Df Photographic Dynamic Range (PDR) - no surprise
Started Mar 12, 2014 | Discussions
bclaff Senior Member • Posts: 2,921
PDR values for the Df are only slightly below the D4 and D4S.
Comparable to the D800/D800E at high ISO (ISO 800 and up).
Interactive Chart - Df versus D4S
Nikon D4 Nikon D4S Nikon D800 Nikon Df
cluna Senior Member • Posts: 1,403
Re: Df Photographic Dynamic Range (PDR) - no surprise
I love how the D3s still makes the grade
-C
rhlpetrus Forum Pro • Posts: 24,486
Thanks, good job. Just one question, for the millionth time: you use the nominal ISO values, correct?
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
bclaff OP Senior Member • Posts: 2,921
For the millionth time
Not quite
Yes, the so called "manufacturer" ISO.
AustinTed Contributing Member • Posts: 564
Thanks for doing this.  Interesting and useful.  On the current generation of cameras D600, D800, D800E, Df, D4. D4S things have clearly hit a wall beyond some subtle (although perhaps perceptible) differences.  Even so the difference between a D800 at ISO 25,600 and Df/D4/D4S/D3S is clearly visible, but it comes through characteristics other than DR and noise.  Color retention and grain quality become the differentiating factor and there probably isn't a good quantitative metric that captures that.
Thanks.
Yes and no. For example, there are ways of measuring pattern noise as opposed to overall noise; but developing an easy to use and  reproducible tests that normal users can perform is another matter.
