HVL-F60M on A7
Started Mar 11, 2014 | Discussions
drjs
drjs Forum Member • Posts: 84
HVL-F60M on A7
I got this flash together with the A7.  I am having problem getting the IR assist to work.  On my Canon, the IR assist just turns on when the scene is too dark.  I can't seem to get this one to go even in a completely dark room.  I have read the manual but couldn't pin point what I am not setting correctly.  Anyone have any suggestions? I am an experienced shooter but this is my first SONY.
 drjs's gear list:drjs's gear list
Olympus PEN E-PM2 Sony Alpha 7 Olympus OM-D E-M10 Sony 100mm F2.8 Macro Tamron SP AF 90mm F/2.8 Di Macro +8 more
Sony Alpha 7
tn1krr Senior Member • Posts: 1,072
Re: HVL-F60M on A7
The AF Assist beam does not work in any any external flash when attached to an E Mount camera. The compatibility list below is for F43AM but it is same with all Sony flashes and E Mount cameras. Actually the AF Illuminator does not work even with the flagship A99...
http://www.sony-asia.com/support/resources/en_AP/html/Compatibility/DSLR/Flash/sony/F43AM.html
 tn1krr's gear list:tn1krr's gear list
Sony Alpha 7R II Kenko Teleplus Pro 300 AF 1.4x Sigma 35mm F1.4 DG HSM Art Sony 70-400mm F4-5.6 G SSM II Carl Zeiss Apo Sonnar T* 2/135 +7 more
drjs
drjs OP Forum Member • Posts: 84
Re: HVL-F60M on A7
Thanks for the quick reply.  Do you know if this is a limitation of the A7 or the flash?
Re: HVL-F60M on A7
Since the AF Illuminator on these flashes work with a pile of A mount bodies I'd say it is the limitation of camera body. There is no known flash available that would give you the external AF illuminator with an E Mount camera.
Scottsphotos Junior Member • Posts: 34
Re: HVL-F60M on A7
The compatibility issue seems to be with E mount cameras.
http://community.sony.com/t5/Alpha-NEX-Cameras/How-dissapointing-A7-or-A7R-and-External-Flash-HVL-F60M/m-p/293036#M3126
"The AF Illuminator function on the external flash unit is designed for A-mount cameras (SLT and DSLR). It is not compatible with E-mount cameras, even if an A-mount adapter with Phase Detection AF is used.
In this case, using an external light source to help achieve focus is recommended if possible. If you cannot change the lighting conditions try selecting a different Focus."
 Scottsphotos's gear list:Scottsphotos's gear list
Olympus E-M1 Sony Alpha 7R Sony a6000 Olympus E-M5 II Sony RX100 +17 more
Re: an AF tip for low light
If one is shooting fast glass like FE 55/1.8 stopped down then turning Live View Setting Effect off makes the camera AF lens wide open. I've tested this in a darkened room ( light meter said -2EV) and when shooting with for example with selected aperture above 2.8 it really helps locking the AF.
drjs
Re: HVL-F60M on A7
Thanks!  Not sure why this wasn't addressed before the bundle was announced.  At a minimal, it should have some type of notice to perspective users.  This kind leave a bad taste in my mouth.  I love the camera and lenses, but not crazy about this flash.
Chad Hardy
Chad Hardy Senior Member • Posts: 1,191
Re: HVL-F60M on A7
Ebay the flash, you should make a profit.
 Chad Hardy's gear list:Chad Hardy's gear list
Fujifilm X-T1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R Sony Cyber-shot DSC-RX100 III Olympus E-M1 +16 more
red fuji Regular Member • Posts: 213
Re: HVL-F60M on A7
That is a big disappointment; just so happens i was testing the flash for the first time yesterday in total darkness and sure enough could not get the AF assist to do its job; no luck. only the AF-A on camera works. But the camera would never take the shot because it could not find focus in that darkness . The AF-A on the A7 does fire but it is not powerful enough to bounce a beam beyond a certain distance although it is within the flash coverage area. This is totaly unacceptable for Sony to make their most powerful flash partially compatible with the A7 A7R.
 red fuji's gear list:red fuji's gear list
Nikon D5100 Sony Alpha 7 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Sony FE 24-70mm F4 OSS Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 7,694
Re: HVL-F60M on A7
so do you know any other big flashes from Canon or Nikon or whatever that will assist mirrorless camera AF (whatever brand is - like Canon flash assisting canon eos-m, etc) ? just curious...
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Phase One Capture One Pro +23 more
drjs
Re: HVL-F60M on A7
As far as I know, Canon/Nikon never offered to sale one of their DSLR flashes as part of their mirror-less bundle.
exdeejjjaaaa
Re: HVL-F60M on A7
And what it has to do with AF assist - was there any promise anywhere that flash assists in focusing for mirrorless cameras ?
Absolutic
Absolutic Veteran Member • Posts: 5,022
No flashes AF assist light works with mirrorless cameras period.
That is true with all mirrorless cameras. and the flashes.   Across brands.   Olympus, Fuji, they all have the same issue across brands and always have.   Basically their TTL flashes are designed only to work with normal phase autofocus detect method through mirror like on DSLRs.  When using with a DSLR, the autoassist light works because DSLR use Phase Autofocusing.    The auto assist light does not work with any camera using contrast focus method focusing.  100% on that.   I've tried numerous other flashes from other brands and the result is always the same
The only two questions I had unanswered were
1)  PDAF on sensor, will that trigger the AF Assist light on flashes designed for DSLR.  My guess would be either NO, or maybe Yes in Daytime shooting when PDAF focus points actually work.  They turn off in low light as we all know as a limitation of every PDAF on sensor in every mirrorless camera from all manufacturers, and it is back to contrast method so no flash af assist light would work.
2) what about using LA-EA4 with Sony A lenses?  Logic tells me that in this scenario, AF Assist light on flashes such as 60AM or 60M SHOULD WORK, because the  A7/r then starts being like any other A big camera with its normal phase af method.
 Absolutic's gear list:Absolutic's gear list
Panasonic Lumix DMC-ZS100 Panasonic Lumix DMC-GX7 Olympus E-M1 Sony Alpha 7R II Panasonic Lumix G Vario 7-14mm F4 ASPH +11 more
compositor20 Senior Member • Posts: 1,631
Re: No flashes AF assist light works with mirrorless cameras period.
can someone confirm that with la-ea4 + sony alpha lenses and fl-60 the camera or the flash emit an AF beam? or if there is any menu option to use the Flash light as an autofocus light... like a built in flash with Sony A57. THanks
