60 yr old model shot with Panasonic GX7
Started Mar 11, 2014 | Discussions
nucmanchh
nucmanchh Contributing Member • Posts: 820
minor PP
Shutter Crazy Regular Member • Posts: 287
Re: 60 yr old model shot with Panasonic GX7
Do you want C&C?
 Shutter Crazy's gear list:Shutter Crazy's gear list
Canon EOS 5D Mark III Canon EOS 5DS R Canon EF 85mm f/1.2L II USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM +2 more
nucmanchh
nucmanchh OP Contributing Member • Posts: 820
not sure what C & C is but go for it
Comments and criticism
Klaus dk
Klaus dk Veteran Member • Posts: 3,342
nucmanchh wrote:
minor PP
I'll be blunt, but these are opinions, so you are welcome to ignore them.
I find both the expression and the pose odd. The bright light on the chest attracts attention away from the face. The tilt of the background is a distraction as well.
Sidelight with no fill seems to accentuate even small imperfections and wrinkles, so a more even lighting will be preferred by many especially female subjects.
Your contact with the model is the most important, but you have to catch the right moment. I'm sure it was there, so keep practising, there's definitely something to build on.
 Klaus dk's gear list:Klaus dk's gear list
Canon PowerShot S120 Canon EOS 500D Canon EOS 7D Canon EF 35mm f/2.0 Canon EF 50mm f/1.8 II +9 more
nucmanchh
thank you! Probably light behind her and use fill-flash?
Your post is a little strange. First you announce subject's age, then you photograph her in the worst possible way, caricature-like. You don't like her?
RunnerSomewhere Forum Member • Posts: 54
I would suggest trying again. Her hair has a green tint and she's wearing a shade of purple. She looks like she could be a sibling of the Joker. She also looks drunk.
Klaus dk
Bad taste
5
Commenting negatively on the looks of models is considered bad taste and not at all helpful to the photographer.
nucmanchh
I announce her age b/c I've been married to her for 30 years. In her 20s she was Miss Marshall University as well as other beauty titles. We're aging now, but being totally bias toward her I like to hear comments when I mention her age (wow! doesn't look her age, still a beauty, yada, yada).
Also I have mostly done landscape photog. I'm now learning portrait, so all ur comments are helpful. I don't have all the lightening I need &, as u noted and I stated, I'm still learning
Re: Bad taste
I meant no disrespect, but it was in bad taste and I apologize. I will try to be constructive. It looks as though she was standing next to a window and shot with natural light. If you have no other lighting, try having her face the window (your back to the window) to get a nice even light across her face. I assume the green tint is the result of something on the window or in the room. That can be fixed by manually setting the white balance in-camera, or adjusted in PP. I'm not a pro, but the head tilt looks off.  It may look fine with adjusted lighting. I have no suggestions, other than to experiment.
TroiD
TroiD Contributing Member • Posts: 505
After making comments like those, I think you must be the one who's drunk. People don't post photo's here to be ridiculed and insulted. They look for another set of eyes to give them feedback on which aspects work and where are the areas for improvement.
 TroiD's gear list:TroiD's gear list
Canon EOS 7D Canon EF 50mm f/1.4 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-300mm f/4-5.6L IS USM Canon EF 40mm f/2.8 STM
Point taken and I've already apologized.
TroiD
She's got such pretty sparkling eyes... they deserve to get some light on them. I like natural light (from a window?) when it's available. Otherwise experiment with whats available. And do come back to show your results. We need to see more of this pretty woman.
David
ktownbill Senior Member • Posts: 2,190
You could have used a reflector to fill in the shadows on her face. If you do use fill-flash, you should use diffusion or reflection so as to avoid the harshness of direct and unmodified flash.  Also consider using off-camera flash both multiple and singular.
There is so much to learn and practice makes perfect. Get some books at the library on portraiture and maybe join a photography club or take a class.
Thanks for posting.
Bill
nucmanchh
from the same night. thoughts?
There is so many things wrong about these, actually everything is wrong. Light, poses, poor focus, processing artifacts. It is not difficult to educate yourself on portrait taking. Libraries, bookstores and web are full of professional level advice and tutorials
nucmanchh
Yep, I'm learning
Klaus dk
My experience...
... with ladies in that age group (I'm 59 and recruit my models among friends) is that one really has to work with the light to get good results.
I don't know if this is correct, but it seems to me that you more or less use the available light, resulting in some WB challenges and generally some problems with direction of light and speculars. Available light often tricks us, because the low intensity fools us into believing it is also soft, which it most often is not.
If the precious moment and available light is what you wish to capture, by all means do so, but if you want to emphasise the beauty of your wife, you will have to work a little harder. Take a look at Christa Meola's work ...
Good luck.
nucmanchh
Re: My experience...
Thanks Klaus. That was helpful
