HD DA TC x1,4: no Sigma HSM; not making FF compatible
Started Mar 10, 2014 | Discussions
beholder3
Regular MemberPosts: 437
Mar 10, 2014
Just to confirm two items:
  • The new TC does not work with 3rd party Sigma HSM driven lenses
    tested on 70-200/2.8 OS and only focussed to infinity nothing else; 85/1.4 not working at all. Even FNumbers are not converted for these lenses (while oldies like FA 24-90 do show converted FNumbers)
  • While in theory a TC would convert the FoV to make APSC lenses FF-compatible in practise they dont, due to the fact that the lens system in the TC has such a small diameter and you get hard black vignetting all around. Tested with some lenses on 5D3.
Other than that the TC isĀ  a little jewel with DA* 300, DA* 60-250 and DFA 100. And that is what it is intended for.
Nikon Df
leopold
Forum ProPosts: 13,223Gear list
Re: HD DA TC x1,4: no Sigma HSM; not making FF compatible
In reply to beholder3, Mar 10, 2014
 leopold's gear list:leopold's gear list
Canon EOS 7D Fujifilm X-E1 Canon EF 400mm f/5.6L USM Canon EF 70-200mm f/4.0L USM Fujifilm XF 14mm F2.8 R +3 more
james45
Regular MemberPosts: 158
Other than that the TC is a little jewel with DA* 300, DA* 60-250 and DFA 100. And that is what it is intended for.
How is it with non HSM Sigma lenses? Keen to know if it behaves with the 100-300 f4...
beholder3
In reply to james45, Mar 10, 2014
Sigma 180 Macro and 105 Macro seem to be doing fine. Looks like screw-driven lenses are fine and only HSMs dont work. On the latter not only FNumbers but also focal lengths are not converted. Seems a Sigma issue.
SungiBr
Regular MemberPosts: 124Gear list
I remember that newer nikons can't properly focus with some sigma lenses to. That was caused by the reverse engineering sigma employs on their lenses, and was adressed with firmware updates for some of their lenses so they can work on nikon bodies.
Still, Ricoh/Pentax didn't state their TC is compatible with third party lenses
 SungiBr's gear list:SungiBr's gear list
Pentax K10D Pentax K-5 II Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc FA 31mm F1.8 AL Limited Adobe Photoshop Lightroom 3 +1 more
james45
In reply to SungiBr, Mar 10, 2014
Thanks everyone. The standoff between camera manufacturers and 3rd party lens makers is understandable... but a little childish to be still running 40 years on, and somewhat irritating to the consumer.
In this case, I'm inclined to vote with my feet and get a 2nd hand Sigma 1.4x converter next time I see one on an auction site.
(And indeed there may shortly be a few, as people buy the Pentax, I suspect!)
Bmoon
Regular MemberPosts: 260Gear list
One of the problem with sigma tc on pentax is that the incorrect fl is given to the body so SR calibrated for the native lenses FL
 Bmoon's gear list:Bmoon's gear list
Canon EOS 5D Mark II Pentax K10D Nikon D3X Nikon D300S Pentax K-5 +7 more
awaldram
Forum ProPosts: 11,287Gear list
In reply to Bmoon, Mar 10, 2014
And has no Pz contacts so won't AF Sigma HSM either.
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax smc DA* 55mm F1.4 SDM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +11 more
GossCTP
Veteran MemberPosts: 4,213
The way I see it, that irritating childishness is where all the profit comes from. There is no technical reason to have the number of mounts that we have today - particularly APS-C. The sole reason is to keep people contained within a system. If they don't handicap third party and legacy glass, how can they charge more for the new stuff? That goes for all manufacturers.
Through the window in the wall
Come streaming in on sunlight wings
A million bright ambassadors of morning
KentG
Veteran MemberPosts: 3,929
In reply to GossCTP, Mar 11, 2014
Now your being a little childish. All lens mounts were proprietary when they started even though some companies started out making lenses for others before becoming camera makers themselves. The only reason we have standards like 4/3 and M4/3 is because of profits. They were not going to become viable systems without involving multiple companies and adhering to a standard mount. Some mount designs were done to maximise the potential advantages of SLRs and others to do the same for rangefinder cameras. If Sigma had not won a big case against the Big 4 back in the late 60's or so we would likely not have 3rd party lense at all. And definitely would not have the camera companies selling lens mount licenses to other lens makers like Tamron and Tokina (they do that so that other companies will compete with Sigma)(Sony now owns most of Tamron). If not for Sigma, OEM lenses would likely cost more than they do now. And no company is going to change their mount to someone elses or a common one. They would automatically alienate their entire customer base. In spite of the fact that the Big 4 had a blanket cross licensing arrangement for decades if not still (see that as Japan against the world in cameras).
Kent Gittings
GossCTP
In reply to KentG, Mar 11, 2014
Perhaps I should have quoted that part, as it wasn't my word.
Yes. And the reason they were proprietary was to create a system. A system to limit competition and raise the barriers of entry. It happens all the time in many industries. Some use the profits to further R&D and flesh out the system, while others use their position to try to lock out potential competitors through lobbying and lawsuits.
4/3 is a different animal. It was done from scratch for a different format size.
There have been advantages here and there that persisted for a few years, but by and large all makers catch up. Either by adding to their mount, or else creating a new mount from scratch that is also proprietary.
Or we would have had more lawsuits.
Kent Gittings
The fact that Sigma can make so many lenses in so many mounts and the Tamron Adaptal system existed seems to support my assertion that there isn't a technical reason for all the different mounts to exist. Not for a given type of camera or format anyhow. It is to create systems. I'm not trying to condone or condemn it, but that is how I see it.
Barry Pearson
Veteran MemberPosts: 6,168Gear list
In reply to beholder3, Mar 13, 2014
  • <snip>
That doesn't appear to be true for the Pentax 1.4 Teleconverter.
The first thing I did when my Pentax 1.4x Teleconverter arrived a few minutes ago was to attach it to a Pentax Z-1p film camera. Then I attached various lenses (below) that might be expected to hard-vignette. None of them showed signs of vignetting, looking through the viewfinder at a well-lit surface.
The lenses I tested that apparently didn't hard-vignette at any focal length , showing image right to the corners, were:
DA 10-17mm Fisheye. (Not on the Pentax list of supported lenses!). This hard-vignettes on the Z-1p at 10mm and 12mm without a Teleconverter.
DA 12-24mm. This hard-vignettes badly on the Z-1p at wide angles without a Teleconverter.
DA 17-70mm. This hard-vignettes at all focal lengths on the Z-1p without a Teleconverter.
DA* 60-250mm.
I haven't yet tested any other lenses on the Z-1p with this Teleconverter. I may shoot my last roll of film with a range of lenses using this Teleconverter on the Z-1p to complete my previous tests of lenses on the Z-1p.
 Barry Pearson's gear list:Barry Pearson's gear list
Panasonic Lumix DMC-LX100 Pentax K-7 Pentax K-5 IIs Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
beholder3
In reply to Barry Pearson, Mar 13, 2014
Barry Pearson wrote:
  • <snip>
You are right. I havent updated my post here later.
I tested with DA 15 and Sigma 8-16 and both hard vignetting came from the unlucky combination of either fixed hood (Sigma) or not fully retracted hood (DA 15) combined with the fact that the adapter mounts the lens somewhat turned to the side so the petal shaped hoods come into sight.
Even the K50/1.2 works fine as does the DA 15. See http://www.dslr-forum.de/showpost.php?p=12056039&postcount=129
Stig Vidar Hovland
Senior MemberPosts: 1,731Gear list
In reply to beholder3, Mar 14, 2014
I suppose you didn't read this from the specification?
Please refrain from equipping the following lenses since the rear converter lens might touch the joint part of those main lenses - HD PENTAX-DA 15mm F4 ED AL Limited / HD PENTAX-DA 21mm F3.2 AL Limited / smc PENTAX-DA 40mm F2.8 XS
Barry Pearson
In reply to Stig Vidar Hovland, Mar 14, 2014
That is a good point! With lenses on the "compatible" list, they are properly aligned, so perhaps we now know what happens when the lens hits the converter!
beholder3
In reply to Stig Vidar Hovland, Mar 15, 2014
I was fully aware. Nothing hit anything even when fully extended. Works allright (but doesnt make sense in real life anyway).
derekkite
Junior MemberPosts: 37Gear list
In reply to beholder3, Mar 16, 2014
150-500 Sigma HSM lens focuses, but the fstop and focal length are not corrected.
 derekkite's gear list:derekkite's gear list
Pentax K-5 Pentax K-3 Sigma 150-500mm F5-6.3 DG OS HSM +6 more
