FINALLY! A small flash for our mirrorless cams.
Started Mar 9, 2014 | Discussions
EthanP99 Senior Member • Posts: 2,421
12
 EthanP99's gear list:EthanP99's gear list
Sony RX1 Sony RX1R Canon EOS-1Ds Canon EOS 5D Mark II Sony Alpha DSLR-A900 +21 more
pedroec New Member • Posts: 22
Re: FINALLY! A small flash for our mirrorless cams.
Will it work with Sony A7 I wonder?
sassenach74
sassenach74 Regular Member • Posts: 375
EthanP99 wrote:
http://www.nissindigital.com/2014/02/new-products-compact-flash-nissin-i40.html
I am very excited for this!
Looks great, can bounce in portrait orientation too. Might hold off buying the Sony HVL-20M until this comes out. Could be quite useful on my A7r.
Thanks for posting.
Neil.
 sassenach74's gear list:sassenach74's gear list
Sony Alpha 7R Canon EF 50mm f/1.4 USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm f/4L IS USM Sony FE 35mm F2.8 +3 more
Peter A. Stavrakoglou Veteran Member • Posts: 7,759
They noted availablility in June 2014 for Sony.  Which Sony cameras is not noted.  I've got an A7 myself, this flash looks very inviting.
My humble photo gallery: http://www.pete-the-greek.com
 Peter A. Stavrakoglou's gear list:Peter A. Stavrakoglou's gear list
Fujifilm X-S1 Panasonic Lumix DMC-FZ200 Sigma SD15 Canon EOS 7D Sigma SD1 Merrill +16 more
EthanP99 OP Senior Member • Posts: 2,421
this site points to MIS compatible shoes
http://www.lightingrumours.com/nissin-i40-speedlight-announced-in-japan-5375#.UxzqpfldVZs
and on the nissin site it says
Supports Canon E-TTL/ E-TTL II, Nikon i-TTL and Sony ADI/ P-TTL.
I am pretty sure its for our MIS shoes
I am also hoping it has a good AF assist light also
It says it has AF assist so that will be good.
What is an MIS shoes please?
npires
npires Senior Member • Posts: 1,545
The head doesn't seem to twist vertically for bounce though does it?
EDIT: Just read the article link yup it does! Excellent
 npires's gear list:npires's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-5 Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 70-200 F4 +3 more
Lightshow
Lightshow Veteran Member • Posts: 4,487
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony Alpha 7R +1 more
MIS shoe is the multi interface shoe on the a58, rx100mk2, a99, rx1, nex6, a6000, a7, a7r, etc
bascially the standard hotshoe with the little prongs near the front like this.
El Matadurr
El Matadurr Senior Member • Posts: 4,988
Wow, this thing is tiny for all the functions and range it provides. Definitely considering this for my NEX-7 via MIS adapter. Good find Ethan.
matthewdurrphotography.com
 El Matadurr's gear list:El Matadurr's gear list
Sony Alpha NEX-7 Carl Zeiss Touit 1.8/32
jpr2 Forum Pro • Posts: 14,710
Matt: NEX-7 via MIS adapter? how does it work and who...
...supplies such adapters? Will be possible to get it working in [E]TTL?
jpr2
LeicaBOSS
LeicaBOSS Regular Member • Posts: 432
If this is real, I will KISS Mr. Nissen. And boo to Sony for this crazy new hotshoe that makes all my triggers useless.
From time to time, I point my camera at the right things. This is generally when I forget everything I've learned.
 LeicaBOSS's gear list:LeicaBOSS's gear list
Leica M9 Sony SLT-A77 Canon EOS M Sony Alpha 7R Canon EF 50mm f/1.8 II +17 more
Vaughn T.Winfree
Vaughn T.Winfree Veteran Member • Posts: 4,036
Re:NEX-7 via MIS adapter? Will I have FULL FUNCTION?
jpr2
My question as well...With NEX 7 with adapter, will I have full (E)TTL function, etc?
Very interested in this.
Vaughn
Vaughn T. Winfree
Go confidently in the direction of your dreams! Live the life you've imagined.
'See what the camera see's, letting the lens interpret what can be. Capture a moment in time telling a story.'--Vaughn T. Winfree
 Vaughn T.Winfree's gear list:Vaughn T.Winfree's gear list
Sony Alpha NEX-7 Canon PowerShot G11 Canon PowerShot S100 Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS +1 more
EinsteinsGhost
OTOH, Nissen likely considered Sony for this unit because of the "crazy new hotshoe". BTW, it is this crazy hotshoe that I share triggers in studio with Canon and Nikon shooters (since I don't have my own) and without an adapter, my iISO shoe equipped a55 is useless.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
LeicaBOSS
I envy you. I'd have to do some dicey physical modifications to my triggers to work with the new shoe. It's just a hassle. I really wish Sony could get their flash system right.
edwardaneal
edwardaneal Veteran Member • Posts: 9,101
already have a small flash - and its perfect size for my NEX-7
smaller than my iphone
 edwardaneal's gear list:edwardaneal's gear list
Sony Alpha NEX-7 Sigma 60mm F2.8 DN Art Carl Zeiss Touit 1.8/32
Thats not nearly as strong nor have the control I need.
straylightrun Senior Member • Posts: 1,292
The AF assist light may not be compatible with mirrorless cameras, only DSLR bodies that support PDAF. I tried the Sony 43AM with NEX-7 with native emount lenses and a-mount lenses with LA-EA2 and the external AF assist light was not supported.
 straylightrun's gear list:straylightrun's gear list
Sony Cyber-shot DSC-HX90V Sony Alpha 7S Canon EOS M10 Canon EF-S 18-200mm f/3.5-5.6 IS Sony E 16mm F2.8 Pancake +19 more
Bart Hickman Veteran Member • Posts: 7,256
Can it be wirelessly triggered?  Does it do tilt AND swivel?
Bart
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Sony a6000 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +10 more
