Windows 7 activation
Started Mar 7, 2014 | Discussions
Michael Fritzen Veteran Member • Posts: 4,598
Hi,
my wife's Windows 7 notebook needed repair for a defect switch. But besides fixing this they said it had some serious virus infection which demanded reformatting. When reinstalling the system they used a different product key than imprinted on the sticker fixed on the notebook's back and now when performing Windows updates the system alerts for non original Windows. Frankly I'm already sick with those people and I don't want to take the notebook back. So here's the question: is there a way to exchange the Windows product key for the correct one? According to MS's site it should work in a way - however it doesn't. I'd appreachiate your help. Thanks.
Michael Fritzen
Jim Cockfield Forum Pro • Posts: 16,333
Re: Windows 7 activation
It may be easier to call Microsoft and explain the problem, where they'll probably give you a key that you can plug in to resolve it. Phone Numbers for Microsoft Activation Call Centers here:
http://www.microsoft.com/licensing/existing-customers/activation-centers.aspx
JimC
Michael Fritzen OP Veteran Member • Posts: 4,598
Hi,
tahnks for the input. Thought about that but I'm in Brazil and I'm a bit afraid of being ripped - you know "taxes may apply".
Michael Fritzen
Osvaldo Cristo
Osvaldo Cristo Veteran Member • Posts: 4,089
Changing Windows 7 activation key
Michael Fritzen wrote:
Hi,
Please check as following steps:
Control Panel->System-> at the Windows activation selection, see if there is change product key link.
If there is not, please use command to try to change:
1. type cmd and right click it to run as administrator;
2. in the cmd window, type slmgr.vbs -ipk <type your product key here>;
3. To activate windows after changing the key, type: slmgr.vbs -ato
[Source: TechNet (I do not have the direct link anymore)]
All the best,
O.Cristo - An Amateur Photographer
Opinions of men are almost as various as their faces - so many men so many minds. B. Franklin
 Osvaldo Cristo's gear list:Osvaldo Cristo's gear list
Olympus Stylus 1030 SW Nikon D200 Nikon D300S Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED +32 more
Bob Collette Veteran Member • Posts: 3,830
Windows Vista and newer (Win7 & 8) allow the user to easily change the product key.  Here's how to do it:
1) Click the Start button, right-click on Computer, and select Properties.  A dialog window will appear with information about the system.
2) Scroll to the bottom of the dialog window to the area where it tells you about Windows activation.  To the right of the Product ID you should see "Change product key"  in blue lettering.  Click this to enter the correct key and try to activate Windows.
 Bob Collette's gear list:Bob Collette's gear list
Canon PowerShot G3 +4 more
Hi,
thanks for the reply. As far as I remember that's also what it says on MS' site but was puzzling me is the fact that there's no saying "Change product key" but simply the logo of "original Microsoft" as if it had been tested and confirmed. But then again at starting the notebook there's always a message appearing that it's not original - what is right because the shown product key on the page you mentioned isn't the proper one for the machine.
Michael Fritzen
Adding to the previous: after I proceeded like Oswald Christo suggested it seems that the right ID was accepted, activated and SURPRISE now the link in blue with the saying for Chaning the product key appears.
Michael Fritzen
Re: Changing Windows 7 activation key
Hi,
All the best,
Hi Oswaldo,
thanks a lot. It worked a charm. Now I hope that the next time I start the computer I won't see that boring message again
Michael Fritzen
