18-55 reconsidered
Started Mar 6, 2014 | Discussions
kriztian
Contributing MemberPosts: 779Gear list
18-55 reconsidered
Mar 6, 2014
Hello,
For a long time I have been unfairly harsh towards my kit lens 18-55 wr. I waited and waited for a new lens to come and when it finally did. (20-40) my disappointment where big to be honest. Although it´s a fine lens in many respects I couldnt bring myself to buy it because the lack of edge sharpness. I then decided to give my old 18-55 a last chance. I went out shooting raw like a mad man and then I w
ent home and run the pics through Lightroom 5 wich I recentley bought. And what happend? When I did all the adjustment I could find, like Cromatich abberation, vingetting color contrast, sharpening etc. the result was: I now like the 18-55 wr. It is quite good if one shot raw and do a lot off pp. Here is one example wich is very representative. I focused on the blue beemer numberplate wide open 18mm. I Think it shows what is possible to do with this lens. Cheers
kriztian
andy amos
Contributing MemberPosts: 685
Re: 18-55 reconsidered
In reply to kriztian, Mar 6, 2014
Sounds like you need to go out and buy a prime! It could the the best thing you ever did for your camera!
M R Padmaraju
Senior MemberPosts: 1,799Gear list
18- 55 is quite capable lens , I like it . My pic is here , for you to see.
Regards ,
mrp.
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-x Pentax K-01 Pentax K-500 Pentax K-S1 +4 more
LDBOK
Senior MemberPosts: 1,016Gear list
I agree that this lens sometimes gets a bum rap, and is actually better than some people give it credit for. Using F5.6-F9 will yield a significant improvement, especially at the wide end. I usually use the 21 or 15 Limiteds instead for the 24mm and shorter range and have thought about replacing the 18-55 for the midrange 28-35, but after comparing test reports to others in that range, there isn't much difference at F5.6-8.
 LDBOK's gear list:LDBOK's gear list
Pentax MX-1 Pentax K-5 Pentax K-3 Pentax smc DA 15mm F4 ED AL Limited Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +11 more
SRT201
Senior MemberPosts: 2,176
It really isn't a bad lens and stopped down it can be decent.  However something like the DA 35 2.4 absolutely blows it out of the water.  Pick one up and you'll see what I mean.  Best bang for the buck in the Pentax glass without question.
Any government that has the power to correct any injustice and level any inequality also has the power to do ANYTHING it wants.
kriztian
In reply to M R Padmaraju, Mar 6, 2014
ThatĀ“s a good one
kriztian
kriztian
In reply to SRT201, Mar 6, 2014
I have the DA 35 and I agree but I like the wide angel when shooting street and landscapeĀ
kriztian
sleepwalker400
Senior MemberPosts: 1,498Gear list
Prime is much BETTER
In reply to kriztian, Mar 7, 2014
All day LONG
 sleepwalker400's gear list:sleepwalker400's gear list
Sony Cyber-shot DSC-R1 Pentax *ist DL Pentax K10D Pentax K-30
dpthoughts
Regular MemberPosts: 101
It's all about sample variation. There are some horrible samples out there, I couldn't believe how blurry the one is, which PentaxForums.com was using in their tests.
But good 18-55 samples are really good! I remember having started photographing a planar target for scientific documentation purposes with my 40mm Limited, but then switched over to my kit (the Version II of 2008), because it gave just better picture quality towards the edges and Corners (mainly because the 18-55 kit lens doesn't seem suffer from curvature-of-field, whereas my Limited prime does (as many primes probably do?)
The kit's sweet spot is around the 24mm mark, where it seems to perform like a prime lens. The wide end (18mm) is quite sample dependent, and the 55mm end is mediocre OOC, but "OK" if given the proper sharpening amount in ACR.
awaldram
Forum ProPosts: 11,872Gear list
In the scheme of things there’s some things that just are.
They'll never be a bad 50 , 135 , 18-55 , 28-80
The reason is because everyone make them so optical solutions are ten a penny and they’re all solid.
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
