Panasonic GX7 with Oly 45mm prime
Started Mar 6, 2014 | Discussions
Pete2 New Member • Posts: 23
I just bought a Olympus 45mm lens for my GX7. I also have 20mm and a 14-140mm zoom which are both Panasonic. The Panasonic lenses fit just perfectly to GX7 with no effort at all and you get a feeling of high quality. When I put my new Olympus lens the fit is much tighter and it doesn't slide as nicely to lock position (you get a feeling that it should need some oil. Of course I don't put any). Is this normal for Olympus lenses?
 Pete2's gear list:Pete2's gear list
Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +1 more
Panasonic Lumix DMC-GX7
MAubrey
MAubrey Senior Member • Posts: 1,598
Re: Panasonic GX7 with Oly 45mm prime
Not all Olympus lenses, but the 45mm is a tight lens across the board.
--Mike
 MAubrey's gear list:MAubrey's gear list
Olympus OM-D E-M5 Sony Alpha 7 Voigtlander 35mm F1.2 Nokton Olympus M.Zuiko Digital ED 75mm F1.8 +2 more
Ultbruin Forum Member • Posts: 91
Hi Pete,
You got the exact same camera and lens that I picked.  Just received my 45mm as well.  It is definitely more snug than the Panasonic lens.  Seems like the norm.
 Ultbruin's gear list:Ultbruin's gear list
Canon PowerShot S95 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Panasonic 20mm F1.7 II
(unknown member) Veteran Member • Posts: 9,509
My 45 is fine on the GX7 no different in that regard to Oly 14-42 kit lens or 12 f2 Oly or Pana 20.
 neil holmes's gear list:neil holmes's gear list
Pentax K-x Panasonic Lumix DMC-GX7 Sony Alpha 7S Canon TS-E 17mm f/4L Canon TS-E 24mm f/3.5L II +8 more
brentbrent Senior Member • Posts: 1,914
I've never noticed this before.  I just tried both my 20mm and my Oly 45. The latter did give a bit more resistance when mounting, but nothing that seems abnormal to me.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH +9 more
Gunnlaugur Gudmundsson
Gunnlaugur Gudmundsson Senior Member • Posts: 1,067
I have both Olympus 17 f/1.8 and the 45 f/1.8 on the GX7, no problem...
I did have a problem with Olympus 12 f/2 when I had that lens and the EM5... very tight... so I guess individual copies may vary....
 Gunnlaugur Gudmundsson's gear list:Gunnlaugur Gudmundsson's gear list
Panasonic Lumix DMC-GX7 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 Sigma 60mm F2.8 DN Art
Impulses Senior Member • Posts: 4,043
Brent
For me it was noticeable on the 45mm straight out of the box when compared to the kit 14-42 II... Can't say I've noticed it over time vs the 20mm or the 12-32mm though.
My 20mm bumps ever so slightly against the tripod-mount strap I have on my camera anyway, so if anything it feels the tightest cause it's back edge rubs slightly as I turn it on the mount. The 12-32mm is so tiny there's just less to grab on so it probably feels tighter than it is too...
 Impulses's gear list:Impulses's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic 20mm F1.7 II Panasonic Lumix G 42.5mm F1.7 +26 more
Lawrence W Contributing Member • Posts: 562
I find the smaller grip on 45mm makes it difficult to rotate. Other than that, a beautiful lightweight lens.
 Lawrence W's gear list:Lawrence W's gear list
Panasonic Lumix DMC-LX5 Olympus OM-D E-M5 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 Nikon D7100 +13 more
