A bunch of firmware updates
Started Mar 6, 2014 | Discussions
brandrx Forum Pro • Posts: 28,337
Firmware updates for K-7, K-r, K-5, K-5 II / K-5 IIs, K-01, K-30, K-500, K-50, and K-3.
I haavn't read what the updates are for yet.
EDIT: It looks like they are all for the Pentax 1.4X AW rear converter.
Click Here For Firmware Updates
Cheers.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
Pentax K-01 Pentax K-3 Pentax K-30 Pentax K-5 Pentax K-5 II Pentax K-5 IIs Pentax K-50 Pentax K-500 Pentax K-7 Pentax K-r
Younes B Contributing Member • Posts: 841
Re: A bunch of firmware updates
Its for the TC, the 4new4 HD lenses and 4 'general performance'  ( whatever that means...)
 Younes B's gear list:Younes B's gear list
Pentax K10D Pentax K-30 Pentax K-5 II Pentax K-5 IIs Pentax smc DA 16-45mm F4 ED AL +6 more
brandrx OP Forum Pro • Posts: 28,337
Let's keep this near the top for the time being.
Ron
Leandros S Senior Member • Posts: 1,804
Is this the first time that the K20D, K-x and earlier models are being left in the dust? Someone should probably publish a timeline so that people can see what will and won't work with older bodies.
No amount of perceived entitlement can replace actual expertise.
ozdean
ozdean Forum Pro • Posts: 22,995
Thanks Ron - you are on the ball!
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 70mm F2.4 AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM +9 more
The K-5 IIs updated with no problems.
Ron
ozdean
Re: The K-5 IIs updated with no problems.
Ditto here Ron & K01.
MightyMike Forum Pro • Posts: 34,528
K-3 so far so good *nt
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Kyogle Contributing Member • Posts: 551
Done!
Thank you, Ron.
I've updated K-5 and K-5 IIs without any problems.
David, an Australian living in the Highlands of Scotland a few months each year.
 Kyogle's gear list:Kyogle's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R +6 more
brecklundin Senior Member • Posts: 1,995
K5 passed the smoke test....so far [nt]
No text.
Kerusker
Kerusker Contributing Member • Posts: 895
Re: A bunch of firmware updates .... coming (slowly)....
Thanks Ron,
the FW updates are listed, but not all update files are downloadable yet (f.ex. K-5 II).
Will you check which EXIF data will be changed/added by the new converter?
Phil Harvey (exiftool) sure will like to know (for all the exiftool users).
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Pentax K-5 II Pentax K-5 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED
Russell Evans Forum Pro • Posts: 11,634
OK, so have you tested your third party TCs to see if they work now?
Just wondering if the new firmware resolves the issues with the old third party TCs as people thought it might, or lately might not.
Thank you
Russell
Kerusker
The K-5 IIs update - currently not available
Currently not available?
I've downloaded the FW 1.16 for the K-5 but didn't see the update FW 1.07 for the K-5 II and K-5 IIs.
Would you please look at the update files when they reappear? Especially for the sub-version numbers (1.07.xx.yy)? - Thanks
][.Kerusker
Looks like the same old behavior after the update on a K-5. n/t
Thank you
Russell
Kerusker
FW 1.07 for K-5 II and K-IIs is available again.
For the K-5 II FW version now is 1.07.24.16 (was 1.06.23.14 before).
][.Kerusker
Re: Looks like the same old behavior after the update on a K-5. n/t
Russell Evans wrote:
Thank you
Russell
Same behavior on the K-5 IIs.
Ron
awaldram
awaldram Forum Pro • Posts: 12,316
So as suspected its a two part solution
Fw and Pentax adapter
Now all I need to know is will the Pentax adapter drive Sigma HSM properly.?
Ron I'm counting on you as I need to order before Monday for a meet next weekend if its a go , No pressure
Seems strange how many sales to Ricoh throw down the toilet by not describing their products properly ?
They must know what people want , If the product will drive 3rd party in lens motors correctly then £379 is a done deal.
 awaldram's gear list:awaldram's gear list
Pentax Q Pentax K-3 Pentax Q7 Pentax K-x Pentax smc DA 40mm F2.8 Limited +15 more
Alex Sarbu Veteran Member • Posts: 5,491
They won't say it for the same reason they won't say their cameras works with 3rd-party lenses.
First, it's not just a claim; they would have to test lenses which are using reverse engineered protocols. And if e.g. Sigma screws it up, Pentax would have to assume responsibility. That's not going to happen.
Besides, Pentax wants to promote using their own products; people might want cheaper 3rd-party lenses but Pentax won't tell them to do so.
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Pentax smc DA 35mm F2.8 Macro Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited HD Pentax DA AF 1.4X AW Rear Converter +2 more
awaldram
I don't see it from that point of view though you have a valid view.
The converter is late to the party it's reasonable to assume possible purchases have already bought the lens they intend to use it with.
The goal has to be to sell as many 'converters' as possible before any third parties appear.
I note in the spec stating any 3rd party lens compatibility even with a disclaimer would massively increase the market impact of the converter.
We have a saying cutting off your nose to spite your face.! which is what Ricoh are doing with this product (if it does have 3rd capability).
Potential sales will not happen because of confusion as to it's applicability to users existing glass.
This lack of initial take-up may end up being 3rd party converter sales or even longer 3rd party glass.
so IMO not making a statement on the converter global appeal far from protecting Ricoh assets will have the opposite effect not generating additional lens sales and damping converter enthusiasm .
Of cause if there is no 3rd party working saying that as well would help with purchasing decisions .
Take my case I'm 80% SDM 20% HSM , If the converter worked with all I'd have pre-ordered happily, If it was reported it didn't work then I probably would have still ordered.
Because we just don't know I decided to wait
I will wait for 'user reports and monitor any 'Sigma' response to incompatibility.
Sigma are likely to take one of two paths.
1 release their own converters with both SDM/HSM
2 update FW for Ricoh compatibility.
If Sigma announce option 1 I will not be buying the Ricoh product
JohnXLondon Regular Member • Posts: 161
The .bin file for the K5II v1.07 upgrade extracts with the same file name as the previous v1.06 upgrade, i.e.. fwdc216b.bin.
Anyone else have this problem please? Does it make a difference to the upgrade?
 JohnXLondon's gear list:JohnXLondon's gear list
Pentax K-S1
