Definition of bokeh, simply gibberish?
Started Mar 6, 2014 | Discussions
guitarjeff
guitarjeff Senior Member • Posts: 1,120
Bokeh is defined as “the effect of a soft out-of-focus background that you get when shooting a subject, using a fast lens, at the widest aperture, such as f/2.8 or wider.”
i agree with this first part.  It is the blur due to shallow dof.
Simply put, bokeh is the pleasing or aesthetic quality of out-of-focus blur in a photograph.
This above is the gibberish part.  A "THING" cannot be an aesthetic opinion, if it were, then you could say a thing exists for one person if he likes it,and doesn't exist for someone else if they don't.  To say it is subjective is really saying nothing about it at all that could be considered a definition.
A quality is an aspect of something. An aspect or quality of something has definable parameters. Never have accepted the artsy definition thrown around because a definition has to be definite, or it isn't definition.
If Bokeh "is" the quality, then is it a sliding scale, meaning one person can say there is bokeh in a photo while another says there is none at all? Saying bokeh is the quality is not a definition at all. That's why I define it as simply the blur due to shallow depth of field. Then we can discuss whether we actually like the bokeh (the blur due to dof), or not. We can decide whether we like the various "Qualities" of the bokeh (blur due to dof) or not, but there will be no argument on whether the bokeh actually exists or not, it will have a concrete definition. In other words, the definition will be definite.
So the standard attempt at a definition appears to be gibberish. Isn't bokeh simply the Japanese word for blur? Anyway, I have set the photography world straight and saved the day for logically minded folks.
The Davinator
The Davinator Forum Pro • Posts: 16,425
Re: Definition of bokeh, simply gibberish?
25
What a long post about something you don't understand or grasp.
 The Davinator's gear list:The Davinator's gear list
Canon PowerShot G3 Canon PowerShot SX150 IS Canon EOS D30 Canon EOS 10D Nikon D2X +18 more
guitarjeff
guitarjeff OP Senior Member • Posts: 1,120
And I notice you offer no explanation for your statement, noted.  And long post?  I have seen far far longer.
bigpigbig
bigpigbig Senior Member • Posts: 1,721
9
Put simply, like it or not, bokeh, IS the quality of the out of focus areas.
There are several aspects to bokeh that make it more or less desirable.
It has NOTHING to do with how out of focus something is. Only the quality of the blur circles (that might not even be circular, but that is another story).
 bigpigbig's gear list:bigpigbig's gear list
Fujifilm X-E1 Fujifilm X-T1 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +12 more
tesilab
tesilab Senior Member • Posts: 2,511
9
There is good bokeh or bad bokeh. Not more or less bokeh, though evidently, if everything is in focus, there is nothing to judge. Yes it is true that it comes from the word for blur, but it is a photographic term used to discuss what that blur looks like, not how much there is.
More specific adjectives that besides "good" or "bad" might be neutral, smooth, hard edged, doubled, nervous, etc. There is also "onion" bokeh, describing apparent concentric rings in an image. If you are using, say a Petzval lens or something similarly uncorrected you would see "swirly" bokeh.
 tesilab's gear list:tesilab's gear list
Sony RX1R II Sony Alpha NEX-5 Olympus Air Panasonic Lumix DMC-GX8 Panasonic Leica D Summilux Asph 25mm F1.4 +13 more
Ed B
Ed B Veteran Member • Posts: 7,486
Bokeh comes from the Japanese word boke. It became popular in the U.S. in the late 1990's when some photography magazine started using it to describe the quality of the out of focus areas of a picture.
If the out of focus areas look good you'd say it had good bokeh if the out of focus areas looked bad, you say the picture had bad bokeh or the lens produced bad bokeh.
It's all in the eye of the beholder. It's simply a descriptive term.
I, personally, always thought it sounded a little effeminate.
unknown member
(unknown member) Regular Member • Posts: 362
Thank you. I don't really know where the confusion is
Matthew Miller
Matthew Miller Senior Member • Posts: 1,306
actually, the first part of your quoted definition is wrong
The above isn't strictly correct, and that's what's tripping you up. Bokeh is visual quality of the out of focus blur in any situation. You just can't see it very easily when there isn't much. (Narrow aperture, or not shooting a subject.)
No; it is the appearance of the blur, not the existence of it.
Or it is the not-pleasing aesthetic quality.
Bokeh isn't subjective. It just is. "Good bokeh" or "bad bokeh" are subjective to a degree, although there are certain aspects which are generally agreed to be one or the other.
That's fine, although don't put too much emphasis on "shallow". And, again, it is a word specifically referring to the appearance of the blur, not the existence. People who say that a photograph taken wide open with a fast lens "has bokeh" are, strictly speaking, misusing the term (because it implies that photographs where the bokeh is less apparent do not have any, which is not usually the case except when the entire photo is completely in focus).
That is already the case.
It is derived from the Japanese word for blur, but has its own meaning. Kind of like how "hardware" in German means computer hardware, and a hardware store selling hammers, hinges, and lumber is therefore pretty funny.
Or..... you have made a up a problem, and then declared that the thing which was already solved is the solution. Which puts us right where we started, except for maybe you will read this and come out a step ahead.
Matthew Miller « http://mattdm.org/ »
 Matthew Miller's gear list:Matthew Miller's gear list
Pentax K-5 II Fujifilm X-T10 Pentax smc DA 40mm F2.8 Limited Pentax smc DA 70mm F2.4 AL Limited Fujifilm XF 23mm F1.4 R +5 more
Conrad567
Conrad567 Regular Member • Posts: 492
Bokeh is the quality of out of focus rendering.  As this is completely opinion based, there is no firm definition. I for one prefer a softer smoother rendering, others prefer the squashed onion look of the old Jupiter lenses.  But either way it is up to each person and of course much to do with the kind of shot you are taking.  My all time favorite lens is the Leica 35mm Summicron.  It is known as the king of Bokeh for a reason...IMHO.
Leica Summicron at f2.0
35mm Summicron wide open
 Conrad567's gear list:Conrad567's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 35mm f/1.4L USM Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +10 more
carlk
carlk Forum Pro • Posts: 15,940
Re: In focus area: IQ. >> Out of focus area: Bokeh.
You say IQ of the picture is good/bad and Bokeh of the picture is good/bad.  Simple as that.
 carlk's gear list:carlk's gear list
Canon EOS 50D Canon EOS 7D Nikon D800E Fujifilm X-E1 Canon EF 85mm f/1.2L II USM +6 more
whiteyblack
whiteyblack Regular Member • Posts: 163
The "f2.8 or wider" part is not really accurate.
Some of the best bokeh I've seen was in a photo taken by a 400mm f5.6 on a APS-C camera focused on a small subject at close range.
 whiteyblack's gear list:whiteyblack's gear list
Fujifilm X100S Nikon 1 V1 Olympus OM-D E-M5 Fujifilm X-E1
kjhants
kjhants Regular Member • Posts: 104
use a mirror lens & you will recognise unpleasant bokeh.
regds
 kjhants's gear list:kjhants's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Fujifilm X-Pro1 Sony Alpha 7 II Sony DT 18-200mm F3.5-6.3 +6 more
Les Lammers
Les Lammers Veteran Member • Posts: 3,008
Everything you ever wanted to know. Given the options in PP I don't worry about it.
http://en.wikipedia.org/wiki/Bokeh
 Les Lammers's gear list:Les Lammers's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X-E1 Fujifilm X-T10 Fujifilm XF 18mm F2 R +5 more
John Gellings
John Gellings Senior Member • Posts: 1,595
I'd rather worry about content and framing... 20 years ago nobody cared about bokeh.
 John Gellings's gear list:John Gellings's gear list
Fujifilm X70 Nikon Df Fujifilm X-Pro2 Nikon AF Nikkor 50mm f/1.8D Nikon AF Micro-Nikkor 60mm f/2.8D +3 more
slimandy
slimandy Forum Pro • Posts: 16,170
Not really. The blur you get has to do with focal length, distance to subject, distance to Bg etc. just as much as it does DoF. You can get more blur with a longer lens even if DoF stays the same. Some people confuse the extra blur with bokeh.
Bokeh is the quality of the blur, not the amount. For example, is the blur soft or fuzzy; how have highlights been treated? You can't really define it as some people like one look more than another.
That's a better way of looking at it but I'm still not sure you have a good understanding of what it means. It has nothing to do with DoF other than you will get more blur with shallower DoF all other things being equal, but that is the amount of blur, not the quality.
www.andrewsandersphotography.co.uk
 slimandy's gear list:slimandy's gear list
Sony RX100 II Nikon D200 Nikon D700 Fujifilm X-E1 Fujifilm X-T1
darngooddesign
darngooddesign Senior Member • Posts: 4,439
Bokeh is absolutely definable as the out of focus areas caused by depth of field.
You can have more or less, which is user controlled.
You can have good and bad, which is a characteristic of the lens. For example, I think this is bad bokeh, like someone blurred an area and then ran a really harsh sharpness filter in photoshop. While good/bad is subjective if most people consider the quality of bokeh from this lens to be unpleasant you can then objectively say that the lens provides bad bokeh.
When people say a photo has nice bokeh, they are referring to a combination of how much and how good the quality of the bokeh is to them.
 darngooddesign's gear list:darngooddesign's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
The Davinator
Ummm...we most certainly did.  It has been a consideration in lens choice as far back as I can remember.  Obviously content and framing are important....but if the out of focus areas are distracting, it's time for a different lens.
slimandy
No it isn't. It is the quality of the blur.
No, you can have more or less blur but not more or less bokeh, and the amount of blur is not just governed by depth of field. A longer lens will give more blur for the same framing and same depth of field.
I agree this is bad, but it is subjective and some people might like it.
They are not quite accurate then. They should only be referring aesthetic quality of the blur. Shallower DoF may affect the quality of the bokeh by giving more blur but so will other factors such as narrow field of view.
http://dictionary.reference.com/browse/bokeh
Les Lammers
+1 To each their own.
guitarjeff
Put simply, like it or not, bokeh, IS the quality of the out of focus areas.'
Wrong.  Like it or not, 2 plus 2 DOES NOT equal 5.  Your statement has no meaning.  If it IS the quality, then define that quality for me?  YOU CAN'T
To you, or to many?  If I like it, and you don't, does that mean there is MORE bokeh for me and less for you?  Is it subjective?
I never said it had anything to do with the amount of blur.  The amount of blur is only one QUALITY of the blur, some may like more, some may like less, amount has nothing to do with it's actual existence.  If bokeh is a THING, then it is definable with concrete parameters, if it is subjective, then it's not definable.
