D4s still lacks wifi and gps!!!
Started Mar 5, 2014 | Discussions
Devendra
Devendra Veteran Member • Posts: 3,584
yes GPS is pointless
GPS is mostly pointless for folks that do not step out of their 1mile permanent living radius.
oh for them i wonder what the point of having D4 is either
Edit: shots added for example. Thanks to GPS on my DSLR's I am able to know exactly where I shot this in
Canyon Lands area
Where I shot this in Glaciar National Park
Where I took this in Alaska while camping in Denali NP
Where I took this in Badlands
Or in India
oh wait.. I don't know where I took this.. since I did not have my GPS
anyway.. having a GPS helps, especially when the info is in the exif
mgblack74 wrote:
I don't understand why you need GPS? We've figured out where we are by maps for many hundreds of years.
Wifi? Consumer models refresh every year, wifi tech progresses with it. The little units that come in the D5300 or accessories for the D3200 & D5200 are anemic at best. Meant to upload 24mp DX photos to your phone or tablet one every 5 seconds. These are too slow for the data that the D4/s needs to put into the webisphere.
Consider also that if the wifi part built in a D4s fizzles, then what? Send it in for repair for a part of the camera unrelated to taking pictures? Sure you can send it in during down time but how many events or gigs have gone by without the ability to send files wirelessly? The external wifi devices make sense for this class of camera (Dprobody). If it dies, you resort to plan B... LAN. You can keep shooting and just get another wifi unit without loss of time without the camera.
If someone is going to have a D4s for a few years it is possible that wifi tech evolves to become faster and smaller independant of the body it's meant to work with. I'd rather upgrade wifi thingamees than the whole cameras. As it is now we upgrade a body to get different resolution and low light performance properties. Imagine the uproar when a D5s comes out with improved internal wifi capability. People are bemoaning the D4s processor increase which is pretty integral to the photographic experience. I.e. It's the 2nd most important part of the camera. Imagine the uproar when a $15 tech boost means a $1000 price increase for a successive model.
Besides. Wifi built in is just something else the NSA can tap into.
"You're guaranteed to miss 100% of the shots you don't take" - Wayne Gretzky
_______________________________
 Devendra's gear list:Devendra's gear list
Sony Alpha NEX-3N Nikon D800E Nikon D200 Nikon 1 J1
mgblack74
mgblack74 Senior Member • Posts: 1,658
Re: D4s still lacks wifi and gps!!!
cluna wrote:
GPS, extra metadata make sorting easier. In 40 years you would rather not ask, when and where did I take this picture
Is it a problem now? Old time film photographers forgetting where the Grand Canyon is? I think in 40 years our biggest problem will be just the inability to read the NEF or JPEG files let alone not remembering where they were taken.
Wifi?
With pro level wifi as it should be, I wouldn't complain about not having to use a cable.
What is wrong with wanting it? Nothing
-C
 mgblack74's gear list:mgblack74's gear list
Nikon D810 Nikon D750 Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 58mm f/1.4G Nikon AF-S Nikkor 70-200mm f/4G ED VR +6 more
CFynn Veteran Member • Posts: 5,224
Josh152 wrote:
LOL a dongle can actually be better since it allows you to not only choose if you want to have wifi or not for a particular situation but also has the potential benefit of being able to buy the next, improved version of the dongle instead have having to buy a whole new camera to get the updates to the wifi.
Wi Fi and GPS chips in manufacturing quantities are now *very* cheap.
Nikon's add on external "dongles" are expensive for what they are - and in use they prevent the use of other accessories that use the same port.
In some situations these dongles  are also prone to being knocked damaged - and damaging the connector on the camera as well
If people want to add improved external devices, Nikon could always provide  an option to disable the internal device and use an external one  - so there is no benefit in not having these features built-in.
 CFynn's gear list:CFynn's gear list
Fujifilm X10 Nikon D800E Nikon AF Nikkor 50mm f/1.4D Nikon AF Nikkor 180mm f/2.8D ED-IF Nikon AF Nikkor 105mm f/2D DC +14 more
MattiH wrote:
Afak gps and wifi would require the body to be partially made of plastic, like 6D and 70D.
Not the actual body - perhaps a small chamber or recess containing the GPS and wi-fi antenna - but that would not need to affect the integrity of the body. It's not as if the camera doesn't already have non-metal flaps and covers.
Gordon Ripley wrote:
Forgot to mention that you can get an APP cheap for your Iphone that will also give you the GPS coordinates of your location...
Of course you can - but it is an added hassle  (a bit less if the camera had wi-fi and the camera  could use it to grab the GPS co-ordinates from the phone)
An advantage of in-built GPS is that the camera can add compass bearing and attitude info along with the GPS co-ordinates. This is not possible when getting the co-ordinates from a phone.
bikinchris
bikinchris Forum Pro • Posts: 18,748
And why not?
golf1982 wrote:
Still lacks wifi and gps. Basic and features found on years old hundred quid compacts!!!! It concerns me how nikon Just doesn't get it. please can someone tell nikon it is no longer 2005
And why not? IT IS THE VERY SAME CAMERA that it was before. Only slight refinements have been included. Get some knowledge of Nikon history.
Cycle tracks will abound in Utopia. --H.G. Wells
 bikinchris's gear list:bikinchris's gear list
Nikon D3 Nikon D4S Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR +1 more
mgblack74
Re: yes GPS is pointless
Does that happen often to you? Mistaking Alaska for India? You might need more than GPS my friend. I am amazed that you've been to these places, taken pictures there and, if not for GPS, you would have forgotten where you took them.
Jack Simpson Forum Pro • Posts: 11,333
Re: D4s still lacks wifi and gps!!! Well, I'm just glad that ….
…. you didn't complain about the lack of a built-in flash
Jack
STREET PHOTOGRAPHY DOCUMENTARY: http://www.youtube.com/watch?v=6kkHKP4Gnd0
(*UPDATED NOV 16th*)MY BLOG.... www.nakedmanonawire.blogspot.com
****MY EMAIL ADDRESS IN IS MY 'VIEW PLAN'****
It's amazing what one can do when one doesn't know what one is doing
 Jack Simpson's gear list:Jack Simpson's gear list
Ricoh GR Digital IV Canon PowerShot G2 Pentax Q7 Pentax K-r Pentax K-50 +3 more
golf1982 OP Contributing Member • Posts: 744
how is that a reason not to include a feature??
unfortunately many cannot see the benefit of a new feature until they have it In their hands.
Wifi?
-C
You really don't want the feature do you. Fortunately if it ever comes you can turn it off. For everyone else, unfortunately  right now they cant turn it on.
try an iphone. I can go to a map and find every photo i have taken from one location, instantly. This is massively useful when trying to find a Picture and saves me time. A massively useful feature then. Sadly i cannot do this for my thousands of carefully organised DSLR shots.
Re: And why not?
is caps intended to imply you are shouting??  Why?
wow you seem quite annoyed by this?
incidentally don't call over half a stop of high ISO, a different CPU and board, SRAW, improved focus, and a host of video features slight. I actually consider the d3s was a bigger update than the D4.
In any case why would adding wifi and gps not be added at a 2 year s update? Its pretty simple to do, and should have been their since before the D3
George Payne Jr Contributing Member • Posts: 605
Someone is ALWAYS gonna have something to complain about. So while everyone complains, I'm gonna go out and shoot with mine!
D4s, D4, D3, D800, D610
Nikon 24-70 2.8, 70-200 2.8 VRII
Nikon 28 1.8G, 35 1.4G, 85 1.4G, 105 2.8 VR
4-SB900, 1-SB910
Eyes like a shutter, mind like a lens!
 George Payne Jr's gear list:George Payne Jr's gear list
Nikon D4 Nikon D4S Nikon D750 Nikon D5 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +7 more
jjnik Senior Member • Posts: 1,319
Re: And why not?
I agree that the D3s was a pretty significant performance upgrade over the D3 - but mainly in 3 areas: new sensor with 1+ stop better high ISO performance, sensor shake cleaning, and addition of video (subpar 720p, though).  So one could say that the D4s appears to perhaps even be a bigger upgrade over the D4 than the D3s was over the D3 - at least on paper; time will tell when we get feedback from actual users).  The D4s adds:
  • New sensor with 1 stop standard ISO range improvement (same as D3s on paper) and 1 extra hi stop
  • New AF mode and improved AF algorithms for faster acquisition and tracking
  • New Image Processor with significant processing power upgrade
  • Higher capacity battery
  • Reworked ergonomics of body (grip, joysticks, vertical thumb grip)
  • Improved mirror mechanism - less slap and less blackout time
  • Improved AWB and spot WB
  • Faster burst rate (with better AF performance in bursts) and improved buffer
  • Faster ethernet port
  • New sRAW option
  • Significant improvements to video/audio
  • Ability to change autofocus modes via lens buttons on the super teles
So pretty decent list of upgrades versus the D4 if any of those areas of improvement are important to you...
Now there's your one(1) picture being worth ...
…. and a thousand words  Good stuff George
Jack
4-SB900, 1-SB910
vortex09 Forum Member • Posts: 68
I'm with you; it's asinine that either of these "features" are excluded from any DSLR released over the past several years. Unless it's a bare-bones $300 model where every corner is cut in the name of cost -- which, ironically, are the only Nikon models getting these features!
The ignorance in this thread is stunning. GPS is only for "girls posting selfies to Facebook?" How about easy geotagging of landscape photos shot in remote areas? Because Nikon declined to include an incredibly cheap GPS chip in the D610 (couldn't they have at least used it as a good cover for the fact this model is just a non-defective D600?), I now have to record my GPS track to a file on my phone, then try to sync the track file with photo timestamps later. Thanks, Nikon. And last I checked, I'm not shooting "girlie selfies" or concerned about posting to social media from the field.
As for wi-fi, that's more debatable given some of the issues raised here. Still, it ought to be included. I shot with a Canon 6D up until a couple months ago, and the ability to remote control with a smartphone was very handy in certain situations.
 vortex09's gear list:vortex09's gear list
Nikon D5100 Nikon D610 Nikon AF-S Nikkor 70-200mm f/4G ED VR Nikon AF-S Nikkor 18-35mm f/3.5-4.5G ED Samyang 14mm F2.8 IF ED MC Aspherical +1 more
Joe Tam Contributing Member • Posts: 648
Sad thing is my $400 GoPro Hero 3+ & $750 Panasonic GX-7 have built-in Wi-FI and my D4 $5500+ does not.  I played with my friend's 6d with the iPhone app and the feature comes very handy in many situations.
I have used the Go Pro and GX-7 on a Shur line paint pole with Kacey pole adaptor(use loctite btw) in many situations where I needed a higher perspective.  being able to get a feed of the camera sensor allows precise framing.  very useful.
GPS would be another bonus feature.  I would love to have Lightroom mapping feature show all the photos based on location from GPS data embedded in all my images.
 Joe Tam's gear list:Joe Tam's gear list
Panasonic Lumix DMC-GH4 Nikon D4S Nikon D4 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Canon PowerShot G9 +23 more
Pandaemas Contributing Member • Posts: 554
While I understand that adding wifi and GPS seems blatantly easy and inexpensive, but I also understand that they are more "gimmick" to me than a real use for cameras.
While others have stated there are certain rules and regulations against having wifi and gps in a device, to me they are extra features that are not neccessary and may break down and cause the camera to function properly.
Just my 2c..
Instagram: NormanTJ
www.memorialucis.blogspot.com
Both these technologies have reached a state where they are very reliable - much more so than many other components in a DSLR.
They should be even more reliable when built into a camera than they are when mounted externally where they can easily get knocked and need to rely on external cables and connectors
Do you really think it would be beyond the capabilities of Nikon engineers to design cameras in such a way that if either of these components failed it would not effect the normal functioning of all the other features of the camera?
ChapelThrill23 wrote:
"As for wifi...it's a standard that is always changing. It doesn't make sense to put current wifi into a pro camera that could be used for 10-15 years."
I'm not sure if I buy these excuses. Do people really use cameras for 10-15 years in the digital era? I really doubt many will be using these things four or five generations of camera from now. In terms of the wifi standards changing. That is true to some extent but things tend to be backwards comptable. Devices of mine that are about a decade old still work fine with new wireless networks. They might not be able to work at the speed a new router is capable of but they still work just fine. Certatinly I'd expect a new camera's wifi system to be comptable with what we will be using 3-5 years from now at minimum.
People love to think up excuses to defend Nikon - or whichever their favourite manufacturer happens to be.
Nikon realise they can get people who buy D4 level cameras to pay extra money for expensive add-ons to get features they need - and selling those is profitable to Nikon. I suspect they will likely only move on including these features on this level camera when their main competitor does.
RicAllan Contributing Member • Posts: 760
golf1982 wrote:
RicAllan wrote:
If you want a P&S hundred quid camera... buy one. If you want a swiss army knife, buy one... Many others have tried to make the point regarding the downside (and sometimes difficulty) with certain features low volume cameras so I'll stop there.
i hve not seen a single downside to intigrated wifi or gps. Both are really usefull features that should have been included years ago. the cost of inclusion would be negligable, unless of course you account for the lost money from sales of the massively overpriced Nikon wifi dongle!!
Downside:
1) Two way connection means there's a way in, read TO HACK, the camera
2) As technology creeps along (right, creeps), today's standard soon becomes obsolete. If you buy cameras on the gee whiz factor, this may not be a big drawback but if you but it as a tool...
3) As someone else has already mentioned, if the wi-fi or gps malfunctions, you lose the whole camera during its repair
4) It adds cost some of us DO NOT WANT for features we will not use
5) It adds weight (a little bit here, a little bit there... adds up)
6) It adds size
7) It adds complexity impacting overall reliability
8) It does NOTHING for picture quality
Do you want me to go on....
Ric
Ric
 RicAllan's gear list:RicAllan's gear list
Nikon D4S Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 24-120mm f/4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +2 more
