Sony 16-50 2.8 vs Sigma 17-70 "C"
Started Mar 5, 2014 | Discussions
ERN812 Regular Member • Posts: 162
I'm looking to upgrade from the kit lens on the a57 and am considering Sony's 16-50mm and Sigma's 17-70 "C" lens.  Any thoughts on the two?  I looked at a couple reviews online and it seems like they are both similarly sharp when comparing them at the same focal length and aperture, but the Sigma looks a little sharper wide open (which, of course, is slower than the Sony at the longer end).  Both have the SSM/HSM focusing mechanism.  Given all this, it seems like my decision really boils down to whether I want the faster apertures on the long end of the lens in the Sony or the greater reach of the Sigma.  (I know the Sony is also weather sealed, which might be nice to have at some point but my a57 is not and I don't plan on upgrading cameras any time soon.)
I've also looked at the Sigma 17-50 2.8 a little bit.  It too has the HSM motor and seems slightly sharper than the Sony 16-50 at 2.8, but the Sony seems to have it beat once stopped down.
Any advice anyone has would be much appreciated.
 ERN812's gear list:ERN812's gear list
Canon PowerShot SX230 HS Sony SLT-A57 Sony Alpha 7R II Sony DT 18-55mm F3.5-5.6 SAM Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +5 more
Sony SLT-A57
Marco Cinnirella
Marco Cinnirella Veteran Member • Posts: 5,143
Re: Sony 16-50 2.8 vs Sigma 17-70 "C"
Perhaps consider what focal lengths you are likely to use most and how important extended warranty (Sigma warranties are now usually 3 years, Sony still 1 year) and weather sealing are to you (only in the Sony).
My copy of the Sony 16-50 is very sharp from 20mm-50mm, and has nice contrast and colors, but is really quite soft at 16-18mm unless I stop down to about f8 and sharpen quite aggressively. Even then, the corners can be a mess. My Sigma 10-20 smokes the Sony in terms of sharpness at the wide end. I still like the lens as a walkaround - you just have to try to remember to stop it down when shooting subjects like landscapes or architecture at the wide end. Some also complain about the complex distortion at the wide end, but to be honest I find DXO Optics Pro does a decent job of dealing with that (I shoot raw). The build and focus are very nice - there are a few reports of SSM failures on some 16-50s, but not many. maybe also consider the Tamron 17-50 2.8 too? I found that better at the wide end than the Sony, but of course it's not SSM/HSM and isn't quite as wide...
"When words become unclear, I shall focus with photographs. When images become inadequate, I shall be content with silence." Ansell Adams.
 Marco Cinnirella's gear list:Marco Cinnirella's gear list
Fujifilm FinePix X100 Sony SLT-A77 Olympus OM-D E-M5 Sony SLT-A99 Fujifilm X-T1 +4 more
K E Hoffman
K E Hoffman Senior Member • Posts: 4,825
I have the new Sigma 17-70 "C"  Its a great lens, especially for the cost.
I have also been researching the Sony 16-50 2.8 to see if it is an upgrade worth the money
Sigma:
Pros
  • Flat sharpness center to edge at all by wide angle
  • Sharpest at F5.6
  • 70mm extra reach and long-end
  • Lower CA than Sony
  • Pretty Silent Focus (in quite locations automatic gain on they A77 mic pics up some clicking as it starts, stops or changes direction)
  • Price under $500
  • Looks really nice with monochrome design and is compact
Cons
  • F4 at 70 mm where it is a good portrait lens length BUT may not have narrow enough DOF for some types of portraits
  • Sharpest at F5.6
  • Drops out of F2.8 soon and is one stop slower by 70mm
  • Lens switch has to be changed for MF, no DMF no full time manual override adjustments like Screwmount with DMF or SSM
  • No weather sealing
  • Sony Lens JPG compensation does not support lens
Sony
Pros
  • Very sharp at F4 at all FL and pretty flat response (sharper than Sigma)
  • extra reach and wide end
  • F 2.8 available at all FL one stop more light at 50mm
  • Less distortion at long end 50mm than sigma
  • Super Silent Focusing
  • Manual Focus Ring usable at all times for fine tuning
  • Weather Sealed like A77 body
  • Sony internal lens jpg compensation function supports lens
Cons
  • Can be soft and edge soft at F2.8 at all FL (but Sig doesn't even have option)
  • Sony bodies don't simulate DMF feature of turning on focus peaking like screw mount, should be simulated in AFS (Push since neither lens support 100% of DMF function)
  • More CA than Sony
  • Larger than Sigma
I used SLR GEAR tests to evaluate the lenses.. and my personal use of Sigma to confirm it is a nice lens.
For me optically they are close and I am not sure Sony is worth more.  SSM and weather sealing have me thinking about it.  If Sony simulated full DMF by turning on focus peaking after an AFS event.. so it behaved like a screw mount lens on DMF ... I would buy it for sure.  Right now.. I am sticking with the Sigma because I own it and it would cost me about $250 to upgrade.
K.E.H. >> Shooting between raindrops in WA<<
Don't Panic!.. these are just opinions... go take some pictures..
 K E Hoffman's gear list:K E Hoffman's gear list
Canon EOS 450D Nikon 1 J1 Sony Alpha a6300 Sony 100mm F2.8 Macro Sony E 18-200mm F3.5-6.3 OSS +4 more
EinsteinsGhost
I went with the Sony 2+ years ago. And it is the only zoom lens I care about. It has been on the a55 practically all the time. I find the lens quite sharp wide open at any aperture. At f/4, I would say it is as sharp as a zoom lens gets.
SSM is super quiet, close focus (and 1:4 magnification), no zoom creep (my only Sigma HSM is 18-250 which loves to zoom on its own), no CA issues. I also love the contrast and color out of the Sony (Sigma lenses seem to favor green a bit). The only advantage to Sigma might be that it gives you about 20mm more reach... nice to have but I would rather gain at the wider side. And price.
Needless to say, DT 16-50/2.8 SSM on a55 and E 35/1.8 OSS on NEX-6 are my go to options. For extra reach, I generally have Sigma 70/2.8 and usually Sony 135/2.8 STF at hand anyway to go on either camera.
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
Seeky Contributing Member • Posts: 755
I completely second EinsteinsGhost. Also went with the 16-50 2+ years ago, and I still enjoy it almost every day. It is sharp in the center wide open at every aperture on my A57. The only negative I could think of is the distortion at 16mm (which is easily corrected in camera (JPEG) and in LR (RAW) with a lens profile).
I would never trade the f2.8 for 50-70mm zoom range. In addition, one never knows whether the Sigma will work on the new SLT models coming out especially when OSPDAF is involved.
 Seeky's gear list:Seeky's gear list
Sony SLT-A57 Sony Alpha 7 Sony Alpha 7 II Sony Alpha a6300 Sony DT 35mm F1.8 SAM +12 more
vw671 Contributing Member • Posts: 536
+3 on the SAL1650
 vw671's gear list:vw671's gear list
Sony RX100 Sony SLT-A57 Sony a77 II Tamron SP 70-300mm F/4-5.6 Di USD Sony DT 16-50mm F2.8 SSM +2 more
K E Hoffman
Small correction to lists - Sony 16-50 2.8 vs Sigma 17-70 "C"
K
Sigma:
Pros
  • Sharpest at F5.6
  • Price under $500
Cons
  • Sharpest at F5.6
Sony
Pros
Sharpest at F5.6
Cons
  • More CA than Sony
  • Larger than Sigma
K E Hoffman
The "C" model supports user updates and a dock for Sony is due out this spring..   Only a few older HSM lenses ever had a problem and were updated for free.  SO while a consideration.. I am not too worried.
phaedin
phaedin Senior Member • Posts: 1,454
I was making this choice about a year and a half ago (the C version wasn't out)
I went with the Sigma for 3 reasons
it was about $300 cheaper then the Sony
it had extra reach
it has a very close minimum focus distance (it has a macro classification - but it isnt a true macro lens)
If I was making this choice now I would go with the Sony as the constant aperture (in my opinion) out weighs the other advantages that my Sigma has.
I still really like the Sigma (and the C version is supposed to be a bit better too) - it is on my camera most of the time.
The only thing that is a real advantage for the C version is the potential to fine tune the focus with the dock (when it gets released) as the A57 doesnt have micro focus adjust in camera
Only you can evaluate your needs and which lens will suit you best
 phaedin's gear list:phaedin's gear list
Nikon D7100 Sigma 17-50mm F2.8 EX DC OS HSM Tamron SP 70-200mm F/2.8 Di VC USD Nikon 200-500mm F5.6E ED VR
jidery Regular Member • Posts: 212
Get the Sony. It's one of the sharpest lenses ive used and even is capable of beating out some primes. Check out my thread I made a little while ago to see what I am talking about:
http://www.dpreview.com/forums/thread/3626897
In short, here are a couple shots with this lens.
 jidery's gear list:jidery's gear list
Sony RX100 II Sony Alpha NEX-5N Sony SLT-A77 A3000 Tamron SP 70-300mm F/4-5.6 Di USD +3 more
tqlla Veteran Member • Posts: 3,080
The 16-50mm lens can be had for $500 used.
If I had to choose between an
used but in good condition Sony 16-50mm F2.8
or a Sigma 17-70mm F2.8-4
I would take the Sony 16-50mm and buy a squaretrade warranty.
 tqlla's gear list:tqlla's gear list
Sony Cyber-shot DSC-RX10 Sony Alpha DSLR-A850 Sony SLT-A99 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +8 more
joel22484 Regular Member • Posts: 319
I've had both and ended up with the Sigma in the end...for now
I've gone back and forth a few times on my primary zoom so I figured I would chime in.
I started with the Sony 18-50 kit lens. I sold that and bought a Sigma 17-70 lens (prior to the "C"). I had that for a couple years and then went with the CZ 16-80. I loved the Zeiss. It was super sharp, the range was great too. But it was only about a year before I was itching for something new so I went to the Sony 28-75 f2.8. I figured I would like the constant aperture better since I shoot a lot indoors.
Well, I ended up missing the 16-28mm range a lot so I went to the Sony 16-50mm f2.8. I stuck with this lens for about a year. The aperture was nice and it was pretty sharp, I just was now missing the 50-75mm at the longer end. I could tell a difference in my pictures and I was just not able to get what I wanted with the 16-50.
So last December I bought the newer Sigma 17-70 "C" lens. I kept the Sony 16-50 for a few more weeks just in case but it is gone now. I love the Sigma, but of course I miss the constant 2.8 aperture. I listed the criteria I needed though to make my decision.
*I needed it for video so silent focusing was a must (both lenses do this excellent)
*With video, I use auto focus a lot, so the aperture is bumped up to f3.5. Due to that, the constant 2.8 is not a help on the Sony.
*I wanted the range of roughly 16-80 and the 17-70 fit great. The 16-50 left me missing the last 20mm.
*Decent macro was a bonus, so I sold my macro lens.
I still only slightly miss the 2.8 aperture. If I'm shooting indoors and it's dark, then I just use either my 30 or 50mm primes since they are f1.4. I also like to bounce flash. So for now I am currently using the Sigma 17-70 on my a77 and like it a lot. It's convenient, light weight, sharp.
Someone said it above, it mainly boils down to whether you want the constant 2.8 aperture or the 50-70mm at the long end. If you haven't made a decision yet, good luck!
 joel22484's gear list:joel22484's gear list
Sony RX100 II Sony a77 II Sony Alpha 7 II Sigma 50mm F1.4 EX DG HSM Sigma 30mm F1.4 EX DC HSM +14 more
Arrow34 New Member • Posts: 12
+4 for the SAL1650
I bought a SAL1650 when I was thinking of keeping my A580 and LOVED IT! I then got the itch and upgraded to an A77, I bought the combo A77 + SAL1650 because my gf said she wanted to keep the SAL1650 on the A580. This is my goto lens, I keep it on my a77 90% of the time with the other 10% being split between SAL35F18 and a few older minolta zooms.
Few examples...
http://www.flickr.com/photos/67426042@N04/9341399781/in/set-72157634743387459/
http://www.flickr.com/photos/67426042@N04/9341393419/in/set-72157634743387459/
