HDMI cable question
Started Mar 4, 2014 | Questions
fortdodge New Member • Posts: 7
HDMI cable question
I want to view images from my Nikon D600 on the LG TV we just bought.
The camera manual says I need a type C mini-pin HDMI cable.
The manual for the TV doesn't specify the type of HDMI cable I would need.
My question is, how can I make sure that whatever HDMI cable I buy (probably on Amazon) will plug into my camera AND my TV?
Nikon D600
romfordbluenose Senior Member • Posts: 2,083
Re: HDMI cable question
You need a cable with a standard HDMI cable connection for the TV end and the appropriate one for the other end. Amazon sells them all.
e.g. HDMI to mini HDMI (male to male)
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
Rservello
Rservello Senior Member • Posts: 1,157
http://www.amazon.com/gp/product/B00A6VPU5S/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
I have that cable and it works perfectly.
Also, don't forget, the D600 records to H.264.  Any modern TV with an SD slot can play them back natively.
https://www.flickr.com/photos/49019071@N03/
http://www.imdb.com/name/nm2334596/
* Sensitive Internet User Disclaimer: All opinions are my own and are not meant to offend you or damage your precious beliefs.
 Rservello's gear list:Rservello's gear list
Panasonic Lumix DMC-LX100 Nikon D600 Nikon AF Nikkor 50mm f/1.8D Voigtlander 58mm F1.4 Nokton SL II Rokinon 85mm F1.4 +4 more
fortdodge OP New Member • Posts: 7
thanks for your help.
calson Veteran Member • Posts: 7,393
I would want a cable considerably longer than 18 inches to connect a camera to a TV or anything for that matter. Even Nikon usually provides 1.5 meter length cables with its cameras.
Rservello
If you actually looked at the link I posted you will see that they have options up to 6 ft
