Pop up Flash on A65
Started Mar 4, 2014 | Discussions
enemjii Senior Member • Posts: 1,889
Pop up Flash on A65
Recently I took some pictures in the night using the cameras pop up flash and realized that often times after quick consecutive shots the flash would not fire. It would strobe, but not allow to take a picture. Is it because it is still recycling or is it trying to cool down?
 enemjii's gear list:enemjii's gear list
Sony SLT-A65 Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Sony DT 35mm F1.8 SAM Sigma 85mm F1.4 EX DG HSM +6 more
Sony SLT-A65
thebustos Senior Member • Posts: 2,752
Re: Pop up Flash on A65
It's because it's recycling. If you're using full power the flash has to build the charge back up before it can flash at full power again. If you trigger the flash before it's had a chance to fully recharge it will go off with whatever charge it had built up (less than full power). However, if you are using a lower flash power setting you can probably do a few back to back before it needs to fully recharge.
Good luck and happy shooting!
 thebustos's gear list:thebustos's gear list
Sony SLT-A77 Sony DT 35mm F1.8 SAM Sony DT 50mm F1.8 SAM Sony DT 30mm F2.8 Macro SAM Sony DT 16-50mm F2.8 SSM +17 more
dolbyscat
dolbyscat Regular Member • Posts: 226
Yup...
 dolbyscat's gear list:dolbyscat's gear list
Sony SLT-A77 Sony DT 11-18mm F4.5-5.6 Sony 70-300mm F4.5-5.6 G SSM Sony 100mm F2.8 Macro Sony DT 16-50mm F2.8 SSM +3 more
