nifty 50 equivalent under $200?
Started Mar 4, 2014 | Discussions
Sean Caldwell Regular Member • Posts: 229
Ordered an Olympus OM-D E-M10 and the 12-40mm 2.8 lens. One lens I used from time to time on the Canon gear was the 50 1.8. It's a great lens for $100. Is there a favorite equivalent wide aperture inexpensive lens that will work well on the Olympus?
I see the Panasonic 20mm 1.7 pancake, but the cost is $300+
Olympus 25 1.8 is near $400
They're probably built better than the nifty 50, but anyone know if an inexpensive (under $200) 1.8 50mm equivalent might be coming?
Sean
Olympus E-M1
Henry Richardson Forum Pro • Posts: 15,347
Olympus 25mm f1.8 (50mm equivalent)
The new Olympus 25mm f1.8 (50mm equivalent) was just released. A few people here have it already. Not under $200.
Henry Richardson
http://www.bakubo.com
techiecool Regular Member • Posts: 413
Re: nifty 50 equivalent under $200?
The nifty 50 has been around a long long time allowing economies of scale to push priced down. And add larger sales volumes and the nifty 50 is cheap. Id imagine in 3-5 years of continued growth that could be achieved.
Bob Tullis
Bob Tullis Forum Pro • Posts: 31,105
I believe that's the cheapest fast prime in the 50mm FOV range for this format.
...Bob, NYC
http://www.bobtullis.com
http://www.flickr.com/photos/bobtullis/
"Well, sometimes the magic works. . . Sometimes, it doesn't." - Chief Dan George, Little Big Man
 Bob Tullis's gear list:Bob Tullis's gear list
Sony Alpha 7S Sony Alpha 7R II Voigtlander 28mm F2 Ultron Sony RX1R II Sony Alpha 7 II +16 more
Fredrik Glckner Veteran Member • Posts: 3,332
That will have to be the Sigma 30mm f/2.8 DN, which I think is very good. Not very fast in terms of aperture, but good on image quality. My review:
http://m43photo.blogspot.com/2012/07/sigma-30mm-f28.html
FrankS009
FrankS009 Veteran Member • Posts: 3,768
Sigma makes a not bad 30mm 2.8 for about $200, and sometimes you can find version one - only cosmetically different for $150.00
F.
When no-one else is there, the camera becomes my means...to say to a wider audience, "Did you see that?" David duChemin
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GX7
amtberg Veteran Member • Posts: 5,532
You have one for free!
Well, since you already own the 12-40/2.8.  That zoom is better at 25mm/2.8 (50 equiv.) than is the cheap Canon prime at f/2.8.
But you will have to pay more to get under f/2.8.
baxters Veteran Member • Posts: 4,997
The Olympus 25mm f1.8 fits your bill and was $100 off, or $299 if ordered with an EM10 from Olympus USA thru the end of this month. However, they do add sales tax.
By years end, you will probably find it for $319.
 baxters's gear list:baxters's gear list
Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6
broody Contributing Member • Posts: 674
There are no plans for a lens this cheap in the near future. The 20mm may drop close to $200 in the used market as people may now be more drawn to the 25mm Oly, but you'll have to wait and keep an eye on it.
The reason there are no lenses as cheap as the canon EF 50mm 1.8 for other formats, is simply that it's a cheap-ass lens in every sense of the word. Bad build, bad and noisy AF, old 1990s design that is very soft wide open... M43 glass is more expensive, but you get what you pay for, generally speaking.
 broody's gear list:broody's gear list
Canon EOS 5D Mark II Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Canon EF 50mm f/1.8 II Canon EF 24-105mm f/4L IS USM +5 more
Bob Tullis
I started to go 'there' too, but realized he has the 2.8 12-40, and the main consideration after the FOV was the maximum aperture.   I also resisted mentioning the CV 25/0.95 (a little bit more than $300 $500 $700 [g]).
...Bob, NYC
Krich13 Contributing Member • Posts: 619
Sean
Well, the only actual equivalent (in terms of DOF and light gathering) of 50/1.8 in m43 world is Voightlander 25/0.95, but it's nowhere near $200 (and manual focus at that). I wouldn't expect anything of a kind to drift below $200 anytime soon.
Ido S
Ido S Senior Member • Posts: 2,763
No (with exception)
That's the main disadvantage of the Micro Four Thirds system in my opinion - some lenses are pricey compared to DSLR lens offerings. However, if you don't mind focusing manually (your E-M10 has focus peaking, which makes MF much easier), you can snag a great deal on a legacy lens, maybe a 24mm which is usually pretty common in the traditional 35mm format.
 Ido S's gear list:Ido S's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital 25mm F1.8
Steve_
Steve_ Senior Member • Posts: 2,503
I'd recommend just paying the four bills for the Oly 25/1.8. Mainly because it competes equally with the most expensive 50s, not the cheapest (and it's tiny). In that context, the price could be seen as a bargain.
One thing about m43s - it ain't cheap. But the value of Oly products like the 12-40, 25/1.8, 45/1.8 and 75/1.8 is still excellent because of how good they are optically.
As good a lens as the 12-40 is, I don't think you'd be happy with a $100 solution, anyway. And if/when it comes time to sell it, that 25/1.8 will still be worth $300 or more. It's not spent, it's invested.
 Steve_'s gear list:Steve_'s gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Panasonic Lumix G 14mm F2.5 ASPH +12 more
FrankS009
Oops, meant this as a sub-message to the OP, not to yours Bob.
F.
Kevdog
Kevdog Senior Member • Posts: 1,408
Sean
I actually had the Pany 25mm f1.4 on my E-M5 for quite a while.  But when I got the Pany 12-35mm f2.8 (basicaly the Pany equiv of the Oly 12-40 f2.8) I went ahead and sold it.  I personally didn't need the extra stop and the sharpness is so close that I just never put the 25mm on the camera anymore.  And no need letting a lens sit idle!
But if I did want the extra stop, I'd save my pennies and get the Pany version.  You can find a used one for around $400 and it's worth every penny!
 Kevdog's gear list:Kevdog's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic 12-35mm F2.8 Olympus PEN E-PL5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +2 more
mh2000 Senior Member • Posts: 2,774
Sigma 30 as close as it gets
Sean
I bought into m43 on whim without realizing there was not nifty-50 eq. for the system. I have the Sigma 30/2.8. Really nice cheap lens. The older style ones can be found for less than $100 used/mint. Probably better than the EF 50/1.8 II. I also have the Oly 17/2.8... another nice cheap SMALL lens (no matter what anyone else says!).
Sudo Nimh Regular Member • Posts: 281
You're right about DOF, but a 25mm f/1.8 lens designed for Micro Four Thirds has the same light-gathering as a 50mm f/1.8 lens designed for full-frame (35mm). The larger lens gathers 4 times as much light, but the light is spread over an image circle 4 times as large.
yonsito Forum Member • Posts: 91
Olympus 45 1.8
I'd recommend the Olympus 45 1.8. It's over $200 but the perspective is close to your nifty fifty and it complements your 12-40 nicely.
 yonsito's gear list:yonsito's gear list
Panasonic Lumix DMC-LX3 Panasonic Lumix DMC-GF1 Olympus PEN E-P3 Olympus OM-D E-M10 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +10 more
Ulfric M Douglas Veteran Member • Posts: 4,535
Ordered an Olympus OM-D E-M10 and the 12-40mm 2.8 lens. One lens I used from time to time on the Canon gear was the 50 1.8...
So which focal length are you looking for?
A $100 50mm lens on a full-frame body is suddenly not cheap at all,
A 50mm lens on an APS-C Canon is not even close to a 25mm or 30mm on m4/3rds, so are you seriously looking for a 40mm autofocusing m4/3rds lens?
Cheksa wrote:
You're evil Ulfric.
Bhima78 Senior Member • Posts: 1,930
Exactly. The Oly 24mm 1.8 looks more like a competitor to Canon's stellar 50mm 1.4 not the bleh Canon 50mm 1.8.
 Bhima78's gear list:Bhima78's gear list
Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario 35-100mm F2.8 OIS Sigma 60mm F2.8 DN Art +7 more
