D7100 exposure accuracy?
Started Mar 4, 2014 | Discussions
Torben Laursen
New MemberPosts: 13Gear list
Mar 4, 2014
Hi I own a D7100 and have by now shot few thousand photos. I love the camera and it takes stunningly good photos (color/sharpness) But  I think it underexposes lightly by - a third to - two third f-stops.
Has anyone had similar "problems" with their D7100? How easy is it to fix? I still have my one year warranty.
Torben
 Torben Laursen's gear list:Torben Laursen's gear list
Nikon D7100 Nikon D750
Nikon D7100
Mako2011
Mako2011 MOD
Forum ProPosts: 19,180
How?
In reply to Torben Laursen, Mar 4, 2014
First, when you say it underexposes, how are you coming to that conclusion? Not doubting you but there are so many factors. Are you shooting in LiveView? How does the Histogram compare? What metering/exposure mode are you using. So many variables. Have you actually checked the accuracy of the meter using the sunny16 rule or such?
If you have an example to post with full EXIF....it will be easy to tell if you have an issue. Make sure it's not processed in any way but simply an OOC JPEG.
Not something reported here often. D7100 doesn't seem to be problematic regards exposure. Good Luck
dk76111
Junior MemberPosts: 45Gear list
Re: D7100 exposure accuracy?
You are about the 5th or 6th (estimate on my part) person I've seen report this.
I've found the opposite.  I've found that it overexposes based on what I'm used to.  This is purely judgemental.
For lack of a better term, everything is "brighter" than what came out of my D5000.  I've only had the 7100 for a little bit.  So I need to look at my metering.  I think I've got it on spot and that's why.  Aside from that, it's set to the default size (8 mm?).
Haven't looked at the histogram.  But as I said, it's a "feel" thing.
 dk76111's gear list:dk76111's gear list
Sony Alpha NEX-6 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm f/1.8G Sigma 50mm F1.4 EX DG HSM +4 more
mosswings
Veteran MemberPosts: 7,103Gear list
Are you using Matrix Metering or CW/Spot?  If you are comparing the exposure of the scene element under the focus point to that of an earlier Nikon, and you're in MM, you will notice that the D7100 gives slightly less weight to what's under the focus point - a trait common to all the upper-level Nikons. This can result in apparent under or over-exposure of the entire scene depending upon the relationship of the subject to the field.
Early users of the D7100 reported that it seemed to have somewhat higher highlight headroom, which generally means that the reference brightness for the meter has been moved down somewhat in the DR of the sensor, but this would be accounted for in the response curve. These initial observations have quieted down.
Are you shooting RAW or JPEG?
 mosswings's gear list:mosswings's gear list
Olympus XZ-1 Olympus Stylus 1 Nikon D90 Nikon D7100 Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR +5 more
Mako2011
Mako2011 MOD
spot
In reply to dk76111, Mar 4, 2014
Also, have you actully checked to see if the meter reading/mode is giving accuraty exposure results. You can use the Sunny 16 rule (on a sunny 16 day) to see if you get 1/200s in aperture priority at f16 and ISO 200.
The default (8mm) only applies to "center weighted" metering mode. Spot will always meter at 3.5mm in the center of the selected focus box, and is not affected by the b4 setting.
There are other ways to actually check the metering accuracy...not just the sunny 16 rule.
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
dk76111
Re: spot
In reply to Mako2011, Mar 4, 2014
Thanks for the tips Mako. I will check it out. Gonna have to wait until the weekend for the Sunny 16 test. And I shall now look up Metering tests.
It would appear that I have messed up my terms. Back to the manual I go. Apologies for creating any confusion in this thread.
I'm not complaining about the metering. Just seems different than what I was used to. Not saying it good/bad, right/ wrong.
I've been taking portraits of the kids (as best as possible). So while I find the face generally to be exposed properly, it's the surrounding that seem all that much more brighter. Who knows, maybe I had it on Matrix on the old camera and therefore the entire photo is underexposed. I dunno. (I am such a great help in diagnosing my "issue" aren't I?)
krikman
Regular MemberPosts: 381Gear list
It depends on lens, scene type, lighting and your photographic technique. If you feel it, just add exposure compensation temporarily.
sweetgum
Forum MemberPosts: 80Gear list
Torben
Yes.
I increased the exposure fine tune b5 (I think) by 4/6.
Very happy with results now. Histogram well balanced. That was the solution for me.
However, also take into consideration what others have contributed.
chary zp
Contributing MemberPosts: 995Gear list
Re: spot
"Sunny 16 day" is what?
... if you get 1/200 f16 iso200 shooting what exactly? Blue sky? Green gras? A red car standing in direct sun?
Mako2011
Mako2011 MOD
Zone 5
In reply to chary zp, Mar 5, 2014
Meter off any neutral tone (zone 5)....Clear north sky about 60 degrees up, Gray stone, Average weathered wood, Middle gray (18% reflectance), green grass. Palm of your hand should be +1 EC on a sunny 16 day so set -1 EC in camera and see if you get the 1/200s or so.
Mystery Guy
New MemberPosts: 15Gear list
In reply to Torben Laursen, Mar 5, 2014
Torben
I was recently trying to figure out why the pictures I'm taking with my D7100 (mostly with Matrix Metering) sometimes seemed darker than I expected (maybe by about 0.7 stops or so).
In playing around with some basic tests, I was seeing is variation in results just using the same exposure across the range of F-stops.
For example, with my 35mm 1.8G, if I start out using Manual mode and F22 (say at 1/6s) to set the exposure, and then just work up through the F-stops keeping the matching exposure (next F16 @ 1/13s, etc.), the actual results I'm getting seems to be as much as 1 F-stop different across the entire range (between lightest and darkest pictures).
So, just trying to take the same image with the same lighting would give a variation based on what F-stop was actually used (even though the camera meter always seemed to say that exposure was 'correct'.).
Is yours a constant amount of under exposure, or is it variable?
 Mystery Guy's gear list:Mystery Guy's gear list
Nikon D7100
Mako2011
Mako2011 MOD
off ?
In reply to Mystery Guy, Mar 5, 2014
f22 and 1/6s is 1/3 stop different from f16 1/13s
So minor miscalculation might be part of it
What increments is your meter set in?
Mystery Guy
Re: off ?
In reply to Mako2011, Mar 5, 2014
It's currently set to 1/3 stop increments (the default I believe). Maybe what I'm seeing is a metering issue.
For whatever reason, I often see variations where manually adding +0.7 exposure compensation makes things look better to me (in just general picture taking).
I don't know if the following is an expected difference or not, but I quickly took the following two pictures under the same light using Aperture priority and Matrix Metering.
The F22 one seems a shade darker, and if I open the .NEF in Adobe Camera Raw and increase the exposure by 0.7, the two images look a lot closer to each other to me (and have a more similar histogram).
I understand they shouldn't look exactly the same (they are at two very different apertures), but I was hoping that the apparent brightness would be closer. Maybe you can tell me if this is considered an expected amount of variation or not.
Thanks;
F22
F2.8
Nikon D7100
Mako2011
Mako2011 MOD
ADL ?
That's what I have mine set to as well...but I know it's not as precise as say the histogram but certainly gets as well in the ball park as +/- 1/3 is no biggie in post (as long as I don't clip something I want to keep).
Nothing wrong with that. Many add a global correction and it simply works. Ray Soares always set a -2/6 EV in his setup and I don't...And I honestly think our cameras were metering identically. There's, IMO, some honest subjectivity to what's the correct exposure.
These are indeed different and the same exposure. You didn't use liveview did you? You don't happen to have ADL set to "on" do you? That can account for some of the dif.
Open in ViewNX2 and see if the look just as different. Looks to me more like maybe the aperture isn't exactly f22 but way off....might be a simple lens issue. In this case it would be less than 1/8 of a stop if f22 was really f23. And still way small if f2.8 was really f2.6...so if an aperture issue it would have to be a big one.
I wonder if this might be ...long shot...an ACR issue with the brightness instruction set. Do you get same result shooting JPEG?
Thanks;
F22
F2.8
Mako2011
Mako2011 MOD
Also
Mystery Guy wrote:
F22
F2.8
Also (pulling at straws) might be a light issue in this case with cycles....try with flash and see what happens.
Mystery Guy
Re: Also
> You didn't use liveview did you? You don't happen to have ADL set to "on" do you?That can account for some of the dif.
ADL is off and I wasn't using Live-View.
In View NX2 the .JPG and .NEF looks almost identical with only a very small difference in the histograms between them. Opening the JPG in Photoshop CS 6 also looks the same.
Here's a new set of pictures with Native Light, Direct flash from an SB-700 , and Bounce Flash. This is with Matrix Metering, Aperture Priority, F22.
In this case, I think the ambient light one looks the best and the Bounce Flash is the darkest for some reason.
In general, I sometimes see great results, but I'm trying to figure out why sometimes things look so different despite the same frame composure.
P.S.: I just realized that at F22, 1/30s and the ambient light used, the flash modes report significant underexposure (in the camera meter display) since it appears to be determined to use 'TTL-BL' mode. So maybe that's what's up with the flash images.
It seems to me that being able to choose TTL only mode would be nice (without having to resort to spot metering).
Ambient
Direct Flash
Bounce
Nikon D7100
Mako2011
Mako2011 MOD
maybe
In reply to Mystery Guy, Mar 6, 2014
OK...throw that idea out
That's what I would expect. Opening the NEF in ACR will always look different from the ViewNX2 version or the OOC JPEG unless you tweak your picture controls. Hard to do consistently with ACR.
True...to get consistent flash power output (just for testing) you almost have to switch to manual flash mode.
Sort of...remember the purpose of TTL is to illuminate the subject the same regardless of background. With that in mind, it kind of makes sense to use Spot with TTL as we want to ignore the background. Matrix would cause the subject to get weighted differently and maybe defeat the purpose. Two schools of thought...no right or wrong IMO.
Ambient
Direct Flash
Bounce
jraa
Forum MemberPosts: 82Gear list
In reply to Torben Laursen, Mar 6, 2014
The DPR review (for this camera) in their Conclusion page under Image Quality stated that ..the matrix metering need some exposure compensating.... could at times return slightly darker results..when performing their review of the D7100.  This may be the same results your getting..Non the less, it did get a Gold rating from DPR..
 jraa's gear list:jraa's gear list
Fujifilm FinePix E900 Zoom Canon EOS 5D Canon EF 85mm f/1.8 USM Canon EF 16-35mm f/2.8L II USM Canon EF 50mm f/2.5 Macro
Buzz Lightyear
Regular MemberPosts: 433Gear list
In reply to jraa, Mar 9, 2014
I've had this problem before.  It's possible everyone has missed the correct fix . . .
There is a little button on top of your camera, just to the right and behind the shutter button.  It is a black and white square, with a + and - sign on it.  When pressed, you can adjust your exposure compensation to the right (+) or left (-) with your main command wheel.  When set at 0.0, it seems my exposures match perfectly with my metered values.  See if you setting has been modified to a negative value.
 Buzz Lightyear's gear list:Buzz Lightyear's gear list
Panasonic Lumix DMC-FZ1000 Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF Nikkor 50mm f/1.4D Tamron SP 24-70mm F2.8 Di VC USD +1 more
Leonard Shepherd
Forum ProPosts: 10,048Gear list
In reply to Torben Laursen, Mar 9, 2014
Often but not always perceptions of exposure problems are to do with personal preferences computer monitor brightness and so on.
The histogram can often help indicate if exposure is good and the monitor is not set up good for viewing digital images.
Your camera enables you to individual fine tune matrix, centre weighted and spot metering.
I often expose at minus a third of a stop because it helps post processing the way I do it before making a print.
Leonard Shepherd
We all aspire to take great photos but may always achieve this perhaps due to a lack of application, a lack of knowledge, or even a lack of talent.
The best photographers probably work quite hard at their photography.
Nikon D800 Nikon D7100 Nikon D810 Nikon D750 Nikon D7200 +22 more
