A7r 24-70 vs Nex-7 16-70 vs EM1 12-40
Started Mar 2, 2014 | Discussions
LTZ470
Forum ProPosts: 11,926Gear list
Mar 2, 2014
--Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
Olympus E-M1 Panasonic Lumix DMC-FZ50 Sony Alpha 7R Sony Alpha NEX-7
nyoneway
Junior MemberPosts: 38Gear list
Re: A7r 24-70 vs Nex-7 16-70 vs EM1 12-40
In reply to LTZ470, Mar 2, 2014
The Olympus is pretty impressive, sharp throughout the entire image.
 nyoneway's gear list:nyoneway's gear list
Sony RX100 Sony SLT-A99 Sony Alpha 7 Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +3 more
miro3
Senior MemberPosts: 2,326Gear list
In reply to nyoneway, Mar 2, 2014
yes, sell your A7r's and buy Olympus Em1 + 12-40!
viking79
Forum ProPosts: 14,103Gear list
I was just thinking the olympus looked oversharpened and noisy throughout the range without that much detail
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
nyoneway
In reply to viking79, Mar 2, 2014
This comparison is about lens not sensors. If you look at the Oly corner, it's much sharper than the Sony Zeiss.
PVCdroid
Senior MemberPosts: 3,229Gear list
Eric
Yes, silly over sharpened pics again from an MFT crusader. This is probably the 10th time in three months. The bad case of GAS should be professionally treated.
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony Alpha 7R Sony Alpha 7R II
Bart Hickman
Veteran MemberPosts: 7,256Gear list
Try comparing like sizes
It's amazing how a smaller image can trick us into thinking it's sharper.
I tried it both ways:  1. upsize the EM1 image so the scale was the same as the NEX-7 image.  2) downsize the NEX image to the same as the EM1 image.  In both comparisons, there's no question the NEX-7 image is more detailed and you can get significantly better sharpness out of it.  This applies across the frame.
I have to say the Oly image is a bit ratty-looking for a base iso image.  The NEX7 image is smooth and still looks smooth after sharpening it similarly to the Oly.  Perhaps it's being crippled by poor processing?
Bart
 Bart Hickman's gear list:Bart Hickman's gear list
Sony Alpha NEX-6 Sony a6000 Pentax smc FA 50mm F1.4 Sony E 55-210mm F4.5-6.3 OSS Sony E 10-18mm F4 OSS +10 more
robert1955
Senior MemberPosts: 2,411Gear list
How do we know?
Aren't the corners cropped off to show a 2:3 aspect ratio?
 robert1955's gear list:robert1955's gear list
Fujifilm X-T1
forpetessake
Senior MemberPosts: 4,775
Eric
I think Olympus looks worst here. Not only because oversharpened details stick out, but the colors are unsavory, and the 4/3 format doesn't work well for landscapes.
LTZ470
LTZ470 OP
In reply to forpetessake, Mar 2, 2014
Agreed not as well for landscapes as the larger sensors...but there are some folks with m43's landscapes that will make you double take!
I actually ended up with the 24-70 on accident, so why not try it?...In all fairness the sun came out on the A7r shot, just barely out on EM1 shot and was behind the clouds on the Nex-7 shot...I was surprised the 16-70 didn't do so well...
This "m43 crusader" owns, A7r, RX1, Nex-7, Nex-5N, 2 X RX100's...lol...
One EM1, and a Panasonic G3....
That makes one person in this thread a liar at minimum...lol...
The Oly 12-40 is larger in diameter in relationship to the Sony 16-70 and 24-70...thats why the corners are so much better...
But surprisingly if one cropped the 24-70 A7R shot it's not bad for landscapes, so basically same findings here as with other folks at 28mm it is very good...
FlickR Photostream:
LTZ470
LTZ470 OP
In reply to robert1955, Mar 2, 2014
robert1955 wrote:
How do we know?
No I left it in 4:3 aspect ratio...
FlickR Photostream:
LTZ470
LTZ470 OP
forpetessake wrote:
Eric
Yes, I shot EM1 in Natural Mode which doesn't saturate well...the Sony's were shot in Standard...BUT the color depth is one of the biggest challenges for m43, the Nex and the A7r have excellent color depth, especially the A7r, the colors are just excellent...
FlickR Photostream:
LTZ470
LTZ470 OP
Re: Try comparing like sizes
In reply to Bart Hickman, Mar 2, 2014
Bart
All jpegs, PP lightly...no the 16mp m43 sensor will never quite stay up with the APS-C and FF sensors, but it is surprisingly closer than most folks think or want to admit...just means that it is good enough for many situations, but I have found it is better for nature and close ups...the new Panny 42.5 f/1.2 is sharp wide open...very nice lens in m43 favor with OIS and EM1 with IBIS, the IBIS is actually better than the OIS...
FlickR Photostream:
LTZ470
LTZ470 OP
Eric
Didn't use any shaerpening on the Oly, only clarity at 24%...biggest difference I see is the rendition of the clouds which is important to me, both the Sony's rendered the clouds details and sky color better...
FlickR Photostream:
LTZ470
LTZ470 OP
It ios a valid point and really shows how Sony has to skimp on the corner performance to facilitate making a smaller diameter lens...which they are famous for...but I crop 99% of my photos usually so not a deal breaker for me...
FlickR Photostream:
LTZ470
LTZ470 OP
Yes, and it is good enough for most folks, the 12-40 is an expensive lens at $1000, but it is very sharp at f/2.8, where the Sony's are not that sharp at f/4 and really need f/8 to compete...
FlickR Photostream:
JunzInc
Regular MemberPosts: 404Gear list
Hi,
I am interested in knowing more about your unbiased opinions on the SEL 16-70 especially compared to the 12-40 from Olympus which you also own? Are they comparable except for may be the far corners of the image? I also wanted to know what you felt about the handling of the SEL16-70 on the NEX7?
I currently have a NEX5N and was thinking about getting the SEL1670 now and then later upgrading my camera to the A6000 when that becomes available.
Thanks in advance,
Regards
JM
 JunzInc's gear list:JunzInc's gear list
Olympus E-M1 Sony a6000 Olympus 12-40mm F2.8 Adobe Photoshop Lightroom 4 Corel PaintShop Pro X4
LTZ470
LTZ470 OP
In reply to JunzInc, Mar 2, 2014
JunzInc wrote:
Hi,
Thanks in advance,
Regards
JM
To be honest the 16-70 is an awesome sized well thought out zoom...it will work better on the 16mp sensors with less corner issues I think....I need to try it on the Nex-5N...I think it is WAY more than sufficient for the Nex-5N and perfect for it as well...
but the Nex-7 and the 16-70 are a great match up...it did not get the best light in these shots and can do much better except for sides and corners...it looks as if there is some color shift on the right hand side of the Nex-7 shot and that is the 24mp sensor at work...
For a Nex-5N I don't honestly think you could do any better than the SEL16-70 as far as zooms go...
EM1 and 12-40 are also awesome, but much larger and heavier, just the opposite of what folks that use Nex cameras are looking far...
The EM1 and 12-40 are even large for my liking, but they perform so well together it is a joy to shoot...only if they were a bit smaller package...
FlickR Photostream:
ttan98
Senior MemberPosts: 1,660
FlickR Photostream:
Panasonic and Olympus make some very nice(excellent) lenses for m4/3 and more importantly some of them are very affordable e.g. 45mm f1.8 and I can't say that much for Sony lenses some of them are too expensive and they aren't that great(good but not great) either, e.g. Zeiss 16-70 at $1000 each.
LTZ470
LTZ470 OP
FlickR Photostream:
