More pixels?
Started Mar 2, 2014 | Discussions
golf1982 Contributing Member • Posts: 744
More pixels?
Now we have 16, 24 and 36mp models, it seems that at these levels we have almost everyones needs covered. though this was also said by some at 6 and 12 mp. I just wondered if there are many people who feel they would benefit from more than 24 and 36 in an upgrade, and as these MP numbers keep on rising, or will they plateau, a bit like intel's MHZ bumps,
dwight3
dwight3 Senior Member • Posts: 2,377
Re: More pixels?
I now have 10, 16, and 36. I do not forsee the need for additional pixels.
But the future is uncertain, so I will not make any blanket statement to that effect. The one thing about life that is constant is that it changes.
 dwight3's gear list:dwight3's gear list
Nikon D200 Nikon D4 Nikon D800E Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED +8 more
Robin Casady Forum Pro • Posts: 12,898
Re: More pixels?
I think we have further to go. A D800E 36MP image will produce a 20x30" print at 240 ppi. That is without any cropping. Some prefer to print at 300 or 360 ppi.
My printer with print 24" roll paper. A 24x36" print would be only about 200 ppi.
Then there is cropping. Say your composition doesn't work best in a 2:3 frame, or your lens didn't have the reach you wanted. It would be nice to crop and still have the resolution to print large.
Nokia has a phone camera with 41 MP.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
cpkuntz
cpkuntz Senior Member • Posts: 1,003
Re: More pixels?
36 is great; you can print a 16" x 24" at 300 dpi. I wish Canon had a 36 megapixel body. Ultimately I'd like to be able to print 24" x 36" at 300 dpi with one shot instead of a stitch. So that's about 78 megapixels. Since I can't see myself ever printing a digital image larger than 24" x 36", I don't see myself ever needing more than 78. For larger prints I'd rather use a 4" x 5" rail camera.
78 megapixels for a 24mm x 36mm sensor isn't unrealistic, by the way.  The pixel dimensions would be 10800 x 7200, and the pixel pitch would be about 3.33 microns.  A lot of compact cameras have smaller pixels.
Lance B Forum Pro • Posts: 29,026
Re: More pixels?
I wuldn't be surprised to see the Mp's go higher. I think the next step will be 54Mp, maybe next year.
 Lance B's gear list:Lance B's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +16 more
Horshack Veteran Member • Posts: 5,803
More real pixels
Diminishing returns on lens acuity (at least at a reasonable cost, not Otus $$$) and technique portend a switch to non-bayer sensor technology as the path to achieving higher resolving ability.
Re: More real pixels
If they can do it, it sounds promising.
Nader Erfani Contributing Member • Posts: 590
Re: More pixels?
I would prefer more speed than more resolution
AlephNull Senior Member • Posts: 1,308
Re: More pixels?
Need it or not, there will be more pixels
It could be interesting to see if they come up with some interesting ways to use the more pixels, though - imagine a camera shooting 128Mpixel, then down-sampling to 32Mpixel - it's quite possible that you'd see increased sharpness and definition with such an approach. Of course, you'd have to expect one set of whiners complaining that they want access to the raw data, and others saying that no one needs that kind of tech...
They say you must take a thousand bad pictures to take one good one - I have mastered the bad pictures part!
 AlephNull's gear list:AlephNull's gear list
Sony RX100 II Nikon D810 Canon EOS 5DS
Alejandro Daz del Ro Fery
Alejandro Daz del Ro Fery Veteran Member • Posts: 3,735
Why not? ... Re: More pixels?
Why not? ... as improving soft, CPU, lenses and sensors, I'd like more pixels in a lighter tool.
Regards.
mgblack74
mgblack74 Senior Member • Posts: 1,658
DX seems to precede FX
The D7000's 16mp gave us the D800's 36 when up scaled. 10mp DX gave us 24 FX. 24mp DX is estimated to be 54 FX.  A month before the D800 was launched I scoffed at the idea, now I don't think I can do without one high mp body.  People will always have use for high and higher mp cameras. Once upon a time ago it was the peripheral issues around high mp (noise, storage) that people feared. But as mp count climbs, the supporting tech increases too. Storage gets cheaper, and if the D4s RAW small is any indication where things are headed, 54mp may yield a 13.5 mp small RAW file. So, as long as they keep pushing and people keep buying, mp are likely headed up still.
"You're guaranteed to miss 100% of the shots you don't take" - Wayne Gretzky
_______________________________
 mgblack74's gear list:mgblack74's gear list
Nikon D810 Nikon D750 Nikon PC-E Nikkor 45mm f/2.8D ED Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 70-200mm f/4G ED VR +6 more
mmmmmmmm Senior Member • Posts: 2,662
stop the pixel madness
We now have more than enough pixels!  Fortunately for the camera manufactures they know that all they have to do is come out with a "new" camera with more pixels and all the "newbies" will buy it thinking that their photography will improve.
I have printed 20X30 prints with a 6mp sensor that looks great.  The pixel peepers will get out their magnifying glasses and get about 4" from a print and say, "Gee, this print could be sharper!"
Why do you think that Nikon and Canon uses 24 or less pixels for their "professional" grade cameras?  Think about it!
This forum is more of a "gear" forum than a "photography" forum.  More emphasis is placed on the gear than the pictures it produces.
respectfully,
David Miller
 mmmmmmmm's gear list:mmmmmmmm's gear list
Nikon AF Nikkor 50mm f/1.4D
Rservello
Rservello Senior Member • Posts: 1,157
Re: More pixels?
More pixel just mean more cropability. Don't forget, the less pixels a sensor produces, the bigger the pixels. Bigger pixels produce cleaner images with less noise. Also, 36mp is about it for ff. Next res already exists in the form of medium format digital. Unless you are printing billboards, or cropping a 50mm like an 800mm, there is no point to anything above 12mp. I like 24 because I can crop really deep and still have a great image. 5mp is all the average print needs.
https://www.flickr.com/photos/49019071@N03/
http://www.imdb.com/name/nm2334596/
* Sensitive Internet User Disclaimer: All opinions are my own and are not meant to offend you or damage your precious beliefs.
 Rservello's gear list:Rservello's gear list
Panasonic Lumix DMC-LX100 Nikon D600 Nikon AF Nikkor 50mm f/1.8D Voigtlander 58mm F1.4 Nokton SL II Rokinon 85mm F1.4 +4 more
TOF guy MOD Forum Pro • Posts: 12,823
12 MP is plenty for most folks
5
The rest is more about marketing than anything else.
To answer your question expect the MP race to go on for nothing else than marketing reasons.
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon D810 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Sigma 150mm F2.8 EX DG OS Macro HSM +5 more
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 10,602
Re: More pixels?
If you make large prints more MP makes for more image resolution and more tonal separation.
If you do not either make large prints or crop heavily you do not need 36 MP.
As a rule of thumb upgrading MP gives more image resolution than upgrading lenses.
Leonard Shepherd
We all aspire to take great photos but may always achieve this perhaps due to a lack of application, a lack of knowledge, or even a lack of talent.
The best photographers probably work quite hard at their photography.
Nikon Coolpix P7700 Nikon D800 Nikon D7100 Nikon D810 Nikon D750 +24 more
bobn2
bobn2 Forum Pro • Posts: 42,433
Re: More pixels?
5
They will tend to rise. There is an ecology of fabrication technology amongst the big producers. Most of the money and R&D effort is in the tiny sensors for phonecams, and the competitive pressure is to improve those and increase the pixel counts. This needs new processes and new fabrication lines with finer geometry, which in turn means that the older lines get released for making bigger sensors. So, the end effect is that at each sensor size, the available geometry gets finer - which means that the optimum pixel size reduces. The other effect is that bigger sensors become more easily available, because they can make use of the older coarse geometry lines and there is not so much product that can be put through those lines, so, for instance, now Sony is making a 50MP medium format sensor for Phase 1.
I think the problem is that workflows don't seem to adapt to the new high resolution sensors. I workflow based around downsampling should be differently optimised to one based around upsampling.
Bob
larrywilson
larrywilson Veteran Member • Posts: 4,772
Re: stop the pixel madness
I think personally that the pixel thing is about selling cameras.  My camera has more pixels than yours so it is better ugh!!!!  From what I've seen the auto focus systems and frames per second need improvement over the amount of pixels that a camera has.  A 24 mp sensor can produce a 16 X 24 inch print easily.  Yes lots of mp's is good for cropping, but I think we depend on cropping too much these days where the subject is really too far away.  Get in as right in the camera as possible without cropping 100% as I have seen a lot with the 36 mp cameras.  Sharp images depend more on sharp focus than mega pixels.  I've worn out cameras getting the focus adjusted right.
Larry
 larrywilson's gear list:larrywilson's gear list
Nikon D810 Nikon D7200 Nikon AF-S Nikkor 500mm f/4G ED VR Carl Zeiss Makro-Planar T* 2/100 Carl Zeiss Distagon T* 2/25 +7 more
Rservello
Larry
Agree 100%. Seems the tendency to just point the camera in the general area of the subject and crop to compose later is too prevalent. I crop sometimes to get a more pleasing composition, but it never completely changes the image. Spend more time behind the lens and less behind the computer and you don't need high mp.
rubank Contributing Member • Posts: 835
Re: More pixels?
I certainly wouldn´t mind more pixels. So far, everything has gotten better with smaller pixels.
I have been a RAW only shooter for years, since I want the best possible output, but with the D800 I have lately come to have new thoughts on in-camera JPG:s.
For smaller publications, web and social media use the in-camera medium or small JPG:s make a lot of sense; they´re actually quite good (compared to what I was used to with lesser (MP) cameras).
These files are small enough to send via WiFi or mail.
My guess is, that for ordinary newpaper use there is little use for 36 or more MP RAW files and that the smaller JPG:s are good enough (thanks to the high amount of data they´re rendered from).
Rservello
Re: More pixels?
My guess is, that for ordinary newpaper use there is little use for 36 or more MP RAW files and that the smaller JPG:s are good enough.
You're still better off shooting raw and then processing jpegs in camera as needed.
