HELP!!! K3 misbehAving OR I may be confused
Started Mar 1, 2014 | Discussions
breeze_of_wind
breeze_of_wind Senior Member • Posts: 1,196
Here is the problem: For whatever reason only the GREEN MODE seems to be working on my camera
All other modes fail. Sometimes I get a single good image, other times none at all in a set of shots--
Images 1-3 taken with GREEN MODE -- they are OK
Images 4-6 Taken with TAV (I tried TV and AV with the same poor results) -- Auto focus mode ( I have tried AFS AFC and AFA -- makes no difference);
AF active area 27 points (also tried 7 points and spot -- makes no difference)
Shot with JPEG, L, and ***
PLEASE help, just arrived in Thailand for a two week vacation
JOHN
The Three GREEN Mode images follow first
HERE ARE THE THREE TAV IMAGES
 breeze_of_wind's gear list:breeze_of_wind's gear list
Pentax K20D Pentax K-5 Pentax K-3 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +9 more
Wallace Ross
Wallace Ross Senior Member • Posts: 2,073
Re: HELP!!! K3 misbehAving OR I may be confused
It looks like you have some sort of digital filter applied like X-pro and that is disabled when in the green mode.  Try looking for that
MightyMike Forum Pro • Posts: 34,531
8
In TAV you set the aperture and shutter speed and the auto ISO completes the exposure... however for the shutter speed and aperture you've chosen the ISO can't go low enough to expose properly and you get overexposure...
Therefore F8.0, 1/1000th sec and ISO200 in green mode exposes right, F10.0 1/200th sec and ISO100 in TAV is 2/3rds of a stop overexposed if i did my math right. if you leave the shutter speed and aperture alone you'd need ISO64 to get the exposure right.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
brandrx Forum Pro • Posts: 28,337
+1
I agree with MightyMike.
Ron
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
+1
Ron
Also check your ISO setting (Auto or normal) in Av and Tv just to be sure its not whats helping cause the problem
Mike from Canada
ozdean
ozdean Forum Pro • Posts: 22,999
Ditto to the others - Overexposure - Check EV comp isn't on or change Tv,  Av or filters.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-50 Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 70mm F2.4 AL Limited +9 more
kikivrany Veteran Member • Posts: 3,397
Hello breeze_of_wind
It's like MightyMike wrote, your pictures are overexposed in the TAv mode.
normally, a camera like my K5, give you a warning : the LCD indicator start to blink.
If this don't happened:
The green Mode do overwrite our setting for the EV and metering mode -> check if you have in the other modes (like TAv, Av...) a EV setting dialled in or if you use a spot metering mode.
best regards  kikivrany
carpe noctem
13thBagel
13thBagel Senior Member • Posts: 1,115
Consider using...
...Sv mode (controls ISO) for a while. Let the camera set the shutter speed and aperture. Once you feel comfortable with things, experiment with the other mode settings (P mode, then TAV, etc.)
Cheers... M
Be the kind of person chance finds easy to help.
 13thBagel's gear list:13thBagel's gear list
Pentax Q7 Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax 08 Wide Zoom HD Pentax DA AF 1.4X AW Rear Converter
brecklundin Senior Member • Posts: 1,995
Does anyone else think the WB is not right?
I agree there are other settings maybe off, but I see the WB is not right.  Something is buggering the color and not knowing what Pentax does to JPG's I sense that even though that over all there is no apparent colorcast, something about the colors in general feel like it's more than a filter.  My thought was WB is really reading things way wrong.
So maybe a CTE WB shot or just AWB?  Then some test shots?  And of course the color mode (Vibrant, Natural, muted, etc...) will have an effect too.  I say reset the whole camera to ground zero and shoot a shot in manual in RAW+JPG and see how the shots look side by side.
But the OP can look at it this way, you got some interesting non-mainstream results there...take the credit shot shooting "outside the box" never admit to shooting inside the green-box.
awaldram
awaldram Forum Pro • Posts: 12,316
In addition to what everyone else has said
The camera would have been flashing the 100 in the iso auto window screaming you had set an aperture and shutter that did not allow an exposure solution.
In short if the camera flashes any settings at you, then you have missed something.
ensure you do not have aperture shutter or iso flashing before you attempt to capture an image.
If you ignore the camera then your results will be as you posted.
Your camera is behaving impeccably, But your ignoring it's polite warnings
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Pentax Q7 Pentax K-3 Pentax smc DA* 55mm F1.4 SDM +15 more
audiobomber
audiobomber Veteran Member • Posts: 5,298
I suggest you go into the menu pages and reset the Set-Up and Custom Settings menu settings to defaults.
Dan
 audiobomber's gear list:audiobomber's gear list
Pentax K-3 Sony a6000 Pentax K20D Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +17 more
steelski Senior Member • Posts: 2,552
I have a strong case for the answer!!! look here!!!
I can not believe that nobody knows what the result the OP is getting is from. Even Mike is wrong....
The answer........ Its the cross process settings. go to your quick menu and disable the option.
Does this look familiar.....
http://www.ephotozine.com/articles/pentax-k-x-hands-on-preview-12172/images/pentax_kx_cross1.jpg
awaldram
Re: I have a strong case for the answer!!! look here!!!
He may well have filters enabled but the main issue is overexposure
besides the k3 does not have cross process as a locked in filter options are
extract color, toy,retro,high key,vignet,invert,unicolor and boldbw
the auto shots are at around EV16
the tav shot is around EV14
Even without metering using Sunny 16 (bright sun in sand) then EV should be around ev16
Giving an exposure = 1/1000 F8 @iso100
yet he shot 1/200 f8 @iso100
The image is over exposed by about 1 stop
Wallace Ross
Nobody?  Sometimes I do feel invisible here.
Anyway if you look at the  white railing you can see that there is a digital effect being added to the image and it changes between images so it's highly likely it's the x-pro filter.
solarider Veteran Member • Posts: 4,382
A screaming camera
One more for the DPreview over the top-isms list. Would this one be in the top 100?
The intuitive mind is a sacred gift, the rational mind is a faithful servant.
We have created a society that honors the servant and has forgotten the gift. - Albert Einstein
________________
Science... became Scientism, which means it didn't just pursue its own truths, it aggressively denied that there were any other truths at all... Ken Wilbur
__________
Coincidence is God's way of remaining anonymous - Albert Einstein
rogerstpierre Veteran Member • Posts: 3,898
I think that you may be confused. As pointed out by others, it seems that your setup in the example provided, exceeds the lower ISO limit. The exposure differs in each, yet, the settings are constant. The only way this could happen is if you selected both speed and aperture, and the camera is setting the aperture, which bottomed out at 100 while the light is changing, and exceeds what the camera can accommodate (i.e. it needed to set the ISO to less than 100) for proper exposure.
From your comments, I get the impression that you may have bought your K-3 just before your trip, perhaps thinking that a good camera will inevitably give you better pictures on this obviously special trip. You (speculating) may have never used a DSLR before, and may or may not have even read the manual on the plane on your way there.
My recommendation, use the green mode for any important pictures while on this trip, and use your spare time to learn some fundamentals of photo technique and to experiment with your new tool. It is quite normal to have mixed result at first, and can be daunting for some (more is not always better), but it will get better with some basic knowledge of what it is you're doing rather that randomly picking up some settings.
Good luck, and let us know how it goes.
Roger
 rogerstpierre's gear list:rogerstpierre's gear list
Pentax smc DA 21mm F3.2 AL Limited Pentax Optio 33WR Samsung TL500 Pentax K10D Pentax K-01 +18 more
Greyser Veteran Member • Posts: 4,158
My K-5, K-5IIs, and K-3 always overexposure in TAv. To compensate I use very aggressive -Ev compensation (sometimes down to -1.5...-2 in very bright light) depending on current conditions.
 Greyser's gear list:Greyser's gear list
Pentax K-5 Pentax K-01 Pentax K-5 IIs Pentax K-3
sorry but you assume too much. the green mode photo looks fine at iso200 f8 1/1000
this is only 1/2 stop difference ish from iso100 f10 1/200.
hmmmm. you have a point. read your post and knew you refered to the folters....... and now i understand what you mean by x-pros.
sorry.
audiobomber
My K20D and K-3 do not do this. I have no idea why TAv shjould expose differently than Av or Tv mode.
Dan
