28-70 Kit vs 24-70 on A7
Started Mar 1, 2014 | Photos
Jacimi New Member • Posts: 19
I thought I'd share some comparison pics I took with each of these lenses. All are handheld with OSS on. Focus is in center for all. I shot in A priority and some of the shutter speeds are different so difference in exposure. I'm very happy with the results and IQ improvement over the kit lens.  I think I have a good copy of the 24-70 but would be interested in comments.
24-70 34mm F4.5
Kit lens 34mm F4.5
24-70 at 70mm F5.6
Kit Lens at 70mm F5.6
Kit lens at 28mm F4
24-70 at 27mm F4
 Jacimi's gear list:Jacimi's gear list
Sony Alpha 7 Sony Alpha NEX-5N Sony FE 24-70mm F4 OSS Sony E 18-200mm F3.5-6.3 OSS
Comment & critique:
Sony Alpha 7
(unknown member) Veteran Member • Posts: 9,509
Re: 28-70 Kit vs 24-70 on A7
24-70 34mm F4.5
Kit lens 34mm F4.5
24-70 at 70mm F5.6
Kit lens at 28mm F4
24-70 at 27mm F4
Kit lens seems to be holding up quite well in comparison.....especially on a IQ per dollar basis.
I use manual focus lenses with my A7 but the kit lens is handy enough to have and IQ is useable for all but the most demanding uses I think.
 neil holmes's gear list:neil holmes's gear list
Panasonic Lumix DMC-GX7 Sony Alpha 7S Pentax K-x Canon TS-E 24mm f/3.5L II Sony FE 28-70mm F3.5-5.6 OSS +8 more
Mar
Mar Senior Member • Posts: 1,263
Thank you for sharing those results;actually i think that this picture does not show the optical differences between the two lenses. It's a pic that you can take  with both lenses. it shows for sure that the 28-70 is a good kit lens. But the zeiss I think need other considerations,don't you think?
Maurizio
 Mar's gear list:Mar's gear list
Nikon D3 Sony Alpha NEX-5 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +3 more
Jun2 Senior Member • Posts: 2,235
The corner is much better with 24-70.  The corner sharpness is very good with 24-70.
 Jun2's gear list:Jun2's gear list
Sony a6000 Sony a5000 Sony E 35mm F1.8 OSS Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
viking79
viking79 Forum Pro • Posts: 14,137
With my copy, I am not impressed with the corner sharpness of the 24-70mm f/4 at all. It seems decent enough by 50mm, but don't think it is much different than the 28-70mm overall.  The issue is, my good copy of the 28-70mm I had to send back to return a broken A7, and my current copy is maybe a bit average.
I need to check on the A7, but on the A7R it has pretty strong green cast to the corners/edges and soft corners at most settings before 50mm or so.  Doing side by side with my current 28-70mm and it is better, but still feels like a kit lens.  I think 28-70mm on A7 is about like 24-70mm on A7R.  The build quality of the 24-70mm f/4 is very nice though.
Eric
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
viking79
Eric
Looking more at the green cast in the corners, it is aggravated by uncorrected vignetting, even with vignetting correction on, quite a lot remains, so if I manually correct the lens for vignetting, the green cast isn't very noticeable.  In Lightroom I can apply a radial filter that increases temperature in the corners a bit and it nicely corrects this.
I hope the Lightroom profile for the 24-70mm is available soon, it would make me like the lens a lot more.  I can't even test it at 70mm yet since the distortion is too high for my chart...
Eric
Eric
My comments was just based on pictures in the original post.  I don't have the lenses or A7 or A7r.
Stu 5 Veteran Member • Posts: 3,277
It's much better than the 28-70 but it is still not that amazing on the wide end.
Eric
Eric
If your not happy with it why not consider swapping it for another copy. Is it still the same with I.S switched off?
Michael Everett Senior Member • Posts: 1,916
I see a considerable difference between the two.  The 24-70 clearly has more punch overall, even viewed at screen level and not 1:1.  Look at the chain link fence in the first photographs.  The 24-70 looks quite a bit sharper.  Whether it is worth the extra difference in cost is another issue.
Michael
ianbrown Senior Member • Posts: 1,969
I got this lens yesterday and I am resisting comparing with the kit lens as I don't expect a huge difference and therefore won't be disappointed, that said I think curiosity will get the better of me!
I think often the differences in lenses are never as great as we expect, for example I had the Canon 24-70 f2.8 MKII and compared it to the Tamron with VC which was less than half the price and for most of the time the IQ was much the same, unless you pixel peep.
My take is, just knowing you have the best available and the build is better, and you get 4mm wider for me is worth the extra, particularly with the  7R.
I am a zoom guy and therefore I have no options, however if a 24mm prime arrives then it may be a different storey for some people.
Either lens will take good images, and both will rely on PP to maximise the end result.
Ian
Hawaii-geek Veteran Member • Posts: 7,977
24-70mm f4 OSS FE, see the Diff in the Fence - wood and chain
HG
Kit lens at 28mm F4
24-70 at 27mm F4
 Hawaii-geek's gear list:Hawaii-geek's gear list
Sony RX1 Nikon D700 Nikon D800 Sony SLT-A99 Sony Alpha 7R +19 more
npires
npires Senior Member • Posts: 1,545
Re: 24-70mm f4 OSS FE, see the Diff in the Fence - wood and chain
HG
Kit lens at 28mm F4
24-70 at 27mm F4
Thanks! To my eyes there's a massive difference. The kit lens looks a bit blurry and smudged on the left side where as the 24-70 is actually pretty decent on the far left side.
 npires's gear list:npires's gear list
Sony Cyber-shot DSC-RX100 III Sony Alpha NEX-5 Sony Alpha 7 II Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +3 more
KwhyChang Veteran Member • Posts: 3,527
Thanks for posting this.
It's not that I don't like the results. It's just for now the 24-70 is not worth $900 more to me than my kit lens. I might wait for a while and get one used.
In any event, my go to lens for a zoom is the Canon 17-40. The kit lens is fine for now, and if I need it, the EF 24-105, although slower and heavier, is a much better range.
Dave
 KwhyChang's gear list:KwhyChang's gear list
Nikon Coolpix P900 Sony Cyber-shot DSC-RX100 III Sony Alpha 7
