Can FF lenses be used on ASPC cameras?
Started Feb 26, 2014 | Discussions
Absence Of Faith
Absence Of Faith Forum Member • Posts: 50
Can FE lenses be used on the current Nexes? If so, are there any drawbacks to using them?
Thanks.
 Absence Of Faith's gear list:Absence Of Faith's gear list
Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital 25mm F1.8
nevercat
nevercat Senior Member • Posts: 3,193
Re: Can FF lenses be used on ASPC cameras?
Thanks.
FF lenses can be used on every E-mount camera, it does not matter if it is a camera with a FF sensor or one with a APS sized sensor.
The FE lenses (FF E-mount lenses work without adapter and, as far as I know without any real drawbacks IQ, or feature wise.
The only drawbacks for FF lenses are Size and Price (the will be larger and more expensive then APS lenses). So when size and /or priceis realy important go for APS lenses, otherwise you could buy both, when you buy FE lenses you will be able to use them on a FF E-mount camera and use the whole sensor, not only a crop part of it
NikB747
NikB747 Regular Member • Posts: 127
Yes they can, I don't think there are any technical drawbacks.
nik
 NikB747's gear list:NikB747's gear list
Sony Alpha NEX-5N Sony Alpha NEX-6 Sony Alpha 7R Sony E 18-55mm F3.5-5.6 OSS Sony E 30mm F3.5 Macro +12 more
eths
eths Contributing Member • Posts: 775
Yes (nt)
 eths's gear list:eths's gear list
Sony Alpha NEX-7 Nikon D600 Sony Alpha 7R Nikon AF-S Nikkor 16-35mm F4G ED VR Sony E 16mm F2.8 Pancake +18 more
MrT-Man
MrT-Man Contributing Member • Posts: 915
Re: Yes (nt)
I'm using the 55 FE with my NEX-7 and have gotten great results.
Actually I wouldn't even say that size is always a drawback with full-frame lenses, if you look at the 35 FE and 55 FE for example. The 55 FE and it's only a touch bigger than the APS-C SEL50, despite the fact they're both f/1.8 lenses.
 MrT-Man's gear list:MrT-Man's gear list
Sony Alpha 7R II Carl Zeiss Touit 2.8/12 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 35mm F1.4 +2 more
EinsteinsGhost
Thanks.
Yes. Any E-mount lens (FE or E) can be used on any E-mount body. When using a FF lens on APSc as you intend to, the camera will use only the middle part of the FF lens for imaging.
For example, you could use either E 35/1.8 OSS or FE 35/2.8 ZA on a NEX-6. Both will provide the same field of view. But since FE lens is designed to create an image circle two times larger than an E lens, you will be using only the middle part of the larger image circle from an FE lens and the same size as the E lens.
Conversely, an E lens can also be used on E-mount FE (FF) bodies. However, since lenses designated as "E" (E 35/1.8 OSS for example) create a smaller image circle, you might want to use the FF with APSc setting on.
The drawbacks to using FE lenses on APSc bodies? As of now, the FE lenses are only higher end and that includes absence of optical stabilization and higher price tag. You can overlook this if you expect to move up to FF in the foreseeable future otherwise you can stay with any of the E lenses.
Although, if you are shopping for something like 70-200/4, then FE is the logical option (the lens will work like 105-300mm equiv on APSc bodies giving you more reach than it would on FF).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
EinsteinsGhost
Yep
And, FE 35 is even smaller and lighter than E 35 albeit it helps that it is a stop slower at max aperture. But then, on FF it provides the same FOV and DOF as E 24 does on APSc but at half the length.
nevercat
Re: Yep
Yes, but the 55mm has no OIS and the 50mm has.
And it has no OIS, makes it smaller too...
The design of the 35 2.8 FF lens is totaly different than that of the 24mm f1.8 lens, making size comparisons between FF and APS not fair.
EinsteinsGhost
Re: Yep
They are both Sonnars and provide the same application/function on respective formats in terms of DOF and FOV. But, ofcourse, not interchangeable on the same format.
Absence Of Faith
Absence Of Faith OP Forum Member • Posts: 50
Ahh, thanks guys. I didn't know stabilization is an absent feature of FE lenses. I plan to stick with APS-C lenses for now. In fact, I'm keen on purchasing the E 35\1.8 in the near future. I was just worried that Sony will focus mainly on FF glass in the future and hence my question.
bigley Ling
bigley Ling Senior Member • Posts: 2,862
Thanks.
plus when using FE glass on an APS-C camera, you are gaining a heavier lens, yet you are only the center portion of the lens.
Absence Of Faith
Thanks.
Are there disadvantages when using only the center portion of the lens?
EinsteinsGhost
Thanks.
Actually, no. It is usually an advantage since lenses are optically at their best in the center. So, a FF lens on APSc will mostly use that part of the lens (think FF lenses as being overengineered for crop bodies).
The disadvantage could be cost as FF sensors are typically designed to a higher spec. But if you were shopping for an APSc prime for a Canon DSLR, for example, I doubt you will find even one APSc lens. Nikon has one (35/1.8).
Joe Ogiba
Joe Ogiba Veteran Member • Posts: 3,539
Wow, the misinformation is out of hand about OSS in FE lenses. I use the A7 28-70 FE OSS kit lens on my full frame VG900 and OSS works great on it. The 24-70mm FE OSS is another one with OSS along with the 70-200 FE OSS.
28-70mm FE OSS on FF VG900
 Joe Ogiba's gear list:Joe Ogiba's gear list
Sony Alpha 7R Panasonic Lumix DMC-GH4 Samsung NX1 Sony Alpha a6300
EinsteinsGhost
The high end prime lenses (Zeiss) can be expected to not to have stabilization. I don't expect 85mm lens to have it either.
However, the zoom lenses will have it, as all E-mount zoom lenses do. But of course I don't think you would be considering normal or ultra wide FF zooms.
bigley Ling
Thanks.
As EinsteinsGhost said, by using only the center portion of the lens, you are essentially using the sharpest and best parts of the lens, but I iterate the idea of carrying extra glass comes at increased cost, plus added weight.
Brian_Smith
Brian_Smith Senior Member • Posts: 2,479
yes
no
