Need advice: Panny 14-45, 12-35, or 14-140 for travel lens.
Started Feb 25, 2014 | Discussions
Len_Gee
Len_Gee Veteran Member • Posts: 9,061
Hello,
I'm thinking of adding one of the following lenses for current GX1 kit.  A lens for general travel, cruises, walk around photography.  Not a pro just a weekend snapper.
Considering one of the following:
  • 14-45 (not expensive, slow f3.5-f5.6, older design)
  • 12-35 (expensive but "pro quality" f2.8)
  • 14-140 ( one lens does all, but reportedly afflicted with "shutter shock")
What lens would you suggest?
I'm  leaning heavily towards either 14-45 or 12-35.
Just not sure if 12-35 @ $1000 is that much  better than 14-45 @$300.  Is it?
FWIW, I have 7-14, and 25 PanLeica, and plan to keep both, adding Oly 45 in future.
Also planning to add GX7 or M10 body in future.   Want to carry 2 MFT cameras when traveling to avoid lens swapping as much as I can.
Considered GM1 kit, but my hands are XL.
Thanks for any practical as well as technical advice.
 Len_Gee's gear list:Len_Gee's gear list
Sony RX100 Fujifilm X100T Panasonic Lumix DMC-GX7 Olympus PEN-F Panasonic Lumix G Vario 7-14mm F4 ASPH +5 more
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7
James Pilcher Veteran Member • Posts: 8,464
the most versatile lens
I will always take speed over a slower "versatile" lens. I find that a lens that works easily in a larger range of lighting conditions is the real winner in versatility.
Go with the Lumix 12-35mm or Olympus 12-40mm. You get the best overall image quality with these lenses too.
Jim Pilcher
Summit County, Colorado, USA
 James Pilcher's gear list:James Pilcher's gear list
Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Fujifilm X70 Olympus PEN-F +7 more
honeyiscool
honeyiscool Senior Member • Posts: 1,374
Re: Need advice: Panny 14-45, 12-35, or 14-140 for travel lens.
So much happens after sunset that f/5.6 can often prove useless in so many settings. Go with f/2.8.
 honeyiscool's gear list:honeyiscool's gear list
Panasonic Lumix DMC-GX85 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 12-40mm F2.8 +2 more
jeffharris
jeffharris Veteran Member • Posts: 6,413
After sunset, even an f2.8 will struggle.
Go for an f1.4, or faster, prime to augment whatever convenience lens… I mean… zoom lens one might choose.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +27 more
honeyiscool
In my experience, as long you're willing to push it to ISO 6400 (and you have to be, at night), f/2.8 is usually enough to take people shots at 1/40 or faster if you have some light (street light, etc.). At the same setting, f/5.6 is 1/10.
Chez Wimpy
Chez Wimpy Veteran Member • Posts: 8,855
Stopped down, no... but indoors, sure.  The focal range is actually superior on the 14-45 because you can turn the camera and stitch for wider FOV (with the added benefit of more pixels than a single shot at 12mm), while reach is limited by the max focal length on hand.  Given this versatility and IQ across the full range, I wouldn't trade my 14-45 for the 12-35 for landscapes (not for even money) though there have been rare occasions hiking back after sunset where f2.8 vs f5.6 does make the difference between a keeper and noisy(-or-blurry) mess.  Optically the 14-45 is as good as kit lenses get, and though I print very large (A1+) the results are at least as good as I have ever gotten from a zoom (Canon L-zooms on FF included).  The Olympus 12-40 is tempting, but it is larger, and given the cost I am not sure I would ever get my money's worth since I habitually shoot in the f5.6-f8 range.
-CW
 Chez Wimpy's gear list:Chez Wimpy's gear list
Sigma DP1 Canon EOS 5D Mark II Canon EOS 20D Panasonic Lumix DMC-G1 Canon EOS 550D +23 more
richarddd
richarddd Senior Member • Posts: 2,982
Are you likely to want to shoot longer than 45mm?
Are you likely to shoot much in dim light or want somewhat shallower DOF? If so, do you believe your 25 and future 45 would suffice?
It really depends on your photo needs. From a recent poll I did here on travel kits, different people make different choices. http://www.dpreview.com/forums/thread/3625142
 richarddd's gear list:richarddd's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
drtmw
drtmw Regular Member • Posts: 389
Hi,
It's not clear what you want to carry, one lens or two? For me, I found that I really used the 12 mm end of my 12-35 last year in Europe (indoors in churches, and outdoors for wider scenics).  Nearly 1/2 of my shots with this lens were at the wide end.  I would not travel without it. But you do have a 7-14 so if you carry that you have the wide end covered.
I had a 14-45 and it was very nice but like my 12-35 better. Now I carry a GX7 the 12-35, a 20 f 1.7 for stealth and indoor uses, and the 35-100.  I really don't like to change lenses much so this is the most I'll carry.
good luck,
Tom
tjuster1 Senior Member • Posts: 1,680
Any reason you're not considering the new Panasonic 12-32mm? Sure, it's not as fast as the 12-35mm, but so far it seems every bit the equal of the well-regarded 14-45mm, except it's a little wider and a little shorter, a trade-off I'd gladly make. And it's TINY!! I think it would be a perfect match for the GX1.
Also has the latest greatest OIS, which seems to work well too.
LMNCT Veteran Member • Posts: 3,892
The 12-35 f2.8 would be a good choice.  Your GX1 does not have internal stabilization, but the 2-35 has excellent in-lens stabilization.  You might want to pick up a fast prime as well.
 LMNCT's gear list:LMNCT's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH +18 more
eques Senior Member • Posts: 2,195
Taking into account what you have and what you plan to get, I personally would get the 45 and just use the 7-14, the 25 and the 45 for travel. This is a beautiful 3 lens set, and with a close up filter is good for everything except wildlife (birds, safaris, ...)
I have the 14-45 and like it, the 12-32 seems to be even better, I have read; the 12-35 is just a bit better IQ wise and obviously faster.
Peter
 eques's gear list:eques's gear list
Ricoh GR Panasonic Lumix DMC-GX7 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
jeffharris
Even with the improved higher ISO performance of the latest generation M4/3 cameras, ISO6400 doesn't really cut it because of increased amounts of noise. ISO3200 is okay, but not that great. I rarely shoot above ISO800 or ISO1250 even with my GX7, but then, I use fast primes.
jeffharris
I tend to agree, except for one longer lens, like a 75mm.
On my last few trips my basic kit was… 7-14mm, 17.5mm and 42.5mm. Even though I carried a couple other lenses… 12mm T1.6 and a 105mm f2.8 macro (doubles as telephoto)… the majority of my shooting was with those 3 lenses.
Ulric Senior Member • Posts: 3,580
Is your gear list up to date, i.e. are the Pansonic 7-14 and 25 the only MFT lenses you have?
If you're going to use this new aquisition alone on the GX7, i.e. unaccompanied by other lenses, then f/2.8 is just barely sufficient and slower zooms need not apply. Otherwise, any zoom plus the fast prime might do.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
Jim T Veteran Member • Posts: 4,285
Not what most of the others are saying but I'd get the 14-140.  You have the wide angle 7-14 covered and the PL25 should give you the low light prime performance.  Only thing missing is the long end.  The 14-140 is IMO a fine lens with a very versatile range for the regular use needed for travel.  If you get the Oly45 later that will add another option for portrait shooting if that's what your after and the lower aperture.
 Jim T's gear list:Jim T's gear list
Sony Cyber-shot DSC-TX10 Olympus Tough TG-1 iHS Panasonic Lumix DMC-GH1 Olympus PEN E-PL2 Panasonic Lumix DMC-GF3 +12 more
Lumixdude Senior Member • Posts: 2,782
In my experience this is bad technique... If you were shooting with a film SLR you wouldn't all of a sudden come to the conclusion that you're going to stop shooting in the middle of a roll and load ISO6400 film. You would attach a faster lens... ISO is not a real solution... Although maybe I'm just cranky because I actually remember how to shoot with a film SLR.
To answer the question... you have a 14 to 28mm lens equivalent already, so grab the 14-140 and spend the rest on a cheap prime like the 14mm F/1.8 if you need to shoot in low light.
 Lumixdude's gear list:Lumixdude's gear list
Olympus PEN E-PL5 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital ED 12mm 1:2 Apple iPhone 4 +2 more
a13 Regular Member • Posts: 171
It's called progress. Limitations of the past are hardly a good reason to not take advantage of options you do have today. That's like a compact camera shooter refusing to take multiple lenses because "I'm used to having to find other solutions" and not solving whatever problem you have with the smartest/easiest/most effective solution you can employ.
I still see no point
You get the most out of your camera by using an appropriate lens, not using ISO unnecessarily. In the 1% of shots you can't get with a fast enough lens then boost your ISO... not until... Particularly with Micro Four Thirds where using higher ISO figures than 200 has obvious effects on your shots. I'm not saying its bad... it's just obvious and oneof the main reasons for not shooting film is to reduce unnecessary noise and image degradation...
Fredrik Glckner Veteran Member • Posts: 3,347
For travel, I would definitively go for the 14-140mm lens.
http://m43photo.blogspot.com/2013/08/lumix-g-hd-14-140mm-f35-56-review.html
I have used this lens also at dusk and even when it is pretty much pitch dark. I have done that by pushing the ISO up, and also supporting the camera against something. If you need to capture moving subjects, though, that can be more difficult.
I guess it comes down to whether or not you like to use the tele end. Some people just hate tele images, and for those, the 12-35mm lens makes much more sense, of course.
Personally, I like the tele end, which is why I often pick up the 14-140mm lens over the 12-35mm lens.
D200_4me Veteran Member • Posts: 3,875
I only had the 14-140 and....
I was happy with many images I took while traveling. I had the older 14-140 on the GH2 back when I had that camera. That's the only used I used with the GH2 and I think the photos speak for themselves:
http://www.openbloom.com/CAMERAGEAR/Panasonic-Lumix-GH2/
If I were in your position, I would take the 14-140 (new version) over the much shorter and only mildly 'faster' (aperture) 12-35.  I want to get the shot, period.  I don't want to have the 12-35 and regret not having the lens that has the reach to get the shot I just missed.  Go for versatility, not limitations simply because others think you need the very best optical performance, even if it means you miss a lot of shots or framing that you want.
 D200_4me's gear list:D200_4me's gear list
Fujifilm FinePix X100 Nikon Df Sony a6000 Nikon D750 Nikon AF Nikkor 50mm f/1.4D +6 more
