Cannon Powershot D30 -- Been waiting 25 Years for this!!!
Started Feb 25, 2014 | Discussions
karen8888 New Member • Posts: 1
Finally, a caseless underwater camera that I can take on all my dives - soooo excited!!  Going diving in 2 weeks -- wish I could get my hands on one today!
Would have liked to try out the previous D20 - but 33 feet (why cannon -- so random)  Dives are usually 45 and 85 ===>  33' just doesn't cut it.
Anyone else feel the same??
Canon PowerShot D20 Canon PowerShot D30
rpm40 Senior Member • Posts: 2,178
Re: Cannon Powershot D30 -- Been waiting 25 Years for this!!!
You could check out the Olympus TG2 and the Pentax WG series as well, they're both considered pretty decent tough compacts, and they're rated to 45 feet. I haven't heard as many good things about the Nikon version but that goes to 60 feet.
(unknown member) Senior Member • Posts: 5,590
At 33ft the pressure is about 29PSI.  At 85ft that increases to about 52PSI.  The challenges of designing a camera to withstand the latter are considerable and the resulting device and its seals would have to be considerably strengthened and as a result be heavier and more expensive.  This perhaps helps explain why serious underwater photography is usually done with specialist housings.
Ken G.
Ken G. Veteran Member • Posts: 5,601
I own the Nikon AW110.  I compared it to the Olympus TG2 and found that the Nikon did a better job of handling noise reduction.  It seems that all of these 'tough' waterproof cameras over-process for noise, and wind up with one degree or another of the 'impressionist' look when pixel-peeping.  I've only had the Nikon on 1 vacation, but it did a pretty good job - focused quickly and did a good job of getting the white balance right.  It also took very good videos, which is new to me as it's the 1st camera I've owned with video capability.
I had been using the G10 in it's UW case until now.  It did a great job, but the bulk took up a lot of space in my carry-on luggage.
Hopefully all of the manufacturers will improve their quality and features soon...
Camera gear in profile.
Ken G.
http://www.pbase.com/kgilbertsen/
 Ken G.'s gear list:Ken G.'s gear list
Canon PowerShot G10 Nikon D300
21st Hermit Veteran Member • Posts: 5,462
You should look at this thread before you buy that "Cannon".
You're getting your sheets(Cannon) confused with your cameras (Canon).
Lost in the Colorado Mountains!!!
BorisK1 Veteran Member • Posts: 5,366
TG-2's lens opens up to f:2.0 at the wide end.  That's two whole stops more than with AW110's f:3.9.  The scene where TG-2 would use a comfortable ISO 200, AW110 would require ISO 800.
AW110's noise reduction would have to be remarkably better to overcome the difference in lens speed.
 BorisK1's gear list:BorisK1's gear list
Olympus Tough TG-4 Olympus E-3 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 11-22mm 1:2.8-3.5
Ken G.
I'm sure that's definitely true in low light situations, where no doubt the Oly would shine.  I will only be using the camera in bright daylight situations (mainly snorkeling/kayaking), which is where and how I compared the 2, and Nikon edged out the Oly in maintaining better detail.  I will say I liked the Olympus' layout more.  I believe most of the tough waterproofs will give very similar results overall.
Ken G.
That was the big advantage of the TG-1 for me - the expanded "comfort envelope".  It actually has issues in direct sunlight (the camera enables the 3-stop ND filter when it could've set faster exposure instead, so the shutter speed drops unexpectedly).  But in less-than-perfect light it's head and shoulders above the rest.
Agreed. My usual recommendation about the "toughcams" is to avoid them at all costs.  They are very specialized and make a lot of compromises.  But for some situations - like action sports - that's the only way to take any picture at all.
Ken G.
Rmark
Rmark Contributing Member • Posts: 706
In diving, 33 ft would be 1 additional atmosphere of pressure. At sea level you are at 1 atmosphere, at 33 feet 2 atmosphere. If the D30 can do 82 ft that would be a great diving vacation camera.
I have been diving and taking photos for 20+ years and rarely  need to go deeper than 70 feet, unless looking for some thing specific. I think the early waterproof cameras were for snorkeling, but the D30 shows promise as a dive camera.
If Nikon ,with their Nikonos rangefinder camera could do 50 meters of depth, 40 years ago, certainly the technology was there to copy.
 Rmark's gear list:Rmark's gear list
Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +3 more
It's a question of cost rather than technology. The technology employed in the Nikonos of die cast sections and air tight seals to enable it to achieve those depths was not particularly advanced but the cost of building such a device was high and without regular maintenance they would often leak.  A digital underwater camera and housing can be obtained for little more than the typical cost of servicing a Nikonos V.
