Snowflake
Started Feb 25, 2014 | Discussions
Stephen Barrett Contributing Member • Posts: 679
Snowflake
1-Snowflake through double-glazed window
2-The same snowflake a few minutes later - partially melted
Both shots are with Canon SX30 at full optical zoom (150.5 mm) and 2.1x digital zoom. Shot 1 is with Raynox 150; shot 2 is with Raynox 250.
Approximate magnifications on sensor (i.e. not including 2.1x digital zoom) are:
Shot 1 with Raynox 150: 150.5 mm / 208.33 mm = 0.72x
Shot 2 with Raynox 250: 150.5 mm / 125 mm = 1.2x
 Stephen Barrett's gear list:Stephen Barrett's gear list
Canon PowerShot SX30 IS +3 more
Biff Exploder
Biff Exploder Regular Member • Posts: 407
Re: Snowflake
so.... freakin.... cool!
 Biff Exploder's gear list:Biff Exploder's gear list
Canon PowerShot SX40 HS Samsung NX3000 Samsung 16-50mm F3.5-5.6 power zoom +2 more
(unknown member) Veteran Member • Posts: 3,073
Re: Snowflake
Stephen,
Wonderful closeups!!  How did you keep them from melting while taking your photos?
Murry
PS  Just a side note--Letterman broke me up a few nights back when he said:
"Scientists have decided that all snowflakes are pretty much the same"
He has a dry sense of humor that really tickles me at times.
Stephen Barrett OP Contributing Member • Posts: 679
Re: Snowflake
Thanks Biff & Murry.
I have been taking lots of pictures of frost that forms on the inside of the windows of my garage, where it is usually a little below 0 C, while outside it has been -10 C and colder.
This time, the snowflake was outside, while I took the shots through the double-glazed window while standing inside. Snowflakes don't usually stick to the window, but this one was very tiny - only about 2 mm across. Yesterday was a bit warmer than usual, a bit below 0 C outside, with the garage a bit above 0 C, so I guess the snowflake was picking up heat from the glass, causing it to melt.
Augustin Man
Augustin Man Veteran Member • Posts: 6,560
Re: Snowflake
Very impressive, congratulations!
Happy shooting,
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Canon PowerShot SX50 HS Nikon Coolpix P900
Re: Snowflake
Thanks, Augustin Man.
evancj Veteran Member • Posts: 3,689
Re: Snowflake
A very beautiful, and impressive use of your SX30 Stephen, well done!
 evancj's gear list:evancj's gear list
Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR
Re: Snowflake
Thanks, Evan.
Hollander Senior Member • Posts: 1,370
Re: Snowflake
Nicely done Stephen, thanks for sharing.
Rob.
To keep my brain active I'm looking forward to my next trip. So much to see yet and not enough time.
http://robvorderman.zenfolio.com/
 Hollander's gear list:Hollander's gear list
Panasonic Lumix DMC-FZ35 Canon PowerShot SX50 HS Sony Cyber-shot DSC-WX80 Olympus E-1 Olympus E-3 +3 more
Re: Snowflake
Thank you, Rob.
Andre W
Andre W Senior Member • Posts: 1,562
Re: Snowflake
Great shots Stephen. - thanks for sharing!
I don't know anything about the Raynox - could you please tell me more?
I have the SX50HS - I suppose it will also fit?
How do you attach it to the SX and what else do you need apart from the Raynox itself?
Thanks again Stephen.
Regards
Andrè
 Andre W's gear list:Andre W's gear list
Canon PowerShot SX50 HS Canon PowerShot SX270 HS Canon EOS 60D Tamron AF 18-270mm F/3.5-6.3 Di II VC LD Aspherical (IF) MACRO Canon EF 50mm f/1.8 II +2 more
Ian Abrahamson Regular Member • Posts: 343
Re: Snowflake
Thats incredible nice...
Current power shot SX 50 HS
Nikon S9300
Power shot SX 270 HS
Power shot SX 110 IS
Fugi Finpix E 500
 Ian Abrahamson's gear list:Ian Abrahamson's gear list
Canon PowerShot SX230 HS Canon PowerShot SX50 HS Sony Xperia Z3 Compact +1 more
Re: Snowflake
Thanks Andrè,
There are two Raynox closeup lenses:
DCR-250
http://www.raynox.co.jp/english/dcr/dcr250/indexdcr250eg.htm
DCR-150
http://www.raynox.co.jp/english/dcr/dcr150/indexdcr150eg.htm
The DCR-250 is the stronger of the two at 8 diopters with a working distance of
1000/8 = 125mm, or about 5 inches.
At full optical zoom on the SX50, the magnification is 215 mm / 125 mm = 1.72 x
(with infinite focus) and the depth-of-field is only about 0.2 mm at widest aperture. With narrower aperture or less zoom, you get more DOF.
The DCR-150 is 4. 8 diopters with a working distance of
1000/4.8 = 208 mm, or about 8 inches.
At full optical zoom on the SX50, the magnification is 215 mm / 208.3 mm = 1.03 x
(with infinite focus).
The Raynox closeup lenses attach with a spring-loaded "universal adaptor", which is what I use and find convenient, although some people prefer to use adapter rings.
If you want to choose just one of them, I would recommend the 150. Even though it is the weaker of the two, it is easier to use and more of the shots are keepers. The larger working distance makes it easier to avoid casting a shadow on your subject and you are less likely to scare insects away.
Focus-stacking is a fun technique for combining multiple shots in order to increase the DOF.
Here is one of my posts with some technical details about DOF, use of macro rails and the Zerene Stacker software:
http://forums.dpreview.com/forums/post/50636595
Here are some of my stacked shots of small flowers taken with the Raynox-150:
http://www.dpreview.com/forums/post/51443590
If you don't want the bother of stacking, you can still get excellent handheld closeup shots. Again, I would recommend the Raynox 150. The price is around $75 U.S. if you shop around (includes the spring-loaded "universal adaptor"). You can have a lot of fun without any extra equipment. If you want to do focus-stacking, macro-rails start around $70 and Zerene Stacker is $89 U.S.
I hope this helps.
Re: Snowflake
Thanks, Ian
Andre W
Thanks Stephen ---
For your time, giving such a detailed answer - I appreciate - you surely know a tremendous amount of the technical side and - it shows in your images - kudos to you!
Thanks again
Regards from South Africa
Andrè
