Nikon D2Hs
Started Feb 21, 2014 | Discussions
Kent Vinyard Regular Member • Posts: 153
Nikon D2Hs
Kent in Ok
Any one out there still shooting this camera in the days of smaller lighter high iso camera. Also what are you shooting with it.
Nikon D2Hs
RBFresno
RBFresno Forum Pro • Posts: 10,884
Re: Nikon D2Hs
Kent Vinyard wrote:
Kent in Ok
HI!
I still have my D2h (I think.....).
I'm not sure that I'd describe the D3 or D4 as significantly " smaller, lighter" though...
The D2Hs was better at higher ISO than the D2h, but neither were high ISO champs, at least compared to current DSLR's
With the D2h, I could start seeing noise that I didn't like at ISO 320, and by ISO 640, it was very noticeable. However, my noise reducing technique became more refined during my use of the D2h!
Unprocessed JPG out of camera:
Nikon D2h ,Nikkor 200-400mm f/4G ED-IF AF-S VR
1/125s f/4.0 at 280.0mm iso800
RAW image Post Processed (with obvious heavy White Balance adjustment and noise reduction):
With the D4, I wouldn't have to do anywhere near this degree of post processing, and probably would have shot it at around ISO 3200
At the time, I really didi like the D2h. It was amzing what a 4MP camera could produce:
1/1600s f/4.0 at 400.0mm iso200
1/1250s f/4.0 at 400.0mm iso400
RB
 RBFresno's gear list:RBFresno's gear list
Nikon D2H Nikon D4 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +12 more
Schroedingers_cat
Schroedingers_cat Veteran Member • Posts: 3,821
Re: Nikon D2Hs
Almost needed a wide angle lens on that last one
http://www.nightstreets.com
"Sick cultures show a complex of symptoms such as you have named...but a dying culture invariable exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners is more significant than a riot."
This symptom is especially serious in that an individual displaying it never thinks of it as a sign of ill health but as proof of his/her strength. ...Friday, it is too late to save this culture--this worldwide culture... Therefore we must now prepare the monasteries for the coming Dark Age. Electronic records are too fragile..."
--Robert A. Heinlein in "Friday"
hgnoel1980
hgnoel1980 New Member • Posts: 20
Re: Nikon D2Hs
I have only recently got my D2Hs secondhand. Having originally brought a D40 three years ago, I quickly found I wanted something with more manual control and moved on the a D200. I found this much better and loved the jpegs SOOC however found I didn't like shooting with it in portrait with the battery grip and the battery life was shocking. I have found the D2Hs much better in this regard it just feels better in my hands and find now using the D200 I miss the faster shutter blackout and bigger viewfinder.
I therefore will probably let the D200 go to finance a Nikkor 12-24 f4 despite it being a great camera and will keep the D40 if I need something light and as my wife finds it easy to use.
I largely only use my 35mm f1.8 on mine as I take a lot of photos of my kids indoors.
Despite 'only' having 4MPixels it produces lovely pictures and since getting it have started to shoot raw and find the files easy to process thru Darktable compared to the files from the D200.
I understand this camera has been a bit of a 'marmite' camera to many over the years, but for me, I love the handling so much with the built in vertical grip I find it odd using a camera without one. I don't have the money for a D3 etc so the D2Hs has met my needs perfectly. I'm sure there are newer cameras that are considerably better image quality wise and my D200 really is a lovely camera, however I cannot see myself parting with my D2Hs until it dies.
 hgnoel1980's gear list:hgnoel1980's gear list
Nikon D40 Nikon D2Hs Nikon D200 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +5 more
manhattan Regular Member • Posts: 286
Re: Nikon D2Hs
I still love this camera...for outdoor use only! Absolutely stunning pictures and warm colors.
