New Microphone for Multi Interface hot shoe
Started Feb 21, 2014 | Discussions
phototherapy Contributing Member • Posts: 863
For A6000 & A58 & A79 and all other new camera's to come, is it a gadget or something that is really usefull ? thanks.
http://www.sonyalpharumors.com/first-picture-of-the-a6000-with-the-bluetooth-mic-and-af-tests-are-very-promising/
Sony a6000 Sony Alpha 7 Sony Alpha SLT-A58
IanML Senior Member • Posts: 1,653
Re: New Microphone for Multi Interface hot shoe
To my mind, assuming the tall stand-alone thing is the mike and transmitter, and the thing on the shoe is the receiver, very useful for video. The main problem with video sound is noise from the camera. This will allow an off-camera mike to be cordlessly connected, so not hampering the cameraman, and will do away with the need for a separate recorder, the output of which has to be synchronised to the footage in post.
Ian
 IanML's gear list:IanML's gear list
Sony SLT-A33 Sony Alpha NEX-5N Sony SLT-A57 Sony a77 II +1 more
Just to add, the unit seems very similar to the ECM-HW2 for camcorders.  That is a very versatile unit and even allows two way communication when the mike is worn by a subject/assistant.
Link to operating instructions
Ian
phototherapy OP Contributing Member • Posts: 863
Ian
the sound is recorded by the camera directly I think, so why should the output still have to synchronised in post ?
phototherapy wrote:
Ian
I think you misread what I said:   "and will do away with the need for a separate recorder, the output of which has to be synchronised to the footage in post."
Ian
leonche64
leonche64 Contributing Member • Posts: 555
Wow! This is a simple solution to so many technical issues involving video shooting. It looks like you can now film from across the room at f8, have the transmitter hard lined into an H2, and have it recorded in-camera in stereo with the ability to sync it at the same quality to 4 channel surround sound with out carrying any additional gear. Amazing.
For all the moaning and crying about the new hotshoe, it is starting to make a lot of sense.
 leonche64's gear list:leonche64's gear list
Konica Minolta Maxxum 7D Sony SLT-A77 Sony Alpha 7 II Sony E 18-55mm F3.5-5.6 OSS Sony 70-300mm F4.5-5.6 G SSM +7 more
Wally626 Senior Member • Posts: 2,262
Ian
Link to new mic
https://docs.sony.com/release/ECMW1M_EN_ES_FR.pdf
Does look very similar to the ECM-HW2 but adds a port for a separate mic to the transmitter unit so you can use it just as a mic pack and have a separate higher quality mic hooked to it. It is a neat device but similar units exist that would just require a mic port on the camera to work.
K E Hoffman
K E Hoffman Senior Member • Posts: 4,825
Having worked with the old show on Sony Camcorders.. includes functionality like this..
I knew all the time
Add Video light control, Flash with Video light combos etc. The new shoe not only allows for ISO triggers (non-ttl) but lots of other ability .. It was a good move.. as much as I for flash prefer the old Minolta.
K.E.H. >> Shooting between raindrops in WA<<
Don't Panic!.. these are just opinions... go take some pictures..
 K E Hoffman's gear list:K E Hoffman's gear list
Canon EOS 450D Nikon 1 J1 Sony Alpha a6300 Sony 100mm F2.8 Macro Sony E 18-200mm F3.5-6.3 OSS +4 more
