Decisions, Decisions: 10-24mm zoom or 14mm prime
Started Feb 20, 2014 | Discussions
jrk
jrk Senior Member • Posts: 1,839
I pre-ordered the 10-24mm zoom which is expected in April.  With the current sale offering of $699 for the 14mm, that's a $300 differential.  The zoom gives me more versatility, while the 14mm will most likely provide better IQ and is faster but has a significantly smaller FOV (89 degrees vs 110 degrees).  Size/weight is really not a factor for me so I'm not concerned the zoom is significantly larger.  I like the options that zooms provide but I'm very impressed with pictures I've seen coming from the 14mm.  I'm really trying to hone my photographic skills so I will be using the lens (along with the others I own) on a variety of subjects.  I think of myself as a utility photographer, not a specialist.
Thoughts anyone?
Thanks in advance!
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X-E1 Canon EOS 70D Fujifilm X-E2 Fujifilm X-T1 +12 more
Apsphoto
Apsphoto Regular Member • Posts: 480
Re: Decisions, Decisions: 10-24mm zoom or 14mm prime
Get the 14mm now and enjoy it and then add the 10-24mm when it arrives.... step on the G.A.S.    I bought the 14mm when it came out and it is a great lens, I will add the 10-24mm when it is available.
Alan
Alan Smallbone
Orange county, CA
 Apsphoto's gear list:Apsphoto's gear list
Sigma DP3 Merrill Sigma dp2 Quattro Canon EOS 5D Mark II Fujifilm X-Pro1 Fujifilm X-E1 +12 more
ryan2007
ryan2007 Forum Pro • Posts: 12,001
Buy what you need, but don't buy something just because it is on sale and may not get enough use to justify it. IMO a rainy day or just in case purchase is not the best idea.
If the lens cost $900 whatever it normally does would you still buy this lens. If not, you do not really need it based on what you shoot.
IMO, many get obsessed with a couple hundred dollars savings when you have a system that costs as much as a Full Frame DSLR but the time you get done with a few lenses. I think the reasoning should be different, unless one has money to burn and does not care about re-sale value if you need to sell the lens later.
I would think if you were going on vacation tomorrow what you would take and what would stay home. The Prime is smaller and less weight than a zoom, but the zoom is more versatile.
The one stop difference on a wide angle lens does not matter. Your not getting a shallow DOF with a wide angle lens unless your very close to the subject wide open and even then 90% of the time one never shoot everything thing at max aperture.
List at least 5 to 10 things/subject matter you shoot with a given lens and you will see that 18-55 or 23 or 35 prime get most use for most everything. A zoom lens being faster to compose the shot. I think the 10-24 is worth a look and if you sell the 14 mm to help pay for the 10-24 you are not getting $700 for a used 14 mm, maybe $400. I see it as redundancy and buying a lens twice if the lens is just to hold you over type purchase.
Joel Stern
Joel Stern Forum Pro • Posts: 10,909
All I can say is the 14 is spectacular and feels great on the camera.
If i am typing on my iPad, please excuse any typos.
flbrit
flbrit Veteran Member • Posts: 3,607
The zoom gives optical stabilization ....
And probably more distortion/ca which will be correctable in software.
Myself, I will stick with the 14mm and probably buy the 16-55 f2.8 wr when available.
Brian
 flbrit's gear list:flbrit's gear list
Canon EOS 7D Mark II Sony Alpha 7R II Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +10 more
nspur
nspur Senior Member • Posts: 1,038
I have the 14 and 18 mm Fujinon lenses. When I had Canon gear I used a Sigma 12-24 (a very good lens) on full frame and 1.6 crop but it actually did not get used very much and hence I'm not going for the 10-24. Effective 21 mm is about as wide as I reckon to go. I do have an manual Samyang 16 mm for my Pentax weatherproof kit and could use it on the X-E2 but it's large and heavy and one can always crop a 14 mm shot.
Nick Spurrier
 nspur's gear list:nspur's gear list
Panasonic Lumix DMC-FZ1000 Fujifilm X30 Pentax K-50 Fujifilm X-E2 Sony Alpha 7 II +1 more
EricWN
EricWN Senior Member • Posts: 1,844
Thoughts?
First thought: research. This forum has probably discussed this before. And probably more than once.
Second thought: go and test both once available. Don't reply on internet chatter.
SaltLakeGuy
SaltLakeGuy Forum Pro • Posts: 11,137
At the end of the day
I am confident you'd find the zoom more flexible and with image stabilization  a definite plus for those times when you'll wish you had it. At some point I may cave but feel I'm not a real wide shooter to begin with. But if I were adding anything that would likely be the one.
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-70mm F2.8 GM +2 more
flbrit
Nick Spurrier
I found the same thing when shooting my 12-24 (FF equiv 16-36mm) Tokina f4 on my Nikon D300(half frame). I often ended up at 14mm widest.
Having said that, I now shoot a 18mm lens on my D800e but I often find I crop to 21mm. Having the option is good though otherwise stitching beckons.
Just got the 18mm Fuji f2. Love it. It compliments my 27mm nicely as an about town, smallish, light weight kit with the X-E2.
Brian
georgehudetz
georgehudetz Senior Member • Posts: 2,152
You don't mention the lenses you already have. For example, if you have the 18-55, then there is significant overlap between the 10-24 & your current lens. But if all you have is a 35mm (for example) and favor wide angle shots then the 10-24 might make more sense.
However, I believe the most important factor is to understand if you truly want to shoot ultra-wide. Shooting at 10mm is different than 18, 16, or even 14mm. For example, if you use 10mm to shoot a typical landscape, all you'll get is a very wide view with lots of tiny details, and will likely be an uninteresting composition.
One of the main reasons to shoot at 10mm is to get exaggerated perspective. This means you bring some element in the foreground very close to the lens, to make it look larger than it actually is. It is a very distinct style and either you like it or you don't.
Here's an example of mine:
http://www.flickr.com/photos/39102910@N07/9768773266/in/set-72157635553959736
I like this style of shooting, but I have to put myself in that mindset.  There are some good write-ups on this technique out there, although I think they overstate the degree of difficulty.
I'd suggest searching on flikr for very wide shots.  If you like what you see, you have something to aspire to and the 10-24 will be a good purchase.  If you are just looking for a good landscape lens, look to the 18 or 14.
 georgehudetz's gear list:georgehudetz's gear list
Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +7 more
flbrit
+1..................NT
No text.
stulevine
stulevine Regular Member • Posts: 207
I'd start with the 10-25mm zoom as I think you'll be really happy with it.  Yea, it is slower, but the zoom has OIS and this can oftentimes gain you about 4 stops.  And, frankly, unless your doing astrophotography and need a really fast sharp lens, the zoom will be perfect for landscape photography since we tend to stop down the lens anyway for that.  I have the 14mm, and use it on occasion for landscape work, but I think the zoom would be perfect and I'll pick up one of those as soon as it's available at my local retailer.
 stulevine's gear list:stulevine's gear list
Fujifilm X-T10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +18 more
jrk
jrk OP Senior Member • Posts: 1,839
EricWN wrote:
Thoughts?
Unfortunately I know of no brick and mortar shop that I can visit that would have these two lenses.  The only places I'm aware of any where near me are places like Best Buy, Sams Club, etc.  They do not carry higher end equipment.  If I knew of a place I certainly would go once the 10-24 was released.  I found a couple of the replies very informative and have provided some insights that I hadn't thought of.
Thanks for taking the time to respond.
jrk
Thank you, this is much appreciated.  Viewing your pictures gave me a perspective I hadn't thought of.
Astrophotographer 10
Astrophotographer 10 Senior Member • Posts: 6,536
The 14mm is an extremely good lens.
Have a look at this shot:
http://www.pbase.com/gregbradley/image/150291539/large
Click on original and look at the very top left corner. You see significant star elongation only in the very corners. So the lens is not fully corrected for the image circle - they missed a bit. But that is unlikely to show in your images of landscapes.
OIS reduces image quality to some degree. So OIS on a 10-24 is less desirable. Shake is far less of an issue at wide focal lengths so OIS would be far less important. IQ is eveything though at wide angles.
The 14mm is one of Fuji's sharpest lenses.
Also perspective distortion will be much greater with the 10-24 at wider like those carpark photos posted a few weeks ago. So with the 10-24 you are going to be limited at the wider end to shoot horizontal or face the ugly consequences.
But also look at those wonderful Bruce Devlin Nevada landscape shots posted in his XT1 review. They are stunning.
I have 18-55 so 14 fits nicely. F2.8 is important for my use. 10-24 may still hold an attraction once more sample images are out. But as mentioned a super wide pushes landscape details back and can make for an uninteresting image.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
dotborg
dotborg Veteran Member • Posts: 8,250
Here are some points of thought
  • The zoom is certainly more versatile.
  • The prime is a stop brighter.
  • At 14mm and f4, they both probably have similar IQ. In fact, I'd put money on this with the exception that the zoom is likely to exhibit more lateral CA.
  • The zoom has an image stabilizer.
  • If I had the zoom, I probably wouldn't use it very often wider than 14mm due to the fact that I find the extreme stretching into the corners bothersome with ultra-wide lenses.
  • The prime is a lot smaller.
  • The prime has that nice manual focus feature.
  • The prime has the same filter size as the kit zoom, allowing me to carry only one set of polarizer and ND filters.
  • The 18-55mm and 14mm share the same hood, so I only need to pack one.
  • The zoom has 72mm filter threads. I have no other XF lenses with this filter size.
  • They both have very nice construction (of course).
  • Neither is weather sealed.
  • The minimum focus distance for the zoom is 24cm.
  • The minimum focus distance for the prime is 18cm.
BTW, the diagonal angle of view for the 14mm is 90.8°, not 89°.
Miamistan
Miamistan Forum Member • Posts: 61
got the 14mm
The reason I got the 14mm is because I also have the 18-55 and thought this is the perfect lightweight combo for travel. I have xe-1 and xe-2, I keep the 14 on xe-1 for scenics and the genereal purppse lens on the faster xe-2. I also have the 55-200 and while I like it its a pain carry. I ordered the 27mm fixed to go with the 14 when I want to travel really light. It wasn't money I just feel the 14mm is small enough to stay on body all the time and I thought the wide angel zoom would be a hunk of glass that got me away from why I started with Fuji.
 Miamistan's gear list:Miamistan's gear list
Sony RX100 Nikon D5100 Fujifilm X-E1 Fujifilm X-E2 Tamron SP 70-300mm F/4-5.6 Di VC USD +12 more
Al Valentino
Al Valentino Senior Member • Posts: 4,579
The price difference may be more than $300 once you factor in a set of filter, clear, CPL and/or ND into the mix. So with filters the price difference might be closer to $400.
If you have the 18-55 the 14mm is a nice compliment as they share the same filters and hood. The 10-24 looks like the 18-55 on steroids - not that there is anything wrong with that.
Since the 14mm is on sale for a limited time, without a camera purchase, if you get the 14mm for $700 you can sell it for $750 in 3 months when the sale has long gone. So you risk little and get to shoot wide today!!!
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
ballwin12
ballwin12 Regular Member • Posts: 287
the zoom is better choice IMO!
No text.
 ballwin12's gear list:ballwin12's gear list
Leica X (Typ 113) Sony Alpha 7 II Sony FE 55mm F1.8 Sony FE 24-70mm F4 OSS Sony FE 28mm F2 +1 more
LaFonte
LaFonte Senior Member • Posts: 2,744
Thoughts anyone?
Thanks in advance!
With the current discount, the 14 is the best deal. Its price will go back up so for me tat is one not to be missed.
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
