Minimum shutterspeed Fuji 23mm lens
Started Feb 20, 2014 | Discussions
Marco1971
Marco1971 Regular Member • Posts: 340
What's the minimum shutterspeed for the 23mm Fuji prime to take pictures without blur ? (handheld).
Today i tried this lens on a X-E1 but with a shutterspeed of 1/60 with 1,4 apterture at iso200 but it was not possible to take a picture without blur (indoor shooting handheld).
 Marco1971's gear list:Marco1971's gear list
Fujifilm X-E1 Fujifilm X-M1 Fujifilm XF 23mm F1.4 R Adobe Photoshop Lightroom 5 +1 more
Fujifilm X-E1
Mike Guffin
Mike Guffin Regular Member • Posts: 476
Re: Minimum shutterspeed Fuji 23mm lens
1/60 should do it... I shoot 1/60 handheld with the 35 1.4... Maybe your subject moved, or you missed focus slightly...
 Mike Guffin's gear list:Mike Guffin's gear list
Ricoh GR II Fujifilm X-Pro1 Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F1.4 R +2 more
Marco1971
Marco1971 OP Regular Member • Posts: 340
Zoomer52 Forum Member • Posts: 59
The answer to your question depends on YOU!
Only you can determine your steadiness with various lenses and even then it would vary depending on how tired you are, how much coffee you've had, etc.
When in doubt, I always reach for a tripod.  (Or up the ISO.)
I've got a friend who's never drank coffee and (not sure that's the reason or not) he can hand-hold a lens at a slower shutter speed than anyone I've ever met.  Three, sometimes four, stops lower than I can.
Learn your limits and don't be afraid of your tripod.
 Zoomer52's gear list:Zoomer52's gear list
Canon EOS 5D Mark II Canon EOS 5D Mark III Fujifilm X-E2 Canon EF 14mm f/2.8L II USM Canon EF 35mm f/1.4L USM +17 more
Marco1971
My post was related to the RAW file. The JPEG is tack sharp.
But i still don't understand why there is so much difference in sharpness....
Marco1971
I attached the JPEG. Seems ok to me
DonSantos Senior Member • Posts: 1,145
I keep my min shutter at 1/125. But that's because I mainly take photos with people in them.
 DonSantos's gear list:DonSantos's gear list
Fujifilm X100S Nikon D600 Sony Alpha 7 Voigtlander 40mm F1.4 Nokton Classic Nikon AF-S Nikkor 50mm f/1.8G +3 more
Marco1971
This jpeg was shot at 1/6 2.8 iso 200 --> impossible avoiding blur...
flbrit Veteran Member • Posts: 3,665
RAW/JPG softness, nothing to do with Minimum shutterspeed Fuji 23mm lens
RAW files are not sharpened by the camera. You need to do this in post processing using your preferred software. JPG's are sharpened by the camera depending on what jpg style you select.
 flbrit's gear list:flbrit's gear list
Sony Alpha 7R II Carl Zeiss Distagon T* 1,4/35 ZM Canon EF 100-400mm F4.5-5.6L IS II Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +6 more
57even Senior Member • Posts: 9,414
Blur is a lot more noticeable on a 16MP camera than it would be on most 35mm film, especially since noone ever looked at 100% screen files (30" prints).
The 1/FL rule is totally inadequate for most people. For one thing APSC means the FL is effectively 1.5X greater, and secondly the rule was invented for 12" prints.
My baseline (minimum) is 1/2FL, which still takes a fair amount of good technique, but this does not necessarily translate equally to all focal lengths. Light cameras tend to be harder to control as well (less intertia) and still may not be critically sharp at 100%.
Generally I use 1/50 as a minimum for the 14, 1/100 as a minimum for the 23 and 35, and 1/200 for everything else, simply because it seems to work. But I still have to be VERY careful when hand-holding. However the Fuji is usable enough up to ISO1600 for this not to be a problem.
 57even's gear list:57even's gear list
Fujifilm X-Pro2
Andy Dan Regular Member • Posts: 160
Depends how steady are your hands and how you hold the camera...Considering the crop factor and the 23mm lens (35mm ff equiv)...1/35 is enough with a dlsr (slr style). With a rangefinder (if you don't have the lateral grip and your hands are not so steady) 1/80 is the best bet imo.
 Andy Dan's gear list:Andy Dan's gear list
Canon EOS 6D Canon EF 100mm f/2.8L Macro IS USM Canon EF 24-70mm f/4L IS USM +4 more
57LowRider Senior Member • Posts: 3,766
Very interesting, I nearly started a thread on this.
I think minimum shutter speed is one of the disadvantages of smaller formats; before Fuji enabled min speed in Auto ISO, it used to default to 1/F where the F is full-frame equivalent - so with the 35mm, it would go to 1/52.
Now, I don't have fun with that 1/F. In my experience, it works a lot better with 1/(full frame F + APS-C F), which would make the 35 require 1/(35 + 50) = 1/85; in practice, 1/100 (and I notice that Bert Stephani uses this too).
For the 23, 1/(23 + 35) = 1/58, so I use 1/60 as a minimum and that's fine - as your JPG shows. The real mystery you have is why the default output from RAW is not sharp - what are you using to post-process?
 57LowRider's gear list:57LowRider's gear list
Fujifilm X-E1 Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +10 more
bluesman2070
bluesman2070 Contributing Member • Posts: 936
I've not had the 23mm for long but I think 57LowRider is close to the mark with his formula. This was taken at 1/58s @ f3.2.
 bluesman2070's gear list:bluesman2070's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-T1 Canon EF 20mm f/2.8 USM Canon EF 70-200mm f/4L IS USM +5 more
Marco1971
LR5
Peter Flor Contributing Member • Posts: 637
I find Focal Length + 20 works well for me.  So for a 23mm APS-C that would be 35 + 20 = 55  or 1/60 (rounded off).
 Peter Flor's gear list:Peter Flor's gear list
Fujifilm X100S Nikon D700 Fujifilm X-Pro1 Fujifilm X-T1 Nikon AF-S Nikkor 24-70mm f/2.8G ED +7 more
LR5
Do you use the defaults on import? (Sharpening amount 25, Radius 1.0)
Marco1971
LR5
Yes
LR5
Yes
Could you show us the Samsung camera shot exported at LR5 defaults? Just want to look at the sharpness compared to the earlier JPG (which was OOC?).
Marco1971
You didn't like the 23mm ??
Marco1971
Here it is.
57LowRider wrote:
LR5
Yes
