7-14mm for travel?
Started Feb 20, 2014 | Discussions
zilver
Contributing MemberPosts: 647Gear list
7-14mm for travel?
Feb 20, 2014
I've been interested in wide angle lately but never really tried shots wider than 12mm (24mm FOV) with the 12-35mm.
The review seems to agree that the Pana 7-14mm F4 is a very good wide angle zoom.
I'm going to the mountains and thinking I want to explore wider lens, just need to ask that if I take only one lens can the 7-14 be a walk around lens for landscape and family shots, can I at least take nice shots of family member with background of the view at long end of the zoom or it's not really practical?
Thanks,
 zilver's gear list:zilver's gear list
Fujifilm X100T Leica Q Sony Cyber-shot DSC-RX100 IV Fujifilm X-T10 Sony Alpha 7R II
George Paulides
Contributing MemberPosts: 998
Re: 7-14mm for travel?
In reply to zilver, Feb 20, 2014
I would not call the 7-14mm a "walk around" lens. It is more of a landscape lens, a great performer at that.
If you want to take pictures of family you would be better off with a standard lens as 12-35mm or 14-42mm.
dmanthree
Veteran MemberPosts: 5,211Gear list
I think it's too wide to be a walk around lens. I'd go for the 12-35. If you see a scene that too wide for 12mm, shoot multiples and stitch.
No Signature.
 dmanthree's gear list:dmanthree's gear list
Sony Cyber-shot DSC-HX30V Olympus Tough TG-4 Panasonic Lumix DMC-GX1 Nikon D810 Panasonic Lumix DMC-GX8 +11 more
Mark Thornton
Veteran MemberPosts: 3,139Gear list
My 11-22 is fine as a walk around lens albeit oversized on m4/3. The Olympus 9-18 may be suitable and does have a m4/3 version. I agree with the other posters, that 14mm is a bit too wide to qualify for 'walkaround' use.
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Olympus E-500 Panasonic Lumix DMC-GX1 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Isabel Cutler
Forum ProPosts: 15,454Gear list
Re: Suggestion
Thanks,
The 7-14 would be too wide for all round and people use.
You'd be much better off with the 12-40 and when it's not wide enough to combine images into panoramas when you get home and can edit them. Here's a panorama I made at 12mm with the 12-40:
Best viewed at original size
Or...as long as you don't need it for low light work a standard 14-42 kit lens (or some other kit lens in that range) would be perfect for outdoors.  I've found my Olympus 14-42II to have excellent image quality.
Isabel
 Isabel Cutler's gear list:Isabel Cutler's gear list
Canon EOS 7D Olympus PEN E-PL5 Panasonic Lumix DMC-GX7 Olympus OM-D E-M10 II Samsung Galaxy Note 4
Richard Weisgrau
Veteran MemberPosts: 3,518
I agree with those who have posted here saying that the 7-14 is not a walk around zoom lens. With the 12-35 you already have that type of lens. The zone from 7mm to 12mm is very wide indeed, and there are few subjects you will encounter in your travels that require that wide a lens. It is not a good lens for candids on the street unless you want to move in close to your subject and get a lot of background in the shot.  I have the 7-14. It is a remarkably good lens. I use it mainly for shooting residential real estate interiors. Even then I hardly ever have the lens set at 7mm.
Richard Weisgrau
www.drawnwithlight.com
www.show-my-house.com
Author of:
The Real Business of Photography
The Photographers Guide to Negotiating
Licensing Photography
Selling Your Photography
jeffharris
Veteran MemberPosts: 6,086Gear list
Re: 7-14mm for travel? Absolutely!
The 7-14mm is excellent. It focuses quickly and produces very sharp images, as long as you don't stop it down too much. I try go no further than f8. It takes a little effort to learn to control the 7mm end, but it's really worth it! Here's a good piece by Ken Rockwell (really! ) on shooting with ultra-wide lenses.
http://www.kenrockwell.com/tech/how-to-use-ultra-wide-lenses.htm
It's part of my standard travel kit and I often use it as a walkabout lens when shooting places and spaces. And also for my design business. But certainly NOT people! My girlfriend complains of looking blimp-like if I happen to catch her in the edge of the frame. I always carry longer prime lenses or a standard zoom, so I can swap when necessary. If I were to carry two cameras, I think I'd dedicate the second to the 7-14mm. It's really that good. The images it helps me produce can be kind of amazing.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical +27 more
markymark101
Senior MemberPosts: 1,097Gear list
UWA is really cool - go for it
For years i didn't think I needed an UWA and just stiched.   I bought the 9-18nm last year, and no way I'm selling it.   You can do more with an UWA that stitching just doesn't get you.
Saying that, UWA is not very good for people.   The wider you go the more faces and bodies can get distorted.   However, the 9-18mm is a better choice for an all-rounder than the 7-14mm.   I could easily take the 9-18mm and and a telephoto on vacation and be happy.   The 7-14mm is a fine lens, though.
Sometimes you just need more than one lens.   That's why they make them interchangable.   With m43, carrying an extra lens is no problem - they weigh nothing.    Pair up the 7-14mm with a fast prime (20mm or 25mm) and you are good to go.  Or if you wanted to stick with zooms, adding the 14-54 or a 14-42 are inexpensive options.
Anyway, I say go for the UWA.
 markymark101's gear list:markymark101's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +3 more
richarddd
Senior MemberPosts: 2,982Gear list
Two threads on travel lenses which include discussions of the 7-14:
http://www.dpreview.com/forums/thread/3625142
http://www.dpreview.com/forums/thread/3627156
 richarddd's gear list:richarddd's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 UMC Fisheye MFT +3 more
jeffharris
Re: UWA is really cool - go for it
In reply to markymark101, Feb 20, 2014
Exactly.
The original kit I bought with my first M4/3 was the GH2, 14-140mm, 20mm and 7-14mm. This was a perfect and very flexible set of travel lenses. Not too many (always a danger! ) and covering quite a wide range. My girlfriend has a GX1 and uses a 14-42mm II, 20mm and 45-150mm. I use a GX7 and primes. We share the 7-14mm.
Regardless of where I go or what I'm doing, the 7-14mm is always there. It's just a fantastic lens. And LOTS of fun to use!
Pic Man
Senior MemberPosts: 1,280
Thanks,
It will be fine, 28mm equivalent is great for environmental portraits. The 7-14 is one of the best lenses m43 has to offer in my opinion. Sharp at every focal length corner to corner from wide open to f8. After f8 diffraction starts to affect sharpness but that happens with all m43 lenses. The unique perspective you get at 7mm can't be replicated by stitching and you can create some amazing shots if you get it right. I would take the oly 45mm f1.8 to complement it though just in case you want some closer people shots.
zilver
zilver OP
Thanks all for the great replies.
I guess it's still divided answer on whether the 14mm end can actually take family shots with the background view when traveling.
I tried the 9-18mm and not really happy with the sharpness so I returned it too quickly without actually testing out the focal length uses, mistake!
brentbrent
Senior MemberPosts: 1,738Gear list
The 14mm long end of the 7-14 isn't really that much worsethan the 14mm short end of just about every kit lens made.
Here are two snaps with the 7-14 that might be the type of shots you are contemplating, one at 7 (with some significant subject distortion, particularly the dog at left), and one at 14.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 7-14mm F4 ASPH +10 more
PSCL1
Senior MemberPosts: 2,975Gear list
To the OP:  Actually, the opinions are NOT equally divided if you count them up.  Many more of the comments say that 7-14 is NOT suitable because it is too wide and causes distortion.  The advocates of the 7-14 include it as part of a multi-lens travel ensemble and the examples given of use with family are atypical.
IMO, it is YOU who cannot decide and remain equipoised between purchasing the 7-14 or not.  You have the entire range of reasons provided to you, both pro and con.  We cannot make this decision for you.
 PSCL1's gear list:PSCL1's gear list
Leica X1 Nikon D80 Olympus PEN E-PL1 Panasonic Lumix DMC-G3 Sony Alpha NEX-3N +27 more
sigala1
Senior MemberPosts: 3,629
Thanks,
Don't you already own a lens that can do 14mm? Like the kiit lens that came with your camera? Why don't you use it at 14mm and find out for yourself?
sigala1
The 9-18mm is on par with other m43 lenses I’ve used. Sorry to disappoint everyone, but the m43 system is not the most optically perfect out there. I only discovered real sharpness after buying a Ricoh GR.
The 7-14 is probably going to perform worse on an Olympus camera than the 9-18mm, because although it may be a bit sharper, it has a lot more purple fringing plus weird issues with purple flare. So I hope you intend to use it only on Panasonic cameras.
EarthQuake
Senior MemberPosts: 1,814
Thanks,
The 7-14mm is essential in my travel kit, but I would never take *just* that lens, always a couple others like the 12-40, 75/1.8, or a few primes like 12/25/45 along with it in a small messenger bag.
When you need a lens like the 7-14, nothing else will do, but it isn't in any way a general purpose do everything lens. Its a specialty ultra wide zoom.
al_in_philly
Regular MemberPosts: 478Gear list
7-14mm for travel with pics
I always take my 7-14 with me when I travel.  When I was shooting 4/3 the Olympus Zuiko 7-14 was tons of fun, giving me unique perspectives unavailable with even a standard wide-angle lens; and now that I've downsized to m4/3, the Pany 7-14 continues to give me some of my most memorable shots when traveling.  Here's a few samples:
 al_in_philly's gear list:al_in_philly's gear list
Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 Leica Nocticron 42.5mm +1 more
JLTaylor
Contributing MemberPosts: 935
Re: mountain landscape example.
A few years I carried a 7-14 on a favorite hike (Ingalls Lake in the Cascades) and took the same scene at 7mm and at 14 and stitched.
7mm
Same time/location stitched version.
I am not a big fan of UWA for landscapes (exception is if you are going for large DOF). In the upper photo the clouds and larches seemed stretched in the corners.  In this case Mount Stuart is very close to Ingalls pass, but UWA's can easily make molehills out of mountains.
The stitched version looks more natural, even though it is much wider. Another advantage of shooting panoramas is you can use different projections.
To show why the UWA stretches the corners I mapped stitched version using rectilinear projection and did not crop.
JeanPierre Martel
Senior MemberPosts: 2,696Gear list
The Lumix 7-14mm is a super wide-angle lens. Invaluable in specific situations but quite specialized.
Its strong parallax effect can be corrected for landscape but it's harder for deformed human beings shot near the side of the frame.
In your message, it's not clear if you'll climb mountains or drive to them. If you climb, it's difficult to protect that lens from hitting rocks since it doesn't accept filters.
In a nutshell, if I were in your shoes, I'd bring the Lumix 7-14mm for landscape photo, but rely to another lens as my general-purpose lens.
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro +24 more
