Micro Four Thirds Focal Reducer Shootout
Started Feb 20, 2014 | Discussions
brian
Senior MemberPosts: 1,103
Feb 20, 2014
Since Metabones released the first general purpose m4/3 focal reducer in June 2013 several more products have appeared on the market. To my knowledge, there haven't been any systematic high resolution comparison tests of these focal reducers, so I decided to shoot a test chart and put together a matrix of 100% crops.
The matrix below shows 100% crops from the center, left side, right side, and all four corners of test chart images taken with a 50mm f/1.4 Nikon G lens (wide open) attached to: 1) the Light Cannon by Vizelex; 2) the Lens Turbo by Zhongyi; 3) the R.J. Focal Reducer; and 4) the Speed Booster by Metabones. The test chart used is a standard Resolving Power Chart available at low cost from Edmund Optics: http://www.edmundoptics.com/testing-targets/test-targets/resolution-test-targets/resolving-power-chart/1665 .  Note that the chart illumination wasn't perfectly uniform, and was a little brighter on the right side.  In each case, focus was adjusted for maximum contrast in the center of the field.  The camera used was a Panasonic G6.
DISCLAIMER:  I'm the designer of the Speed Booster optics.
Brian Caldwell
brian
brian OP
Shootout Part 2: Hotspotting
In reply to brian, Feb 20, 2014
In the second part of the focal reducer shootout I shot images of a back-illuminated soft box with a square patch of black gaffers tape taped to the front.  The lens used was the Sigma 18-35mm f/1.8 set to f/16.  The reason I used this lens is that its exit pupil varies substantially during zoom, ranging from 70.3mm at the 35mm focal length to 149.4mm at the 18mm focal length.  This is useful because hotspotting behavior is strongly dependent on the exit pupil distance.  Note that 149.4mm is an unusually long exit pupil distance, and most SLR lenses have an exit pupil distance less than 100mm.
Combined with the Sigma lens are 1) Vizelex Light Cannon; 2) Zhongyi Lens Turbo; 3) R.J. Focal Reducer; 4) Metabones Speed Booster; and 5) Sigma lens by itself with a plain adapter (no focal reducer).
In the case of the Lens Turbo and R.J. Focal Reducer the intermediate focal length position was chosen to show the worst instance of hotspotting.  This occurs when there is a sharp ghost image of the aperture stop.  For the m4/3 Speed Booster the worst hotspottiing occurs at the 18mm focal length position (exit pupil distance = 149.4mm).  Hotspots like this always occur in the middle of the frame because they are ghost images of the iris opening, which lies on the optical axis.
The Sigma 18-35mm lens by itself has very low ghosting, as shown by the two images in the bottom row.  Among the focal reducers, the Vizelex Light Cannon performs best because it has only a single optical element.  Unfortunately, this simple design also means that image sharpness is extremely poor, as can be seen in Part 1.
Brian Caldwell
zuikowesty
Senior MemberPosts: 1,656Gear list
Re: Micro Four Thirds Focal Reducer Shootout
Interesting, as I am just looking into this. But why no OM to MFT version?
 zuikowesty's gear list:zuikowesty's gear list
Olympus OM-D E-M5 Olympus Stylus Tough 3000 Olympus Stylus 5010 Olympus E-410 Olympus PEN E-PM2 +12 more
Jack Hass
Regular MemberPosts: 392Gear list
This is very much appreciated Brian. It is about what i have read, that Speed booster is the best by far, then lens turbo in 2nd, followed by junk. It is however nice to see it with my own eyes. I have debated picking up a SB and this eases my mind. For example the classic 50mm F1.8 offering from Nikon is very good and dirt cheap. With a SB it works out to be a 71mm F1.26 which is just fine for portraits.
Heyseuss Hoolio
Contributing MemberPosts: 538
Thank you for the tests and design.  The design has revolutionized mirrorless systems to be able to obtain radical lenses.
Kameraphil
Regular MemberPosts: 445
In reply to zuikowesty, Feb 20, 2014
I'm guessing: when there is a large number of users, there will be an adapter (as it needs to sell).
Although I'm originally an OM film cameras users, most of the legacy lenses I'm now using with my Micro 4/3 are Nikon. I don't  know if this is the case with other users.
OM lenses are a dying breed because there are no current SLRs to support them. I'm very sorry to say.
fraserhadden
Regular MemberPosts: 291
In reply to Jack Hass, Feb 20, 2014
Surely not. The SB increases FOV. Applied to the 50mm f1.8, it results in a 35mm f1.26 equivalent.
Fraser
Kameraphil
In reply to fraserhadden, Feb 20, 2014
I think Jack Hass is correct in relation to the M4/3 system, which this thread is about. "35mm x 2" is not far off 71mm.
Ulric
Senior MemberPosts: 3,221Gear list
In reply to Kameraphil, Feb 20, 2014
Only OM legacy lenses, because that's all I have.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
Lab D
Senior MemberPosts: 6,938Gear list
Lens Turbo
I have the Lens Turbo and can says the center is very sharp. I am sure the MetaBones adapter is worth the extra cost, but for anyone who only occasionally wants to shoot at very wide apertures, the Lens Turbo is a great low cost option.
 Lab D's gear list:Lab D's gear list
Panasonic Lumix DMC-FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
zuikowesty
Apparently those who paid very good money for my OM lenses don't know that...
But I imagine there is a bit more involved in making an optical adapter than just a mount adapter. But if the optics used are the same in each, it shouldn't take much to correct for flange distance, etc.
OM lenses are still the most compact and high quality available, and are a natural fit for MFT as a result.
Jack Hass
Fraser
Im talking about on my GX7, a MFT camera. (50mm x2) x.71=71mm. for APSC yes, it would be what the lens actually says, 35mm.
Jack Hass
woops, make that 50mm.
ApertureAcolyte
Contributing MemberPosts: 994Gear list
OM mount
So why did they make an FD speedbooster then? Contax/Yashica?
The OM mount makes more sense than any other mount. Metabones would have made more sales on the OM speedbooster than the C/Y.
 ApertureAcolyte's gear list:ApertureAcolyte's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GH4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 +1 more
Jack Hass
Re: OM mount
In reply to ApertureAcolyte, Feb 20, 2014
I think even though both FD and OM are no more, there are far more FD's out there due to Canon being a much larger user base, so it makes sense to sell to the larger audience. I agree they should have made both, but id imagine it has to be convincing before the R&D is started.
Tom Caldwell
Forum ProPosts: 24,448
Hot spotting - the cause?
Brian
Thank you for making these tests  it is appreciated.
I am always puzzled by the condition that creates these hot spots.  I have no proper technical knowledge of what causes the but I have tried to explain them on forums to the best of my understanding.  (For want of an alternative more knowledgeable source).  It seems that the "spots" are shown and commented upon but their technical reason for occurring remains a mystery surronded in optical jargon.
If I repeat my understanding here then you might be able to comment and confirm or advise differently.
My understanding is that back in the film days the film stock was not as reflective as modern sensors and therefore the reflection of a strong light source from the film and further re-relection back off some part of the lens glass back on to the film was less of a problem.  In fact some lens manufacturers did not particularly worry about it as inconsequential.  Different legacy slr lenses are therefore more prone to sensor re-reflection spots/smudges than others.
Sensor reflection can be bounced back via some flatter glass surface in the form of a aperture delineated circle if from an element located in front of the aperture or as a smudge if after the aperture.  According to some Canon literature even a flat filter lens surface can cause this reflection.  Canon seem quite proud that they have a meniscus protective front lens to prevent this re-reflection "unlike some of their opposition".  Canon's advice for those getting this hot spot on their esteemed telephoto range in extreme conditions was to try removing the lens filter.
I believe/think that good lens design can disperse this re-reflection before it is completely reflected back to the sensor surface.  You are to be congratulated as the Metabones product seems to have been designed to reduce or eliminate this re-reflection that happens in more extreme circumstances very well.
I also have to make a disclaimer so that readers might understand: I share your surname, but we are not related.  I have no commercial connection with Metabones nor any other Chinese focal reducer manufacturer.  I buy my own focal reducers, including a Metabones Speed Booster and several other Chinese made focal reducers for the Sony E-mount.  I have one RJ made M42 to M4/3  focal reducer adapter.  I am not suitably qualified to make exacting tests, nor do I have any optical knowledge other than what I have read.
Tom Caldwell
Tom Caldwell
Re: OM mount
Ask Brian?  The oracle started this thread, otherwsie we are just flapping our keyboards.
I don't know but I think that there are some bits that stick out of the back of OM lenses that complicate matters.
Tom Caldwell
amtberg
Veteran MemberPosts: 5,519
Re: Hot spotting - the cause?
In reply to Tom Caldwell, Feb 20, 2014
I'm not sure if it's the same thing as the so-called hot spot phenomenon, but I've definitely seen problems with filters reflecting back the sensor with MFT.  That's the main reason I stopped using UV filters, which I always employed when I shot Canon DSLRs.
brian
brian OP
Tom Caldwell wrote:
Brian
Tom Caldwell
Hi Tom:
Central hotspots are a ghost image of the aperture stop.  The visibility of the ghost image depends on the magnification of the ghost image (smaller means brighter), the amount of aberration in the ghost image (less aberration means a more pronounced ghost), and the efficiency of the lens coatings.
Brian Caldwell
brian
brian OP
Re: OM mount
Tom Caldwell
I would like to see Metabones come out with an OM version.  However, I'm not directly affiliated with the company so I don't know what their plans are regarding this.  I do recall that some of the OM lenses presented more of an interference issue than other brands such as Nikon.
Brian Caldwell
