my 5d ii suddenly died!
Started Feb 18, 2014 | Discussions
wardayaa New Member • Posts: 1
Hey all..
I need ur opinion about what happened to me
I bought my 5d ii 2 years ago
After using it by 2-3 months usb port stopped working .. and when I searched about this problem I found out that I have to replace all the board which will cost a lot ... so I decided to live with not-working-usb issue ..
And now .. after 2 years ... (in the middle of my trip to china) the camera suddenly stopped working ... I switch it on.. and its not responding ..
I removed CF card..lens.. grip.. batteries ... I fully charged the battery... and nothing happened at all.. still dead .. with no any responses ..
I sent it to canon service center here in Beijing yesterday
They called me today
And the first thing he said "the camera is not connecting to computer"
I replied "yes it was working fine for 2 years.. is it about the board now?"
He said "yes u need to change it.. and the shutter unit too"
I asked him to think about it and call him back ..
But I'm not sure guys if the reason is mainly from the board because the first thing he said "its not connecting to the computer" so he is just wants to change the board for that and he is trying to convince me that its not working because of it?
And what about the shutter unit? Is it necessary to cchange it?
I need to know what is the reason that made tge camera failed! And they don't speak English well!!
Any advice please? ??
hotdog321
hotdog321 Forum Pro • Posts: 15,763
Re: my 5d ii suddenly died!
I used two 5D II professionally for years until last month and never had a hit of trouble-- (49,000 clicks on each camera). Bummer that it cratered like that--unusual. Sorry that I don't have a clue why it failed.
But I would check how much the shop is charging for the repair. Might be more cost-effective to buy a refurbished 5D II or new 6D.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
24Peter
24Peter Veteran Member • Posts: 3,047
I had to have both the main circuit board and shutter unit replaced on my 5DII. Fortunately, the circuit board was repaired under warranty. The shutter OTOH was out of pocket, but with my CPS Membership and a lot of complaining (the camera only had 30K clicks), I paid only about $120.
hotdog321
Wow--cheap fix!
Abu Mahendra Senior Member • Posts: 4,011
Replacement shutters are not terribly expensive...I once had the rear element of a 135L replaced at Canon Singapore for about $150.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 70-200mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 40mm f/2.8 STM +4 more
