Is there something wrong in getting an inexpensive lens mount adapter?
Started Feb 18, 2014 | Questions
mistermejia Senior Member • Posts: 3,340
Could an inexpensive $15 dollar lens mount adapter damage my XE1 or my nikon lenses?
If not I'm ready to hit the purchase button at Amazon
http://www.amazon.com/Fotasy-AFNK-Fujifilm-Camera-Adapter/dp/B007YPED8O
Thanks!
 mistermejia's gear list:mistermejia's gear list
Fujifilm FinePix S5 Pro Fujifilm X-E1 Nikon AF-S DX Nikkor 35mm f/1.8G Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Fujifilm XF 35mm F1.4 R +6 more
Fujifilm X-E1
taz98spin Contributing Member • Posts: 526
Re: Is there something wrong in getting an inexpensive lens mount adapter?
Nothing wrong with getting a cheap lens adapter.
But the OM to X mount adapter I got off of Amazon wasn't cut right? or something, because when I mount my OM lenses on they shake.
 taz98spin's gear list:taz98spin's gear list
Fujifilm X100S Fujifilm X-Pro1 Olympus PEN E-P5 Fujifilm X-T1 Sony Alpha 7S +8 more
nick_webster
nick_webster Veteran Member • Posts: 5,565
No
I've had lots of cheap adapters over the last 5 years and all of them did the job I asked of them. They might not have been as well built as the ones that can cost 10 times as much but I didn't care, they worked
Nick
darngooddesign Senior Member • Posts: 4,696
It's only $15. Try it and return it of you don't like it. But remember that with optics, you often get what you pay for.
 darngooddesign's gear list:darngooddesign's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8
ripleysbaby Contributing Member • Posts: 811
I have 2 cheap adaptors and a good one.
The cheap ones at a sloppy fit both ends and to be honest, it's not a pleasant experience to use them.
The good one. A Kipon. (£55.00) is as good a fit as you could wish for.
Expensive or cheap. When you first get one put it on and take it off the body several times with the adaptor facing the floor. Just in case paint or even metal gets dislodged.
Then do the same with the lens.
 ripleysbaby's gear list:ripleysbaby's gear list
Ricoh GR Sony Alpha 7R Panasonic Lumix DMC-GX8 Panasonic 12-35mm F2.8 Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
mistermejia OP Senior Member • Posts: 3,340
Very good tip ripleysbaby! Thanks for bringing that up.
Al Valentino Senior Member • Posts: 4,668
I have four adapters, 3 from Rainbow Imaging (Nikon, Tamron adaptall and Voigtlander screw mount), all fit perfectly and cost me $10 - $15. The nikon version is for lenses with aperture rings so less expensive than my Fotodiox, Nikon G to Fuji X adapter which cost about $40
So I can highly recommend Rainbow Imaging , in NY, from their website or ebay. I also purchased a set of spare caps (rear lens and camera) from them (under $10 for a set) which fit perfectly.
Fuji Silver XE1 w/14, 35, 18-55, 55-200, Rokinon 8mm Fisheye & Tamron 90mm f/2.8 Macro
 Al Valentino's gear list:Al Valentino's gear list
Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Rokinon 8mm f/2.8 UMC Aspherical Fisheye +6 more
Birse Boy Regular Member • Posts: 328
I got a Pixco adaptor off ebay for £15 for my XE1 / Rokkor lenses - works a treat, well made to boot
farnorthfocus
farnorthfocus Forum Member • Posts: 86
I suppose it depends on how much you value the lenses you are going to use with it !
Just a thought.
visit www.farnorthfocus.co.uk
 farnorthfocus's gear list:farnorthfocus's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm XF 18mm F2 R Fujifilm XF 14mm F2.8 R Carl Zeiss Touit 1.8/32 +6 more
WT Jones Senior Member • Posts: 2,495
I have to agree with Al, the Rainbows are pretty decent adapters for the money. They tend to be a bit loose on the rotational axis, but not so they effect usability. I have Eos-X, Minolta MD-X, canon FD to X and a Konica AR to X mount Rainbow adapters & they all work really well.
I also have two Metabones adapters Nikor-F and Canon FD to X  and one speed booster FD-X. These are very well made, but somewhat expensive.
Warren
Les Lammers
Les Lammers Veteran Member • Posts: 3,052
Peruse ebay and see what is there. There are good descriptions on the items. With good glass I'd not go too cheap.
 Les Lammers's gear list:Les Lammers's gear list
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X-E1 Fujifilm X-T10 Fujifilm XF 18mm F2 R +5 more
gerard boulanger Senior Member • Posts: 2,262
NO n/t
No text.
 gerard boulanger's gear list:gerard boulanger's gear list
Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 27mm F2.8
jeffsvisions
jeffsvisions Senior Member • Posts: 1,631
i use several of these on my Samsung camera never had a problem . no sure about fuji camera . i only have the x10 for now.
The best picture is the one you take.
Jeff
 jeffsvisions's gear list:jeffsvisions's gear list
Fujifilm X10 Fujifilm X-S1 Fujifilm X20 +2 more
tr4driver
tr4driver Contributing Member • Posts: 516
Thanks!
I don't think is will hurt anything, but it may or may not fit as well as a more expensive mount.  I have a cheap Nikon to Fuji mount from Rainbow Imaging, and there is noticeable play between the lens/mount/body.  I also have a high quality (and expensive) Rayqual Leica to Fuji adapter.  It obviously has a much higher fit and finish and has no play what-so-ever.
That said, the cheap mount still works, but the lens will turn ever so slightly whenever I go to focus.  It's kind of annoying and if I really used it that much, I would replace it with a better one.
Kurt
jkspepper Contributing Member • Posts: 544
No. I use one
PenPix Senior Member • Posts: 2,237
No. But….
You roll the dice when you buy a cheap one.
I picked up a Polaroid branded one off Amazon and the fit on a few of my Nikon lenses are so tight that I couldn't turn the aperture ring.  If I tried using it as-is, I could see a potential for damaging my lenses.
Since shipping it back was more than half the price of what I paid for it, I decided to rebuild it to make it fit.  It's not bad now, but I'll probably shave a little more from the barrel to make it perfect.  Regardless there is no sloppiness in the fit (before and after my adjustments) and it seems reasonably centred.
I would buy one of the cheap ones recommended by other posters since they have had good success with them.
LaFonte Senior Member • Posts: 2,744
Thanks!
I got once Nikon lens to canon adapter and it was so tight that I had really hard time to get it off the lens. Really, really hard, I almost thought it will be permanent. It did work, but I would really go for middle ground from reputable "brands". If it is too cheap it may be really hit or miss.
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
hellocrowley Senior Member • Posts: 1,271
Thanks!
There can be a number of problems: inability to focus at infinity, tilted focal plane, fit is too tight or too loose. I use a cheap adapter with my portrait lens because those problems wouldn't be noticeable at max aperture.
