FE 16-35mm f4 UW zoom
Started Feb 18, 2014 | Discussions
Donny out of Element here
Contributing MemberPosts: 974Gear list
Feb 18, 2014
is rumored to be announced in a month or so. I was wondering if I can start using FE lenses on APS-C body (A6000), so that in future (when I go FF) I will have FF lenses ready to go.
I was wondering to use that 16-35 f4 as my main zoom actually, since it will be 24-50mm (in APS-C) on my A6000 - which is the focal range I use most often (mostly 24-35mm in APS-C).
So my question is how big this zoom may be or how small? I was hoping for OSS, but it won't have it probably? Do I need it on that FL anyway? I also hope this time Zeiss will make sharp zoom across the frame, not like FE24-70, where 24-28 range is soft on edges and corners.
Sony a6000
Richt2000
Senior MemberPosts: 2,900Gear list
Re: FE 16-35mm f4 UW zoom
In reply to Donny out of Element here, Feb 18, 2014
I was wondering to use that 16-35 f4 as my main zoom actually, since it will be 24-70mm (in APS-C) on my A6000 - which is the focal range I use most often (mostly 24-35mm in APS-C).
So my question is how big this zoom may be or how small? I was hoping for OSS, but it won't have it probably? Do I need it on that FL anyway? I also hope this time Zeiss will make sharp zoom across the frame, not like 24-70, where 24-28 range is soft on edges and corners.
16-35 in FF would have an equivalent Field of view of 24-52.5, not 70mm
An F4 of this nature will be roughly the same size as Canon's 17-40 L or Nikon's 18-35G 3.5-4.5
Unless they can perform some magic  or compromise on IQ
But yes, you are right, hopefully it will become a high quality mid-range zoom for APS nex cameras too
 Richt2000's gear list:Richt2000's gear list
Sony RX100 Olympus OM-D E-M5 Sony Alpha 7R Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Canon EF 70-300mm f/4-5.6L IS USM +9 more
123Mike
Senior MemberPosts: 4,643
I don't that this translation is correct. I have multiple full frame lenses, Minoltas, that I'm using on my A57 APS-C "crop" camera. The way I see it, is that full frame gives you a rim around an APS-C shot. But a full frame lens at 28mm, say, is going to provide the same result as a 28mm from the crop kit lens. I don't know about this new lens that's coming up, but if it's a full frame 16-35 that's a pretty darn wide angle lens on a FF camera. But it'd only be half a kit on a crop camera. That 35 remains 35, and it does not magically double or anything else like that.
However though. It might be a *really* sharp lens, which means, lots of cropping power! And on a 24mp sensor like the A6000, it means being able stretch things quite a bit.
As for OSS... I'm starting to think it's a little bit overrated. I use bursting a lot to achieve better shots. So, burst a lot. The A6000 does 11 fps bursting. That's very high. Combine that with software that lets you quickly lift out the sharp ones and discard the blurry ones, and bursting becomes your friend. OSS might screw up at time too, so, you'll reduce that. Although mind you, the in lens OSS might be a *lot* better than the IBIS of the SLTs which is where I'm coming from.
Re: What kind of SW do you use?
In reply to 123Mike, Feb 18, 2014
for automatically selecting sharpest pics from series of bursts? Can it then automatically delete not sharp ones? Is that something you would run before any PP SW like LR? Thanks.
Re: Thanks. I corrected it.
In reply to Richt2000, Feb 18, 2014
of course 24-50 not 24-70.
Richt2000
OSS
The OSS in the 24-70 is AMAZING.
Far better than Canon's IS on the 24-105 L, i'd dare a guess to stay one or two stops better
With the sony I am getting tack sharp
Images hand held at 50mm and 1/10s
Well, the centre anyway, the corner softness is no fault of the OSS
Oh-oh. I was hoping it would be smaller Those lenses are kinda huge for A7/R IMHO.
seachicken2000
Veteran MemberPosts: 3,128Gear list
I'd never thought of it like that... this would be an amazingly useful lens for me on an A7r.
In APS-C crop mode, it's a 24-52.5mm f/4 standard zoom, and since it's a FF lens it should be consistently sharp across the frame. 15.5 M pixels will do just fine for a travel zoom, which is what it would be for me.
Flip the camera into full frame mode, and it's an ultrawide zoom lens, and here I'd want to use the full resolution of the sensor.
Add the 55mm f/1.8 (a world-class fast standard prime used FF, and a capable short portrait prime when used APS-C) and all my regular focal lengths are there, in just 2 lenses!
I am not sure it needs to be enormous due to the short flange distance.
A rose by any other name is still a chicken.
http://500px.com/seachicken
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony Alpha 7R +18 more
LBJ2
Senior MemberPosts: 1,082Gear list
Donny: For what's its worth, I am using APS-C and FE lenses interchangeably on both my Nex 6 and A7r w/ no real issues so far and in some cases even a surprise--like being able to use the SEL 10-18 in Full Frame mode on the A7r This lens is really wide on the A7r.  I "think" the same E-mount interchangeability for the A6000 is the plan.
 LBJ2's gear list:LBJ2's gear list
Sony a77 II Sony Alpha 7R II
Richt2000
10-18mm e mount
In reply to seachicken2000, Feb 18, 2014
You may as well shoot at 36mp all the time and then just crop afterwards to give you more choice later, although as a compositional tool, this picture taking method works - just like digital zoom on compact cameras.
However, a real advantage of the way you are thinking is how I am using the e mount 10-18mm at the moment.
I have the Nikon G 18-35 with Novoflex for Tripod work, FF 36mp
I have the 10-18 with OSS for light, OSS equiped walkaround for 15-27mm at 15mp when I don't need the resolution. Save me cropping off the vingetting back at the ranch.  When I pick up the A6000, I'll keep the 10-18 on the A6000 for 24mp walkaround and the 24-70 on the A7r.
However....
the 10-18 is a very usable 13-16mm Ultra Wide angle at 36mp full frame with very good IQ at 14mm.
If you want to be really perfectionist about IQ, you can always shoot in FF mode and crop the extreme corners off to end up with a 28-30mp image, the lens at 14mm will give you a Field of view of 15-16mm and be pretty much on par with Canon's 16-35ii in the corners
123Mike
I used to develop image processing software. I can envision writing an algorithm that compares a shot with a unsharpened shot of itself, and perhaps that way measure sharpness. Or else I'll borrow a sharpness algorithm off the net somewhere. My plan has been for a while now, to create a slideshow / organizing software so this would be one of its features.
123Mike
Re: OSS
I'll have to look for that, sounds exciting.
How often though? Can't be consistent can it? That'd be quite an achievement!
I'm picky with lenses. This why I'm avoiding the 16-50 and picking the older 18-55 instead.
zither
Regular MemberPosts: 211Gear list
I have very high expectation of this UWA lens. It will be the decision factor that I'm staying with my Sony A7 or not. I don't mind if it's a bit pricey, say like $1500, but I DO mind the size and IQ. I expect the size to be no larger than FE 24-70 and IQ at least outperform the canon 17-40L. IMO the FE 24-70 is a bit disappointing based on all reviews I've seen so far.
 zither's gear list:zither's gear list
Sony Cyber-shot DSC-RX100 IV Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +1 more
S3ZAi
Contributing MemberPosts: 885Gear list
In reply to zither, Feb 18, 2014
I'm not so sure, but I'd rather have a zoom with less reach that's a bit faster and have better IQ. Wouldn't something like 16-28 F3.5 or perhaps even F3 give better results and be easier to design? I think most people would buy this lens for the WA side and if you want to shoot at 35mm, the also announced 35mm 1.4 fast prime would be a far better choice anyway. I even wouldn't mind a 16-24mm lens if it would have some speed, like 2.8, then it would be usable for handheld indoor shots of churches or train stations and such. I think F4 is just way too slow,
Sezai E., philosophy geek, bibliophile and creative photographer.
Cheers!
 S3ZAi's gear list:S3ZAi's gear list
Sony Alpha NEX-7 Sony Alpha 7R Sony E 35mm F1.8 OSS Sony FE 55mm F1.8
rponiarski
Regular MemberPosts: 212Gear list
For some of us, OSS is a necessity. One thing I miss from my old E-M5 is the IBIS. I personally need as much stability as possible due to having idiopathic familial tremors, one reason that I still use the 28-70mm kit lens. I hope the 24-70mm Zeiss is a bit better, but the OSS is a big plus for me.
Richard M. Poniarski
Not a speaker for anyone but myself.
"Everyone is entitled to the reality of their own choice"
 rponiarski's gear list:rponiarski's gear list
Olympus PEN E-P2 Olympus PEN E-PL1 Olympus PEN E-P5 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Sigma 30mm F2.8 EX DN +4 more
seachicken2000
Re: 10-18mm e mount
In reply to Richt2000, Feb 19, 2014
Yes, I really wish Sony (or an app developer) would implement a software zoom for the A7r that would work with RAW, just to aid composition. The camera has pixels to spare, and being able to zoom something like the 55mm f/1.8 continuously from standard to short portrait focal lengths, would be great.
What you'd effectively have (in FF terms) is a 55-85mm f/1.8-2.8 zoom lens with prime lens sharpness and rendering.
I'd settle for cropped RAWs (like we have in APS-C crop mode now), or better still the full resolution RAW (perhaps with the crop embedded in the metadata), or ideally both.
This is also very interesting as I own the 10-18mm, and use it a lot. I know it can cover the full frame quite well, but I wouldn't have expected much in the way of corner sharpness. Looking forward to giving it a go!
EinsteinsGhost
Forum ProPosts: 11,977Gear list
In reply to Donny out of Element here, Feb 19, 2014
Sony did a good job on 10-18/4 for APSc. The FE UW zoom will be larger but shouldn't be anywhere close to the DSLR lenses (including Sony's own 16-35/2.8 SSM Zeiss on A-mount). It will be over a grand though (in line with FE24-70 if not FE70-200).
Sony Cyber-shot DSC-F828 Sony SLT-A55 Sony Alpha NEX-6 Sigma 18-250mm F3.5-6.3 DC OS HSM Sony 135mm F2.8 (T4.5) STF +12 more
123Mike
In reply to rponiarski, Feb 19, 2014
That's in-lens OSS, which is more of a sure thing. IBIS "super steady shot" or whatever the heck it's called, I found always kind of iffy. It's like it's there, but like it's not there also. I kind of maybe is doing something perhaps, kind of thing...
abortabort
Senior MemberPosts: 1,673Gear list
Nah it will be smaller than the 17-40mm. Look at the 24-70mm OSS FE vs Canon 24-70mm f4 IS L as a guide to the size difference.
 abortabort's gear list:abortabort's gear list
Sony RX100 Fujifilm X100S Konica Minolta Maxxum 7D Leica M8 Nikon D700 +54 more
abortabort
Re: OSS
In reply to 123Mike, Feb 19, 2014
Sure why not? I can quite easily hand hold the RX10 @ 200mm equiv down to 0.8 seconds. That's not 1/8th, but 0.8sec @ 200mm - For those playing at home that's 8 stops of stabilisation! Ok not every shot, but still comfortably good averages. 1/10th is a cakewalk with the RX10 at any FL, so this 'shouldn't' be a problem with a short range zoom like the 24-70 OSS.
