G1X Mark II - What is with the screen??
Started Feb 17, 2014 | Discussions
Dave92F1
New MemberPosts: 16Gear list
Feb 17, 2014
You can't tell from the photos here on DPR, but the screen on the G1X Mark II is not the usual Canon "Vari-angle" - it's a new thing that only tilts up-and-down, not left-and-right.
What is with this? I think it's a huge downgrade from the vari-angle design, which let you nestle the camera tight against your belly for stability (like an old medium-format camera).
I always open the screen to the left, so I can see it with the camera braced against my body - it looks like that won't work anymore!
I'm a huge fan of vari-angle, I've had 4 or 5 cameras with it. And I tried the Sony R1 years back and got rid of it because it had a similar up-and-down-only flip screen.
What is Canon thinking?
 Dave92F1's gear list:Dave92F1's gear list
Canon PowerShot G12 Panasonic Lumix DMC-FZ200 Canon EOS 60D Pentax Q Google Nexus 4
linzybel
Regular MemberPosts: 435Gear list
Re: G1X Mark II - What is with the screen??
In reply to Dave92F1, Feb 17, 2014
I think we'll have to wait and see how it works in practice.  I suspect they thought the flip screen was used mostly for 1) selfies, 2) overhead crowd shots, and 3) ground level macro shots, all of which would be available or maybe even better in the new design.  They didn't stop to think about your type of "waist-level" viewing.
I also suspect that they decided a two-point hinge would be stronger (and maybe lighter) than the traditional tilt-swivel.
Dave92F1
In reply to linzybel, Feb 17, 2014
The vari-angle design does all those things just fine. And I've never had a problem with fragility.
phazelag
Veteran MemberPosts: 3,003Gear list
Canon Explained why
They explained why in a video or the PDF going around. I think it will be fine. I think they Canon guys said it allowed for a smaller camera.  Not sure why that is but I don't they would make it up.
 phazelag's gear list:phazelag's gear list
Panasonic Lumix DMC-LF1 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-FZ1000 Fujifilm XQ2 Olympus E-M1 +4 more
Marco Nero
Veteran MemberPosts: 4,347Gear list
Bad Design Decision...
Canon made a BIG mistake in not using the Vari-Angle LCD.  Part of this MIGHT have something to do with the new screen being a touch-screen.
Unfortunately, this design (if you look at the second GIF image) exposes the electrical wires when the LCD is fully extended.  BAD design.
Marco Nero.
www.pbase.com/nero_design
 Marco Nero's gear list:Marco Nero's gear list
Canon PowerShot S95 Canon PowerShot G1 X Canon EOS 60D Canon EOS 5D Mark III Canon EOS M +9 more
phazelag
Re: Bad Design Decision...
In reply to Marco Nero, Feb 17, 2014
Marco Nero.
I tend to agree with you.  It definitely seems like a step back.  I have two fully articulated screens that I love.  But I have seen Sony, Olympus, and Canon choose this type and I have recall hearing that this allows thinner design from all of them.  I think it will meet my needs fine, but it does on the surface seem less durable or more prone to damage.  But I will wait and see.  I am sure they had valid reasons. I don't think their goal was to disappoint.
Tonkotsu Ramen
Senior MemberPosts: 1,772
This design is already used on a lot of cameras. It works for me, but then I didn't have the G1X.
unknown member
(unknown member)
Engineers can't win.
At least that tends to be the default position people (non-engineers) take when they don't like something.  It makes perfect sense and is perfectly understandable, but if you were part of a team that exhaustively designed, tested, and redesigned a complex system that was greatly influenced by the need to balance one consumer demand with another consumer demand I think you might take it a little easier on the poor designers.
It is actually very obvious from the photos on DPR as well as videos, press material, etc etc.
Yeah, I seriously doubt there was a lot of importance placed on the very few people who shoot this way.  I'd call that a very non-standard method and also not one that was important enough to completely change the design strategy.
You are not the only person in the world who might buy this camera, but I'd bet you could adjust your strategy if you need to and, if not, I'd bet there are many other cameras for you to choose from.
Take your articulating LCD camera out and start trying to pretend like the LCD is a touch screen and make some changes to your settings.  You're putting stress on the hinge and you're also most likely changing the orientation of the screen, and making that hinge stiffer to resist people who push buttons harder than necessary is probably not feasible.  Also, compare how thin this assembly is to a standard articulating LCD.  The truth is that considering what this touchscreen is designed to do it takes care of many, many shooting situations.  Oh, and if Marco thinks some exposed wires is such a horrible design I really think he needs to apply for a job engineering for Canon.
 howardroark's gear list:howardroark's gear list
justmeMN
Senior MemberPosts: 3,125
Re: Engineers can't win.
In reply to howardroark, Feb 17, 2014
It seems to me that non-engineers (management/marketing) tell engineers what they want them to make. The decision are made by management, and the design execution is done by engineers.
Marco Nero
From the Canon G1X User Manual...
In reply to phazelag, Feb 17, 2014
If it was good enough for the G1X, it should have been good enough for the G1X Mk2.
Marco Nero.
Rally Man
Regular MemberPosts: 499Gear list
Re: From the Canon G1X User Manual...
Marco Nero.
Funny I had a screen protector on mine since day one so I'd never had to close to screen face inward.  I really don't see this as an issue.  You can get screen protectors and your good to go.
 Rally Man's gear list:Rally Man's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR
phazelag
In reply to Rally Man, Feb 17, 2014
Marco Nero.
I like to close the screen for shooting theater performances.
www.scottzinda.com
http://instagram.com/phazelag
http://motivationmachine.net/
boogieboogie
Regular MemberPosts: 198Gear list
I for one am very happy they switched to the tilt mechanism. Perfect for operating your camera like a medium format camera with a simple flick to open the screen to 90 degrees and snap shut when I stop shooting. Saves having to unfold it and flip it round each and every time.
This is how I've always used my NEX and find it very comfortable.
You wouldn't use it with the screen opened out on its arms like the photo suggests, this mechanism just gives the screen a hinge point at the bottom as well as the top so allows the screen to flip at least 90 degrees down aswell as a 180 degree flip up. So the wires aren't exposed any more than they are with olympus or sony cameras - which I've never heard anyone having any problems with. In fact I imagine they are more sturdy as the wiring loom isn't getting the twisting stress aswell as flip.
Anyway it's just a matter of changing your technique and there seems to be just as many people who prefer a slimmer camera with no articulation as those that prefer articulation so from a marketing point of view it seems like a good compromise.
Rally Man
phazelag wrote:
Marco Nero.
www.scottzinda.com
Well you could still buy the EVF and have the screen off, but sucks that you would have to spend another $300 to do that.
unknown member
(unknown member)
In reply to justmeMN, Feb 17, 2014
Of course there is a back and forth, but you and I are not in possession of the details involved in that complex process.  Management could have very easily said that a touchscreen was a requirement and the engineers came back with "okay, but if you also want an articulated screen we can't use the old side hinge that rotates because it can't be made stable enough to resist constant force."  Who knows.  If engineers got to built whatever they wanted you'd live in a world of gadgets nobody would want to use because engineers want things made for people are technically minded and aren't bothered by confusing control interfaces that may be perfectly efficient but not terribly intuitive.  Oh, and most engineers don't have a clue about making things that have to be used by a lot of normal people, so some of them do need to be forced out of utilitarian thinking and into aesthetic and simple design strategies.
jonrobertp
Forum ProPosts: 12,330Gear list
In reply to boogieboogie, Feb 17, 2014
Indeed. No articulation... save a few $ and a few ounces... would have been my preference and likely others, but maybe not the majority.
 jonrobertp's gear list:jonrobertp's gear list
Sony Cyber-shot DSC-HX50V Canon PowerShot G7 X Canon PowerShot G3 X Canon EOS 70D
peter42y
Senior MemberPosts: 2,181Gear list
In reply to jonrobertp, Feb 17, 2014
I have a Sony DSLR A500 with that type or articulating screen ( the one in the G1X M2 ) , and it does work fine.
Its very handy.
 peter42y's gear list:peter42y's gear list
Ricoh Caplio R8 Canon IXUS 310 HS Nikon 1 V1 Canon EOS M
Marco Nero
The problem with screen protectors...
But the Mk2 has a touch screen.  Canon do not recommend the use of a "screen protector" with touch capacitance screens because it affects the use of the device.  Too many people complained over the EOS-M touch screen when using screen protectors.  It also hampers vision.
Marco Nero.
panamforeman
Contributing MemberPosts: 987Gear list
I admit I would be happier if Canon had kept the fully articulated screen, but they didn't. I'm still excited about the G1X MkII and plan on buying one.
I'm also pleased about the EVF. I know I'll get that. $300 extra tho does give me pause. I'll get the camera first and wait on reviews of the EVF, even tho I know I'll eventually get it.
 panamforeman's gear list:panamforeman's gear list
Canon PowerShot S120 Panasonic Lumix DMC-ZS100
Tonkotsu Ramen
Re: The problem with screen protectors...
I've had screen protectors on every touchscreen phone I've ever owned, and my eos-m. No issues with viewing or operation
