X-T1 jpg quality question
Started Feb 17, 2014 | Questions
seukel Regular Member • Posts: 496
This is a question for those who already have the camera. As the X-T1 has the same sensor and jpg engine as the X-E2 and X100s I suppose it is also prone to show those waxy smoothened skin tones, that many disliked. Or does it behave differently?
Peter
Education is an admirable thing, but it is well to remember from time to time that nothing that is worth knowing can be taught.
Oscar Wilde
 seukel's gear list:seukel's gear list
Leica D-Lux (Typ 109)
Fujifilm X100S Fujifilm X-E2 Fujifilm X-T1
Ed B
Ed B Veteran Member • Posts: 7,597
Re: X-T1 jpg quality question
5
Peter
Oscar Wilde
I don't own either camera, I have an X-E1 but I wish someone would post some examples, with EXIF data, of this waxy skin tone problem.
I'm not saying anyone is being overly critical, of the new cameras, but find it hard to believe that Fuji JPEGs would have this problem and sometimes wonder if people aren't simply repeating an opinion that isn't shared by the majority.
Seems like any post, where an individual has a problem, turns into a slam about Fuji.
I'd almost bet that if I posted that my camera had a paint chip, there would be 20 people who would chime in and say the paint job on Fuji cameras was inferior to X, Y, Z brand.
Naturally, I could be 100% wrong about the waxy skin issue but I, personally, have never seen a sample, with EXIF data, posted.
LaFonte Senior Member • Posts: 2,744
Peter
Oscar Wilde
I don't have x-t1, but I am 100% sure if you dislike output from X-E2 you will not like the X-T1 as it will be exactly the same.
 LaFonte's gear list:LaFonte's gear list
Fujifilm FinePix X100 Panasonic Lumix DMC-FZ1000 Fujifilm X-Pro1 +1 more
seukel OP Regular Member • Posts: 496
Ed B wrote:
Peter
Oscar Wilde
Well, as someone wrote elswhere, the waxy skin phenomenon "has been shown time and time again, and it used to be talked about a lot more, but I think those that complained finally just moved on from Fuji, while the others that stuck with Fuji don't mention it much anymore", and probably mostly use raw. Or they moved back from the X100s to the X100, if they prefered jpgs.
It's a pity that the X-T1 has the same kind of output.
Oscar Wilde
eye specs Regular Member • Posts: 204
Here is a post at 3200 showing waxy skin from excess nr.
I hope this is helpful as the sort of side by side comparison of x e1 vs xe2/xt1 jpeg noise reduction issue that is of concern to some: http://www.dpreview.com/forums/post/53132928
I do not have not read enough posts to form an opinion and yet it seems that people are divided with some seeing it clearly as in this example and others not. Presumably it is a firmware fixable issue and therefore if real you have reasonable reason to hope that fuji will announce a nr off option for the later cameras. eyespecs.
Re: Here is a post at 3200 showing waxy skin from excess nr.
Thanks, a "good" example. The problem has been around since the X100s arrived. No firmware fix up to now at least
Oscar Wilde
(unknown member) Regular Member • Posts: 362
Peter
Oscar Wilde
I thought the same thing and shot happily with an xe2 until getting my hands on an xe1 last week . It's pretty obvious doing a side by side and I posted that example linked above.
I don't see how fuji let it slip by but I am willing to wait for a fix as they've done so many other things right and the raw files are unaffected. I don't often shoot critical portraits at ISO 6400 anyways as usually when you have to go that high the light will be terrible anyways and a hi ISO shot won't really save it. My opinion anyways. Pre ordered my XT1 yesterday and if I need hi ISO portraits my xe1 will always be with me as a backup body
Graham Hill Senior Member • Posts: 1,355
Ed B wrote:
Peter
Oscar Wilde
This phenomena has been shown in great detail, over and over and over again.  The X-E2 shows sledgehammer amounts of noise at higher ISO values which is dramatically destructive to skin.
You can continue to deny it exists, or do basic research here and find it for yourself.  I dont even care about this issue and still have managed to see a half dozen examples in various threads here.
Ed B
All I'm seeing here are two extremely poor quality pictures. Yes, the X-E2 picture does look like it has more noise reduction applied but both shots are so bad that neither one represents anything other than shots taken by a person who doesn't know anything about photography.
I know that sounds a little ruff but let's get serious.
Ed B
I'm not going to disagree with you but I've still not seen any good examples of this so if it has been shown "in detail, over and over again" I must have missed it.
Granted, it has been talked about in great detail.
Astrophotographer 10 Senior Member • Posts: 6,682
There is no link to an example image in your post.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony Alpha 7R II Sony FE 55mm F1.8 Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +4 more
There was a fantastic image shot by someone here who overlayed an X-E2 shot on top of an X-E1.  The shot was of someone's hand and it showed clear as day the sledgehammer noise reduction that the X-E2 uses at very high ISO values.
One look at this single image and that is all that you need to know.
I wish I bookmarked that image.
Ed B
Yes, I've seen that.
Now let's see some properly exposed portraits with white balance properly set.
I'm not denying that the X-E2/X-T1 may use a more heavy handed noise reduction at ISO 6400 and above but I still haven't seen real life portraits that show "waxy" skin tones.
Heard a lot about them but would like to see real life examples from a photographer.
Randy Benter
Randy Benter Veteran Member • Posts: 3,145
I don't understand what you are expecting to see. Do you not know the difference between test shots and photography? The example images were shot using the same exposure and they are perfectly suitable for showing the different noise handling of the two cameras. The artistic value of the images is completely irrelevant. Do you think the noise reduction algorithm will magically change if the camera is held by an artist?
 Randy Benter's gear list:Randy Benter's gear list
Fujifilm X100T Nikon D7200 Fujifilm X-T10 Carl Zeiss Touit 1.8/32 Apple Aperture +18 more
Ed B
No Randy, I think people are over reacting and owe it to themselves to get a little more information before they talk about waxy skin tones.
People could go to a site like Pbase.com and do a search for the X-E2 camera and look at some of the high ISO pictures of people.
Granted, there aren't a lot of ISO 6400 and above portraits taken by photographers but the few I've seen look pretty good.
Example: http://www.pbase.com/image/153840223
No you havent.  The image I'm talking about was perfectly exposed.
Robert Garcia NYC Senior Member • Posts: 1,765
If you can't see the skin softening being applied your images that's great for you but lots of other folks don't like that treatment applied and I also think it can be an easy firmware fix maybe to adjust it or turn off.
That one example is good but it could have been processed in raw we are talking about jpegs.
mbb101 Junior Member • Posts: 41
The simple truth is the test is extremely easy. You take a portrait at iso 6400 in raw + jpg and output the raw in your favourite program and compare with the jpg OOC. Whilst the plastic skin effect may not be obvious on a very young baby a pic of anyone over the age of 30 will show the problem very clearly. You keep insisting on someone showing you the results - why don't you do the test for yourself and show us that it isn't a problem.
I have an XP 1, X100s and X100. It is very visible over iso 1600 on the X100s and not only on skin tones but other shades in the yellow part of the colour gamut especially light coloured wooden objects. The only solution is to shoot raw.
If you have an X100S or XE 1 then show us your results if you do not believe what other people are saying.
Ed B
You seem to be an expert on all things Fuji so I'm sure this isn't the image you're talking about and couldn't be the one I've never seen.
http://www.dpreview.com/forums/post/52978696
As I've already said. Post some portrait samples. I haven't seen any and from what you've said there are plenty to choose form.
