Canon 6D: damaged raw files
Started Feb 16, 2014 | Questions
AlexNH
AlexNH New Member • Posts: 3
Hello. Does anyone know what's causing this? Every now and then I'm getting these artifacts in .CR2 files:
http://farm3.staticflickr.com/2812/12569798024_3bbab5c013_b.jpg
It was NOT a burst shooting. Well over half a minute before the previous shot and the next one.
The memory card is 32GB Sandisk Ultra HC I. Same artifacts show up when I use other flash cards.
Is it a camera problem?
The camera is Canon 6D, less than 3,000 shots.
Thanks!
Canon EOS 6D
mlaca
mlaca Regular Member • Posts: 164
Re: Canon 6D: damaged raw files
i would say it is a memorycard error. try low level formating it in the 6d.
 mlaca's gear list:mlaca's gear list
Panasonic Lumix DMC-GH3 Canon EOS 6D Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Canon EF 16-35mm f/4L IS USM +1 more
Jim Cassatt
Jim Cassatt Veteran Member • Posts: 4,849
Although very rare, I have had similar and other problems with my 5D MKIII.  Not a memory card problem since I use dual cards and the problem shows up on both.
Recently I did a fitness session for a client where we ran through 110 poses.  I almost used my Fuji X-E2 which shows the picture taken immediately in the EVF.  I decided instead to use the 5D MKIII but checked the LCD screen after each shot.
 Jim Cassatt's gear list:Jim Cassatt's gear list
Fujifilm X10 Canon EOS 40D Canon EOS 300D Canon EOS 5D Mark III Fujifilm X-E1 +18 more
brightcolours
brightcolours Forum Pro • Posts: 12,469
Both sandisk cards? How did you transfer them to the computer?
Optical
Optical Senior Member • Posts: 1,097
Can you post the original RAW file?
I will just view it in different raw converters.
Chris
AlexNH
AlexNH OP New Member • Posts: 3
Thanks to everyone who responded! I appreciate your help guys.
The problem has been identified to the card reader.
Using a different SD card reader same file imports uncorrupted.
I still don't understand how it is possible but it is what it is: Importing files though one reader (a cheapo from ebay) corrupts about 1 in 20 files. Importing files thought another (also a cheapo, but from Newegg) doesn't. Go figure.
hotdog321
hotdog321 Forum Pro • Posts: 15,174
Thanks for the feedback! These "corrupted image" threads occasionally crop up, so it is great you tracked down the problem.
These corrupted images generally seem to appear as card reader issues with a sprinkling of issues from folks using "ingest" programs instead of simple drag and drop or counterfeit cards.
I had a problem with a high-end Hoodman RAW Steel 3.0 reader when I first bought Lexar 1000X UDMA 7 cards, but I fixed it by downloading the latest software from Hoodman. All my older USB 2.0 readers are useless with the new UDMA 7 cards.
 hotdog321's gear list:hotdog321's gear list
Canon EOS 5D Mark III Canon EF 70-200mm f/2.8L IS II USM Canon EF 24-70mm f/2.8L II USM Canon EF 16-35mm f/4L IS USM Canon EF 11-24mm F4L +1 more
