Making the best of SEL 16-50 Wide Angle Distortion
Started Feb 16, 2014 | Discussions
LBJ2 Senior Member • Posts: 1,129
5
I could have used jpeg in camera corrections but I rather liked the fisheye look :-).  ( Nik HDR filter applied).  Thanks for looking
uhligfd Senior Member • Posts: 1,870
Re: Making the best of SEL 16-50 Wide Angle Distortion
Can you also post the jpeg corrected image, please. I think here would not have been a noticeable difference. Especially in landscapers; brickwalls are another matter. Show us how different the corrected image looks, please!
It is this landscape itself that invokes a fisheye bending … Not the lens itself.
LBJ2 OP Senior Member • Posts: 1,129
jpeg version with in camera lens corrections applied
Here's the jpeg with in-camera lens corrections applied:
Hello:  I posted the corrected jpeg as well.  However I initially posted the raw w/ Nik HDR filter applied because I preferred the effect over the corrected jpeg
viking79
viking79 Forum Pro • Posts: 14,136
The lens uncorrected has plenty of barrel distortion (fisheye if you will).  Those two red lines should be parallel.
Nothing wrong with it, but it will exaggerate curves and such.  I had to use the unusual wide points for resolution since the others had too much distortion
Image from my blog...
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Thank you. Another excellent reference viking79. I can clearly see the distortion with this lens in post processing--with the extreme at 16mm. When I want to do a lot of PP for this lens I normally use PTLens to correct my raw shots for this particular lens. But I think in-camera jpeg lens corrections does a pretty good too.
I am sorry, I did not realize such barreling lenses exist and could be sold; I am just behind the times here.
Wow, that is built in distortion of a major level.
What next NEX? What is the usable focal length at 16mm as the correction slices off lots of image estate?
Sorry about this lens ….. My lenses' image correction most often results in a little snipped off the edges, almost no noticeable straightening of lines  and a bit more light coming through. So in about half of the images I prefer to use no correction.
But this 16-50 PZ? Phew.
joe6pack Senior Member • Posts: 1,568
Re: jpeg version with in camera lens corrections applied
Thanks. I think both image looks great to me (the JPEG would look better with the color edit, but I believe is more true to life). But I believe the uncorrected image does better in terms retaining the orientation. In this case, the trees all pointing straight up. Another advantage of using the uncorrected image is you actually get a 14-15mm focal out of the 16mm.
BTW, did you apply CA and vignetting correction? What software did you used? It bothers me that Sony's IDC does not allow me to turn off distortion correction.
 joe6pack's gear list:joe6pack's gear list
Olympus XZ-1 Sony Alpha NEX-3N IrfanView Corel Aftershot Pro DxO Optics Pro Elite
viking79
It is becoming the standard.  Although this particular lens is not a great example of software corrected lenses.  I think Sony's mistake here is they made it to apparent.  If you shoot RAW you have to remember to correct it yourself.  Fuji, Samsung, Olympus, etc all have the corrections applied before you ever see the image.  Lightroom will correct it properly before you see the preview.  You can still use a 3rd party RAW editor to see the uncorrected versions.
Sony's decision is nice if you want control over distortion correction, but makes it readily apparent.  Even lenses like ZEISS 24-70mm show extreme levels of pincushion which are being corrected, etc.
I don't think it is worse than other corrections, even optically corrected lenses suffer from apparent loss of focal length from this, like the Fuji 14mm f/2.8 which is optically correct in terms of CA and distortion, has the field of view comparable to something closer to 16mm.
In the case of this Sony, it is more like 15mm uncorrected, 17mm corrected.  Focal lengths are not so straight forward to measure, they can differ depending on where in the frame you are, etc.
I think some people make the assumption that software based corrections are bad, but remember it is easy to do distortion and lateral CA correction in software and they have minimal negligible impacts over what similar corrections would have in optics and get smaller and light and sharper optics (lose some of the sharpness with distortion corrections).  I am no optics engineer with lens design software to see which in fact is "Better" but there are tradeoffs to be made with both.  Software corrections are something that is possible today which was not possible with film.
Eric
Hello: Thanks! I like both shots too--just preferred the dramatic effect of the uncorrected raw shot with Nik HDR applied. Normally I use the PTLens ( very inexpensive ) to correct for CA and Vignetting for this lens' Raw shots. For the jpeg posted I used in-camera lens corrections and no other editing but to your point could have easily popped the color and/or sharpened up.
My desktop PP software includes Mac Aperture with PTLens plug-in and Google Nik Collection.
DocetLector Regular Member • Posts: 305
I have never heard Fuji`s 14 mm lens is close to 16 mm, can you post the source of this statement? I will probably buy this lens, so I would like to know!
 DocetLector's gear list:DocetLector's gear list
Fujifilm X-E2 Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS XF 90mm Fujifilm XF 14mm F2.8 R +1 more
GaryW Veteran Member • Posts: 8,168
I guess so!  A couple of years ago, we were lectured by the M43 crowd how that this was a great feature, allowing them to have a compact zoom.  I guess Sony listened and made a similar design.  Only now, it's considered bad.
Move those goalposts....
It's 14mm or 15mm uncorrected, so the corrected view is around 16mm.
No need to be sorry.  If you want a REALLY compact zoom, then you have to live with this feature.  As another option, you can consider it a 20-50mm lens, if you want.
Some lenses don't need much correction, but even the 18-55 had significant barrel distortion at 18mm.  On the other hand, this actually worked well, IMO, if you were shooting people.  If you correct the barrel distortion, you'll stretch faces that are near the sides.  So, for some real-world photos, it might be good to put some of that distortion back in.
It's pretty sharp at 16mm once you get past the corrections.  It's an odd lens, but nicely compact, with good contrast and color.  Want a better lens?  Buy a more expensive one!  Simple.
Gary W.
 GaryW's gear list:GaryW's gear list
Sony Alpha NEX-6 Sony E 16-50mm F3.5-5.6 PZ OSS Sony E PZ 18-105mm F4 G OSS Sony Cyber-shot DSC-V3 Sony Alpha NEX-5 +9 more
tri x
tri x Contributing Member • Posts: 690
Don't know or want to know about all the tetchy stuff about lens correction, all I can say is you've got a brilliant image so well done mate.
Cheers John
http://www.flickr.com/photos/40629145@N02/
 tri x's gear list:tri x's gear list
Nikon D750 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 16-35mm F4G ED VR +3 more
CameraCarl Veteran Member • Posts: 4,403
I can't understand the hang up some folks have with software corrections for distortion in lenses which were, after all,  designed in the first place to need software correction. It is sort of like saying that the Stealth Bomber or Typhoon fighter are poor designs because they would be unflyable without heavy doses of computer assisted software. I'll gladly live with a compact, lightweight, wide range zoom that needs software corrections instead of having one that weighs a ton and costs a small fortune.
captura Forum Pro • Posts: 21,703
Gary W.
Reminder we had the 16/2.8 from the beginning and it is another distorter. But with correction on in the menu from NEX-5N +, it is much better.
Strangely to me, the 16's UWA seems to have the additional ability to reduce barrel distortion. It is excellent.
captura wrote:
GaryW wrote:
uhligfd wrote:....
Gary W.
I think you've said this before, but distortion is very minor from the 16/2.8.
According to Photozone, the distortion is only .6%.  Slrgear results are similar.
http://www.photozone.de/sony_nex/728-sony16f28nex7?start=1
http://slrgear.com/reviews/showproduct.php/product/1346
It has a touch of "mustache" distortion, which might be harder to correct, but it's so minor it just doesn't need correction most of the time.
It's almost a no-cost (to quality) option.  The 16/UWA combo is really special, and something many just don't seem to "get."
Gary W.
GaryW wrote:
captura wrote:
GaryW wrote:
uhligfd wrote:....
Gary W.
When I first got it about a year ago, I tried some tile wall tests on the 5R with Distortion correction off, then on. The was a big difference....correction straightened the very curved lines. Even worse was that lens on my NEX-3.
Gary W.
I seldom use it with the 16. I use it a lot on the 14/2.5 Lumix pancake lens mounted on my E-PM1, where it is truly exceptional. Lines are straight although the effective DOF is 11 mm.
Thought I would bring this post back to life since everyone is talking about the SEL 16-50 again. I happen to be a fan of this lens and enjoy it for what it is, but am very aware of its special "characteristics"  See Raw vs In-Camera Jpeg corrections for a real world example.
Above Viking79 posted a good image from his blog illustrating the measured technical  details of this lens.
