Olympus E-M10 raw conversion
Started Feb 15, 2014 | Discussions
morepix
morepix Veteran Member • Posts: 8,779
While we wait for the grass to grow and for Adobe to adapt ACR, Lightroom, DNG Converter, etc. for the E-M10, what's the most convenient / effective / whatever way to convert the ORF files from this camera. Some options I can think of are:
  • Olympus Image Viewer
  • Raw Therapee
That's about all there is on my shortlist. I've tried Oly Image Viewer and don't find it very comfortable, but of course a new piece of software hardly ever is. Have never installed and tried Raw Therapee.
I'm a Windows user, but suppose there will also be Mac users who would appreciate any forthcoming advice.
David
www.pbase.com/morepix
 morepix's gear list:morepix's gear list
Ricoh GR Olympus Stylus 1 Panasonic Lumix DMC-FZ1000 Olympus OM-D E-M10
Olympus OM-D E-M10
Paul De Bra
Paul De Bra Forum Pro • Posts: 12,064
Pretend it's an EM-5.
There was a post not long ago that when the string EM-10 in the RAW image file is replaced by EM-5 (and a padding nul-character) ACR and/or Lightroom will just open it as if it were from an EM-5. This means the RAW files are essentially the same except for the camera name string.
This may not work with all raw converters but supposedly this one works. I have not tried it (and I do not own an EM-10).
Slowly learning to use the Olympus OM-D E-M5.
Public pictures at http://debra.zenfolio.com/.
 Paul De Bra's gear list:Paul De Bra's gear list
Fujifilm FinePix F200EXR Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +5 more
morepix
morepix OP Veteran Member • Posts: 8,779
Re: Pretend it's an EM-5.
Paul,
I'll have to look into what to use as an EXIF editor, especially one that will batch process images. And even then, I'm not sure I'm going to want to do it.
But thanks for the lead.
David
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,336
morepix wrote:
Paul,
I used this trick with the F770 (changing it to F550) and it worked well enough. I believe that I used EXIFGUITOOL ...
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F200EXR Fujifilm FinePix F770EXR Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GF3 +16 more
jkrumm Veteran Member • Posts: 9,033
Re: Olympus E-M10 raw conversion
You can experiment with  just changing the file info in windows and see if that works. If you left-click the orf and look at the file info you should be able to click the camera model box and put in a different one. Try EM-5 and EM-1 and see if either of those works.
I did that when the E5 came out. I typed in E30 and the files opened just fine in Lightroom, no exif editor needed.
For now though it doesn't hurt to learn Viewer. It has be improved a lot and can be quite useful. It does batch editing now, among other things.
John Krumm
Juneau, AK
s_grins
s_grins Forum Pro • Posts: 10,311
Week ago I've found that "Perfect Effects 8" opens and converts RAW, in my case RW2. I hope it can convert ORFs too
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic Lumix DMC-GH2 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Sigma 30mm F2.8 EX DN +3 more
morepix
That seemed a tempting idea, but ...
When I single left-clicked an ORF file, nothing happened. When I double clicked it, Windows Live Photo Gallery tried to open it (but failed). You may have a different version of Windows than I do (Win 7 in my case). If I just change the camera model name in the Properties box after right-clicking the file, I can change the model name from E-M10 to E-M5 all right, but that doesn't make Photoshop CC like it any better.
Thank you for the tempting suggestion. Maybe I'll have to muster up a little patience and wait until Adobe released at least a release candidate for ACR 8.4.
David
morepix
That's an interesting idea. So I opened the ORF file OK in Perfect Photo Suite, and it did open OK. Then I can save it as a full-size PSD or TIF or whatever type I want (full-size, not the embedded JPG), but then it's already been "cooked" by Perfect Photo, not allowing any of the usual modifications to the tone, color, etc., of the raw file.
I'm not sure one ends up any better off that way than just using a JPG right out of the camera. What do you think?
David
morepix
Kim,
That's an interesting idea. I did find EXIFToolGUI, which as its name suggests has had a GUI tacked onto an older command-line program called EXIFTool.
I could have a go at it, except I've pretty much run out of energy for this project today. After all, it's still speculative at this point whether it'll actually fool Lightroom and Photoshop. Maybe another wandering soul will come across your post and feel like trying it.
For now, I'm more or less content to (1) live with JPGs until Adobe comes through with a new rev of ACR; or (2) tackle the learning curve of Olympus Image Viewer; or (3) go back to my Stylus 1 while I wait. Life is full of options, isn't it?
I just hope the powers in raw-heaven will forgive me for actually using OOC JPG files!
David
s_grins
David
Yes, you can open RAW develop it to your tastes, save it as PSD, TIFF, or JPG. RAW remains intact
I'm undereducated person, and can't comment on JPG that is embedded in RAW. I have not found it in my RW2
Also you can open your JPG, develop it to your tastes, and save it or save it as copy having your original JPG intact.
s_grins
David
I run W7 ultimate 64 bit, and after I've installed latest camera codec, I preview all my RAWs in Windows Live Photo Gallery. I do not know why I'm so lucky while many others complain.
morepix
Simon,
I don't think the world works that way -- at least, not my world. Once a raw image is demosaiced (i.e., converted from the Bayer pixel layout to an interpolated raster image) -- and particularly once they're reduced to 8-bits, as JPG images are -- you lose some of the leeway that raw files offer for adjusting tone, color, sharpness, noise, etc. Yes, you can certainly manipulate those qualities further to some extent in another type of file, but not to the same extent as in a real-life raw file.
David
Cheezr
Cheezr Contributing Member • Posts: 818
If you have a mac here is the link to the converter, enjoy.
http://www.dpreview.com/forums/thread/3620404
Life is uncertain, eat dessert first.
s_grins
morepix wrote:
Simon,
David
We live in different worlds. My SilkyPix and new Perfect Effects do not do anything to RAWs.
micampe New Member • Posts: 19
Yes it works, that’s what I’m doing.
 micampe's gear list:micampe's gear list
Ricoh GR Digital Olympus OM-D E-M10
morepix
Also with EXIFToolGUI? Also with an E-M10? Also processing in Lightroom and/or Photoshop CC?
If so, it's back to work for me tomorrow!
David
David
Exiftool (no GUI because I'm old school), E-M10 posing as E-M5 (tried E-M1 but colors were all wrong), Lightroom 5, on a Mac.
morepix
Ah, for those hair-on-the-chest days of command-line processing. How I miss DOS, Unix shell scripts, etc!
The color issue you noted dims it for me, reminds me how much custom tailoring goes into each raw conversion that's right for one camera but not for another, even a close relative. More encouragement to be a little patient and wait.
As far as I can see, Adobe seems to be releasing new versions of ACR on about three-month intervals: Sept 2013, Dec 2013. So now maybe ver 8.4 in March 2014. Meanwhile, JPG gets a little better each time.
Thanks for the info.
David
beomagi Senior Member • Posts: 1,372
Darned tablet hit withdrawpost.....
I analyzed the raws from here
http://www.imaging-resource.com/PRODS/olympus-e-m10/olympus-e-m10A7.HTM
Against an em5
So seeing the difference, ran this command
Sed comes from gow(gnu on windows)
Xxd comes from installing gvim(a text editor)
C:\Temp>xxd EM10INBI06400.ORF|sed "s/452d 4d31 3020 2020 2020 2020 2020 2020 E-
M10/452d 4d35 2020 2020 2020 2020 2020 2020 E-M5/"|xxd -r >conv.orf
What this is doing is converting the binary fine to hex, substituting a string, and converting it back to binary, dumping it to conv.orf.
Here is the result, give it a try.
https://drive.google.com/file/d/0Byn3RaVwsVuvV3V4RTNEbzFkX2c/edit?usp=sharing
I use UFRAW so it doesn't matter to me. Lets see if it works in ACR. Exit was read right in irfanview.
 beomagi's gear list:beomagi's gear list
Canon EOS 5D Olympus PEN E-P3 Olympus OM-D E-M10 Canon EF 50mm f/1.8 II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +5 more
Steven Wandy Veteran Member • Posts: 5,179
I'm not running Windows as my main computer any longer but I think he meant "right click". I believe that brings up what he is referring to.
David
 Steven Wandy's gear list:Steven Wandy's gear list
Canon PowerShot G7 X Olympus PEN E-PL1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus Body Cap Lens 15mm F8.0 +5 more
