45/1.8 cheap
Started Feb 15, 2014 | Discussions
tt321
Senior MemberPosts: 6,473Gear list
45/1.8 cheap
Feb 15, 2014
I am ready to buy a 60/2.8 Sigma, but now this appears.
Should I, should I not, etc...
Skeeterbytes
Veteran MemberPosts: 8,544
Re: 45/1.8 cheap
In reply to tt321, Feb 15, 2014
As a 45 user I can highly recommend it. The Sigmas get enthusiastic reviews, so there's probably no bad choice--which focal length do you prefer?
Cheers
Rick
"Whiskey is for drinking, digicams are for fighting over."
—Mark Twain
baxters
Veteran MemberPosts: 4,778Gear list
Re: 45/1.8 cheap
Buy the 45mm if that is a big sale for you.  Then wait for the Sigma to go on sale. Having both is no sin, for most M32 people anyway.
 baxters's gear list:baxters's gear list
Panasonic Lumix G 25mm F1.7 ASPH
unknown member
(unknown member)
I would buy the 45mm
over and over again if I needed to.  It's that good.  Have not used the Sigma.
 dpalugyay's gear list:dpalugyay's gear list
Olympus OM-D E-M5 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 +4 more
janeenadamsmartin
Contributing MemberPosts: 645Gear list
The 45mm is my favorite lens..
Even over the 75  -- only because I find that focal length a bit specialized.
jan
 janeenadamsmartin's gear list:janeenadamsmartin's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Panasonic Lumix DMC-FZ200 +5 more
tt321
tt321 OP
Re: 45/1.8 cheap
In reply to Skeeterbytes, Feb 15, 2014
It's the old FL histogram again. Had an analysis of my shots with the 45-175. Quite dense between 45 and 65. The 45 has a big spike, but I suspect that's mostly because I am too lazy to change lens.
No real preference. Interesting.
How's the 45 as a close-up lens with either tubes or close-up 'filter' type adapters?
Ulric
Senior MemberPosts: 3,188Gear list
Re: 45/1.8 cheap
Should. Of course.
 Ulric's gear list:Ulric's gear list
Panasonic Lumix DMC-GF3 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +9 more
bluelemmy
Contributing MemberPosts: 878Gear list
Re: 45/1.8 cheap
Buy it! Buy it! Buy it! Possibly the best lens ever made for M43. Small, light, cheap, optically excellent.
 bluelemmy's gear list:bluelemmy's gear list
Olympus E-M1
El Chubasco
Regular MemberPosts: 464Gear list
Re: 45/1.8 cheap
My 45 has been collecting dust since I got the Sigma 60. Get the Sigma 60
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm FinePix X100 Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R +12 more
photofan1986
Senior MemberPosts: 2,740Gear list
Re: 45/1.8 cheap
In reply to El Chubasco, Feb 15, 2014
Care to elaborate?
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Canon PowerShot S100 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +6 more
Paulmorgan
Veteran MemberPosts: 4,633
Re: 45/1.8 cheap
That`s a bit of an odd statement, both are equally as good given the right task, I guess you don`t do portraits.
Skeeterbytes
Re: 45/1.8 cheap
Have not tried it as a true close-up lens, only capitalized on the speed for subject isolation. It's actually a challenge to do so in sunlight, as it takes a fast shutter/low ISO or ND filter to open it wide. Even so, it does a pretty good job.
Sierra wildflowers.
Rick
—Mark Twain
FrankS009
Veteran MemberPosts: 3,446Gear list
Re: 45/1.8 cheap
In reply to tt321, Feb 16, 2014
I have the Sigma 60mm and am enjoying it a lot. I have also ordered a PL45mm, so am indulging in both focal lengths. I am not sure how much the Sigma 60mm costs where you are, but buying both the Olympus 45 and the Sigma 60 seems much less expensive together than say the 75mm.
F.
When no-one else is there, the camera becomes my means...to say to a wider audience, "Did you see that?" David duChemin
 FrankS009's gear list:FrankS009's gear list
Panasonic Lumix DMC-GX7
bill pasuquin
Regular MemberPosts: 107Gear list
Re: 45/1.8 cheap
I have both,45mm F1.8 + simga 60mm,the 45 focus a little better in low light on my E-pl1 & gf1,both are  very good lens
 bill pasuquin's gear list:bill pasuquin's gear list
Canon PowerShot G2 Kodak DC4800 Olympus C-2040 Zoom Olympus C-2500 L Panasonic Lumix DMC-FZ20 +14 more
Corkcampbell
Forum ProPosts: 14,747Gear list
Bogus question: One should have both as they complement each other nicely.
Both are sharp, both can handle video, both have good bokeh, both are portable, both are great for portraits, and both are cheap. They are certainly not redundant because there is quite a difference in focal lengths.
"Knowledge is good." Emil Faber
 Corkcampbell's gear list:Corkcampbell's gear list
Sigma DP2 Merrill Sony Cyber-shot DSC-RX10 Sony Cyber-shot DSC-RX100 III Panasonic Lumix DMC-GH3 Olympus E-M5 II +3 more
rare wolf
Contributing MemberPosts: 885
Re: Bogus question: One should have both as they complement each other nicely.
In reply to Corkcampbell, Feb 16, 2014
Check the Lightroom compatibility list for supported lenses. I know I saw Sigma there for a number of lenses ... The 45 should be there too(?)
cheerios from the Avalon Peninsula, Newfoundland
Cogito ergo zZOooOMm
Anfy
Veteran MemberPosts: 3,401
Just a cosmetic note on the Olympus
Your link goes to a black version 45mm. When I bought mine, the K version was much more expensive than the silver version, so I went for the latter (which is fantastic on my silver E-M5). Then I had the opportunity to see the other - the black -  in the flesh, and I found it a bit too plasticky looking for my taste.
Ciao!
Viva la evolución!
lex32
Junior MemberPosts: 46Gear list
Re: 45/1.8 cheap - macro examples
Hi,
I use the 45 1.8 with a raynox M-250 close up lens and really like it. Of course it is not like a real macro lens as you have to stay in a very narrow corridor to get it focused (around 10cm I would say). I also include an unaltered shot (100%) of a strawberry to show how sharp this lens is when doing macro with the raynox.
regards,
Alex
 lex32's gear list:lex32's gear list
Olympus C-8080 Wide Zoom Olympus PEN E-PL1 Olympus PEN E-PL5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 R +3 more
Mark Thornton
Veteran MemberPosts: 3,128Gear list
Re: Just a cosmetic note on the Olympus
In reply to Anfy, Feb 16, 2014
That store offers the silver and black version at the same price. I'm quite happy with my black 45mm.
Worth noting that the Sigma 60mm is also on sale at the same shop for just £129 (vs £199 for the 45mm f/1.8).
Mark
 Mark Thornton's gear list:Mark Thornton's gear list
Olympus E-500 Panasonic Lumix DMC-GX1 Olympus Zuiko Digital 11-22mm 1:2.8-3.5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 +5 more
Harold66
Veteran MemberPosts: 6,220Gear list
Re: 45/1.8 cheap
I usually try not to push people to buy without a good reason but all reviews agree that the 45mm is a Must have for any m4/3 user
in addition to being a very useful focal length , this is probably the best lens for your buck ( or in your case for you pound) in the m4/3rd line
I use mine a lot for shooting models
Harold
www.haroldglit.com
www.modelmayhem.com/haroldglit
 Harold66's gear list:Harold66's gear list
Ricoh GR Digital IV Sigma DP2 Merrill Sigma DP3 Merrill Ricoh GR Ricoh GR II +21 more
