LX7/LVF2 ?
Started Feb 15, 2014 | Questions
donfigor
donfigor Junior Member • Posts: 25
LX7/LVF2 ?
I just received a used LVF2 from B&H,  when using the camera on IA the aperture may go up to f2.8 but then if I go to Manual or aperture priority the aperture will sometimes not open back up to f1.4 but it will stop down normally.  Turning the camera off and back on seems to restore it back to normal,  and I never had this problem without the LVF2.
Is this normal or should I return it?
Don
 donfigor's gear list:donfigor's gear list
Panasonic Lumix DMC-LX7 Nikon D7100
James Pilcher
James Pilcher Veteran Member • Posts: 8,398
repeatability
Hi Don,
That is inexplicable. I would not return/exchange the LVF2 until I can repeat the behavior after several mount/unmount sequences with the LVF2, and with a camera full reset. If it remains absolutely repeatable, then try to get another LVF2 and do the same thing. That will tell you a lot. If it continues to happen with another LVF2, it's likely your camera.
I cannot imagine how the LVF2 would do this to your camera, but it's all computer programming these days and anything can happen inside a computer. I know. I program for a living and strange things just happen.
I've been using my LX7 and LVF2 for 16 months without issues. I wish you the best of luck.
Jim Pilcher
Summit County, Colorado, USA
 James Pilcher's gear list:James Pilcher's gear list
Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix DMC-LX7 Olympus PEN E-P5 +7 more
donfigor
donfigor OP Junior Member • Posts: 25
Re: repeatability
Hi Jim,  thanks for your quick response.  I have done a reset and am still having the problem, I have noticed it is happening even if I just stay in manual mode and stop down for a few shots then go back to 1.4  it may only stop down to between 1.5-2.3 and the only way to get f1.4 back is to turn the camera off and back on.
I am in a quandary as I am to leave for a month to the the Philippines next week and would really like to have the viewfinder in the harsh light over there.
Lobalobo
Lobalobo Senior Member • Posts: 2,236
Re: LX7/LVF2 ?
Don
I also use the LX7 and LVF2 and have never had the latter do anything but reflect what would otherwise be on the lcd; it's just an alternative monitor so hard to understand how this is possible, though as the previous poster said strange things happen. Since the problem started, have you tried to replicate without the LVF2 attached? Perhaps the camera is just glitchy. Not sure if there is a firmware update for the LX7, but if there is, you might try that (analagous to rebooting a glitchy computer). You might even try to reload the current firmware if there is not update, though I'm not sure the camera will allow that. Personally, the last thing I'd do is give up on the viewfinder, which I find both wonderful and indespensible.
geoffmalter
geoffmalter Senior Member • Posts: 2,489
Re: LX7/LVF2 ?
I too have the LX7/LVF2 combo (my LVF2 was recently purchased used). I have never experienced your issues. As pointed out already, the LVF, for all practical purposes, is just another LCD screen that should in no way interfere with the camera's operations. On aperture mode, are you manually adjusting the f-stop with the lens ring? That's what I do. Good luck.
 geoffmalter's gear list:geoffmalter's gear list
Olympus Tough TG-1 iHS Panasonic Lumix DMC-LX7 Sony SLT-A57 Canon EOS M Sony DT 55-300mm F4.5-5.6 SAM +8 more
donfigor
Re: LX7/LVF2 ?
Thanks for your help guys,  It was just a rookie mistake on my part,  it was just when zoomed and the variable aperture fooling me.
Timj351
Timj351 Veteran Member • Posts: 3,666
Re: LX7/LVF2 ?
I'm glad you got it worked out. I'm not sure I was completely understanding your problem but my first thought was that maybe you had the "Lens Resume" turned on or, at least, it wasn't in the widest zoom position. yes, the lens is variable so it can cause some confusion if you are trying to specifically set an aperture like F1.4 when the lens is zoomed in some amount.
I really want to get this EVF but the high price is keeping me from doing so.
-Tim
 Timj351's gear list:Timj351's gear list
Panasonic Lumix DMC-FP8 Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ1000 +3 more
James Pilcher
Going on holiday
I'm glad you worked out your issue. Enjoy your trip to the Phillipines and be sure to post your best shots here when you get back.
Jim Pilcher
teddoman
teddoman Senior Member • Posts: 1,967
LVF2 stabilization
I just joined the LVF2 crowd too. Being able to stabilize the camera against your face really helps to get more stable shots. Adds stability to an already stabilized lens. I snapped a few test shots at night under street lights w/o even really trying that hard and was impressed with how sharp the photos came out.
I'm not wedded to the visual angle of using a viewfinder per se, but I love the extra stabilization. Opens up more low light options for me.
 teddoman's gear list:teddoman's gear list
Olympus OM-D E-M5 Sony a6000 Samsung NX1 Samsung NX500 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA +10 more
Cyril Catt
Cyril Catt Veteran Member • Posts: 3,848
Re: LVF2 stabilization
tedandtricia wrote: I just joined the LVF2 crowd too. Being able to stabilize the camera against your face really helps to get more stable shots. Adds stability to an already stabilized lens. I snapped a few test shots at night under street lights w/o even really trying that hard and was impressed with how sharp the photos came out.
I'm not wedded to the visual angle of using a viewfinder per se, but I love the extra stabilization. Opens up more low light options for me. -- Ted http://www.flickr.com/photos/tedchang/
Agreed, Ted. I seem to take a lot of handheld photos in dimly lit buildings - churches, mosques, museums, etc - where flash is not permitted, would be lost in the vast space, or would be rudely intrusive.
The alternative to eye-level composing is a small tabletop tripod  to steady the camera against any firm item - wall, lamppost, tree, or at a pinch, against sternum and top ribs. Although useful for longer exposures or HDR, that is not as convenient as using the LVF2.
Cyril
