Olympus 25mm 1.8 vs. Panasonic Leica 25mm 1.4 for Olympus body (E-M5)
Started Feb 15, 2014 | Discussions
Acronator New Member • Posts: 20
I know there will be quite a few comparisons between these two lenses (and I plan on owning both). I am trying to figure out which one to get first and I had a few specific questions for people who have used both lenses with an Olympus body.
1. AF Speed. Both have very fast AF but is the Oly 25mm lens even a tad bit faster on AF with an Olympus body?
2. How useful have you found the extra stop of the Panasonic lens? Please do explain.
3. Both are very sharp lenses. Which is sharper?
4. Do the distortion corrections made by a Olympus body with the Oly 25mm 1.8 make for an advantage?
Thanks a lot.
 Acronator's gear list:Acronator's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GF2 Olympus OM-D E-M5 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +2 more
El Chubasco
El Chubasco Contributing Member • Posts: 511
Re: Olympus 25mm 1.8 vs. Panasonic Leica 25mm 1.4 for Olympus body (E-M5)
Robin Wong is about to release a comparison review. Stayed tuned to his blog. He is excellent and I am sure he will answer your questions.
 El Chubasco's gear list:El Chubasco's gear list
Fujifilm X-Pro1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm Fujifilm XF 60mm F2.4 R Macro +12 more
Len_Gee
Len_Gee Veteran Member • Posts: 8,916
5
Why own both?
Do you have a specific reason why you need Oly 25 AND 25PL?
Seems like a waste of money.
 Len_Gee's gear list:Len_Gee's gear list
Fujifilm X100T Panasonic Lumix DMC-GX7 Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Panasonic 20mm F1.7 II
G1Houston Senior Member • Posts: 2,566
Wasn't there another thread like this yesterday? nt
Thanks a lot.
 G1Houston's gear list:G1Houston's gear list
Olympus PEN E-PL5 Nikon D7100 Olympus OM-D E-M10 II Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S +8 more
Acronator OP New Member • Posts: 20
Why own both?
I have 3 micro 4/3 bodies. I mix and match lenses to shoot videos and stills at the same time. I figure it is only a matter if time before I get both. That said I might not. This is why I need pick the first one carefully.
Am really looking forward to it.
(unknown member) Senior Member • Posts: 1,178
I don't know, was there?
6
I didn't see it.  Does it matter?  Unless you are the forum policeman, why do you care?
You could have linked to it, if you were concerned enough to reply like this.
 dpalugyay's gear list:dpalugyay's gear list
Olympus OM-D E-M5 Olympus 12-40mm F2.8 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 +4 more
Re: I don't know, was there?
Very form has a search button. Use it.
El Chubasco
Actually the review is out
http://robinwong.blogspot.com/2014/02/olympus-mzuiko-25mm-f18-lens-review.html
Enjoy!
FrankS009
FrankS009 Veteran Member • Posts: 3,770
I am looking forward to the LensTip test of the Olympus 25mm 1.8 to compare it to their tests of the Panasonic 25 1.4, the Olympus 45mm, and a number of other lenses. Wong says he thinks the Olympus lens is as sharp as the 45mm. We shall see.
F.
When no-one else is there, the camera becomes my means...to say to a wider audience, "Did you see that?" David duChemin
 FrankS009's gear list:FrankS009's gear list
dgrogers Veteran Member • Posts: 6,725
Robin Wong has just compared the two lenses.  In the end, I think you may be better off going with the Olympus if you have an Olympus body and the Panasonic if you have a Panasonic body.
Completely infatuated with the "OMG"
 dgrogers's gear list:dgrogers's gear list
Olympus E-1 Samsung NX20
Bluevortex Regular Member • Posts: 174
Typical! Just yesterday day got the 25mm 1.4 and EM5 combo, now starting to doubt this was the right decision
blue
 Bluevortex's gear list:Bluevortex's gear list
Olympus E-PL7 Olympus M.Zuiko Digital 25mm F1.8 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 14mm F2.5 ASPH
amtberg Veteran Member • Posts: 5,533
LOL
In case there was any question that Robin Wong is biased toward Olympus products (as an Olympus employee), this settles it.
First claims that the Panasonic is twice as expensive ... well, apparently that's an issue for those living in Malaysia.  Everywhere else the Panasonic seems to cost about 25% more new, or the same or less used.
He somehow concludes that the Olympus is better in the corners, when his crops show they are essentially identical (both excellent), or if either has an advantage, it's the Panasonic.
Spends a lot of time downplaying the difference in DOF between the Panny at f/1.4 and the Olympus at f/1.8 when the difference is clearly significant in the PL's favor, and when -- really -- at 25mm on MFT you want as much DOF flexibility as you can get.
They are both very good lenses.  All else being essentially equal, the PL is faster and thus gives more creative control.
A shame Olympus didn't put the effort into producing a nice 9mm or 10mm prime to fill a hole instead of reinventing the wheel (and making it slightly less round).
markintosh13
markintosh13 Senior Member • Posts: 1,905
I didn't see that much DoF difference, nothing significant. But that's me.
I've always wanted a Panny 25 f/1.4 - but the size and the price has always dissuaded me.
If the Oly version was $350 on sale, I'd consider one.
Anfy
Anfy Veteran Member • Posts: 3,404
As I wrote in the other thread, at least in UK the Panasonic 25mm f/1.4 - new - presently costs just 30 GBP more than the Olympus f/1.8 (source: camerapricebuster.co.uk)
Ciao!
Viva la evolución!
markintosh13
Here in Canada, the Panny 25 1.4 is currently on sale (Henry's) for $599 (reg 649), and the Oly 25 1.8 is selling at reg price at $399.
So maybe it might be on sale at $350 at some point.
The DOF difference isn't dramatic but it's clear, and IMO at this focal length on MFT you're often going to want thinner DOF than you can get even at f/1.4.  That's one reason why I use the Voigt 25/.95 rather than the PL.
sebiruns
sebiruns Contributing Member • Posts: 516
blue
Don't worry. It is a great combination. The PL25 is a wonderful lens that works great together with the E-M5. Robin Wong is an Olympus employee. I like his reviews but he certainly has a bit of a bias. Focus speed is swift and low light capability unmatched. If you want to I can post pics taken with the PL25 and the E-M5, too. Relax. You made a good buy.
 sebiruns's gear list:sebiruns's gear list
Fujifilm X100T Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II
Dissenter Junior Member • Posts: 30
LOL
It's an issue here in Australia too...$700+ where Panasonic along with Sony doesn't even bother to attend the camera trade shows.
I think the prices on the Oly will fall. But takes a bit of time. I bought my 45mm 1.8 for $400 a year back. Now it can be had easily for about $300 or less.
