D800 problem
Started Feb 15, 2014 | Discussions
Pete Silver
Regular MemberPosts: 313Gear list
D800 problem
Feb 15, 2014
My D800 for some reason wouldn't turn on. Checked battery etc. but no go so I sent it off to Nikon for repair - still under warranty.
It has come back repaired - they say 'Replaced front body unit and PD PCB Unit.
Seems to work ok but all my settings have gone (PCB replaced I suppose) anyway the firmware is A 1.01, B 1.02 and L is showing L ?.255. That wasn't like that before. Have updated the firmware again but still showing same.
Also using Focal to fine tune my lenses again the camera sends it's serial number as 000000.
I am going to ring Nikon on Monday but has anyone have any thoughts meanwhile?
Pete Silver
 Pete Silver's gear list:Pete Silver's gear list
Fujifilm FinePix S5 Pro Samsung NX30 Nikon D810 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 28-70mm f/2.8 ED-IF +5 more
Nikon D800
snellius
Contributing MemberPosts: 530Gear list
I think they have also replaced the TOGO PCB.
In reply to Pete Silver, Feb 15, 2014
Robin Casady
Forum ProPosts: 12,898
Re: D800 problem
In reply to Pete Silver, Feb 16, 2014
Take a photo and check the serial number in the EXIF data.
Robin Casady
http://www.robincasady.com/Photo/index.html
"Get your facts first, then you can distort them as you please."
—Mark Twain
rgolub
Senior MemberPosts: 2,061Gear list
Re: D800 problem
Try a 2 button reset?
RG
I break things.
www.lostrange.com
 rgolub's gear list:rgolub's gear list
Nikon D700 Nikon D4 Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF +12 more
Pete Silver
Re: D800 problem
In reply to rgolub, Feb 16, 2014
Yes the TOGO PCB was replaced as well.Tried a factory reset - still the same.
Checked the exif data - no serial number (listed correctly on a previous picture) which may leave me in a quandary with Nikon for any future repairs. I'll ring them tomorrow.
Also checking the finetune with Focal software, Focal doesn't recognise any adjustments (ie setting the range) to the camera. Looks like no data flowing between the two.
Pete Silver
