A77: why long lenses seem to be so out resolved?
Started Feb 15, 2014 | Discussions
JimmyMelbourne Senior Member • Posts: 2,442
Just curious regarding these results on telephoto lenses on the A77. Just curious why the best lens on this list, the sony 70 - 200 g, only achieves 10 P-MPix?
Are these scores to be trusted? Just trying to understand why a77 is so demanding. Even other 24 Megapixel cameras from other brands do not seem to be so demanding of their longer lenses.
http://www.dxomark.com/Reviews/Best-lenses-for-the-24M-Pix-Sony-SLT-A77-Primes-and-Zooms/Best-Telephoto-zooms-for-the-SLT-A77
 JimmyMelbourne's gear list:JimmyMelbourne's gear list
Sony Alpha DSLR-A300 Sony SLT-A77 Sony SLT-A37 NEX-5T Sony Alpha 7 +20 more
Sony SLT-A77
craig66 Contributing Member • Posts: 926
Re: A77: why long lenses seem to be so out resolved?
Sometimes the simplest explanation is quite possibly the best explanation. Maybe because the Canon, Nikon and Tamron VC 70-200 f2.8 lenses are better lenses than the Sony 70-200.
 craig66's gear list:craig66's gear list
Sony a77 II Sony DT 55-300mm F4.5-5.6 SAM Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 500mm F4.5 EX DG HSM Tamron SP AF 60mm F/2 Di II LD IF Macro +9 more
JimmyMelbourne OP Senior Member • Posts: 2,442
Yes, but look at all of the lenses. All of the G lenses are resulting in low numbers. We know the 70 - 400 g is a top end lens. Is there something about the A77 sensor and camera configuration that is affecting how these lenses perform?
I think if we had tamron and sigma 70 - 200 equivalent lenses tested on the a77 they would also return low numbers.
The sony 70 - 200 g is actually fairly closely rated against the sigma and tamron lenses on other camera manufacturer cameras (when looking at the PMpx number)
I should qualify the tamron seems to surpass the other two on the same 24 Mpix sensor, but it does seem the Nikon camera has higher values across the board than the a77 so it might not be a fair comparison due to the diferent camera configuration and variables.
http://www.dxomark.com/Lenses/Compare/Side-by-side/70-200mm-F2.8-EX-DG-OS-HSM-Nikon-on-Nikon-D7100-versus-Sony-70-200mm-F2-8-G-on-Sony-SLT-Alpha-77-versus-Tamron-SP-70-200mm-F28-Di-VC-USD-Nikon-on-Nikon-D7100___320_865_246_734_1028_865
Tamron 150-600 vs Sony 70-400 vs Nikon 80-400
There's a bit of give and take but there's not much to separate them in the overlapping focal length.
In the case of these long zooms, I guess most people are more interested in the long end. It's more useful to look at the detailed measurements than the headline pmpix.
The D7100 has no anti-alias filter which might make some difference.
Chris Malcolm Senior Member • Posts: 1,503
There's something very odd about some of DxO's tests of lenses on cameras. For example, on the A99 the Sony 50mm f/1.4 gets almost exactly the same scores (slightly better in fact) as the old Konica-Minolta 50mm f/1.4. That's to be expected, since those two lenses are supposed to be optically identical but with improved coatings on the Sony 50mm.
Whereas on the A77 the K-M 50mm gets much the same result as on the A99, being one of the sharpest primes, but the Sony 50mm is way below it as one of the poorest primes. That's an extremely large difference!
I get the impression from other learned looking discussions of other paradoxical DxO results, that DxO give interesting & useful results when they get it right, but they do sometimes get it very oddly wrong. If a DXO camera & lens combination gives rather odd results, I wouldn't trust it without independent support.
Chris Malcolm
 Chris Malcolm's gear list:Chris Malcolm's gear list
Sony Alpha DSLR-A550 Sony SLT-A77 Sony 50mm F1.4 Sony DT 18-250mm F3.5-6.3 Sony 500mm F8 Reflex +7 more
Michel J Veteran Member • Posts: 4,009
We sure can't believe, it's just an overall IQ in a combo for itself (specific lens attached to a specific camera)!
We have to make our own interpretations because, voluntarily or not, tests lie! It have some proof of that.
We have to make cross-checking between different sources to be sure. But it's virtually impossible to find exactly same combos and same tests protocols at the same time!
So at this point, the question is not 'if' tests lies but 'why' some lenses are really underrated /or overrated?
The best should be to make our own tests (when it's possible)
Last but not least, why dPr periodically change his "Studio Scene comparison", which hinders us to be able of making comparisons over time!
Cordialement,
Michel J
« Having the latest gear is nice, but great photographers don't have to have it. They can shoot good stuff with anything »
 Michel J's gear list:Michel J's gear list
Sony SLT-A77 Sony SLT-A37 Konica Minolta Maxxum 7D Sony 70-200mm F2.8 G Sony DT 18-55mm F3.5-5.6 SAM +10 more
If so, why the D7100 resolve 3000LPH when the A77 with same 24MP sensor resolve 3400LPH. And why it's the D7100 which have a better resolution power in p-MP than the A77 for a same lens?
Cordialement,
Michel J
Ralf B
Ralf B Veteran Member • Posts: 7,594
AC DC have a song for DXO based pixel peepping
Cos I'm
p-MP
I'm Dynamite
p-MP
And I'll win the fight
p-MP
I'm a power-load
p-MP
Watch me Explode . . .
Ralf
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* +13 more
Re: AC DC have a song for DXO based pixel peepping
Im considering selling all my longer lenses including the sony 70 200 g. The reality is I do not use them enough to warrant the cash sitting there doing nothing. This is why I have been looking at the performance of the 70 200 g and whether it is worth keeping or not. This is also due to the evidence that these longer lenses are all not providing the resolution that would warrant the investment when considering aps-c cameras in A Mount.
VirtualMirage
VirtualMirage Veteran Member • Posts: 3,660
I hate to say you are looking at it the wrong way, but you are.
You are claiming that long lenses on the A77 get out resolved when comparing to similar resolution sensors the competition uses, yet you are comparing different lenses. Apples and Oranges.
We will never know how a Sony 70-200 or 70-400 would perform on a Nikon or Canon, so you can't claim the issue is with the A77.  When you put the same lens on the lower resolution sensors, you don't see a dramatic increase in performance.  At best you will see equal performance and at worst poorer performance.  When a lower resolution sensor score the same with a lens as a higher resolution sensor, then you can conclude that the sensor is out resolving the lens and the lens is at its limitation.
You will be better off comparing the same lens across all sensors to get a better idea as to what to expect.  Unfortunately, it doesn't seem DxO accounts for possible poor manufacturing tolerances on lenses (a goody copy versus a bad copy).  One example of this is comparing the Sigma 24-70 across the Sony, Nikon, and Canon.  The Sony performs poorly compared to how it performs on Nikon and Canon, yet all three are identical lenses in design (same optical formula).  At the very least, you should see similar optical characteristics despite higher or lower resolutions.  An example would be corner sharpness and the transition from center to corner sharpness.
The Nikon and Sony sensors share the same crop, thus use the same portion of the lens, so they should exhibit similar characteristics.  When compared wide open, they don't in this respect.  The Canon is a tighter crop and users a smaller portion of the lens, 1.6x versus 1.5x.  So its characteristics should look like a slightly magnified version of the Nikon and Sony charts.  While it, too, varies a bit, it at least looks more similar to the Nikon in characteristics than the Sony does.  From all three, you could assume that the Nikon was using the best copy of the lens of the three, with the Canon taking a close second, and the Sony a distant third.  Even the vignetting isn't the same.  This is a sign that a copy that wasn't calibrated very well was used.
So to wrap it up, take the numbers with a grain of salt (especially when comparing different brands of lenses).  Manufacturing tolerances and the quality of the copy chosen can have an affect too.
P.S.
I would like to add that the Sony 70-400 doesn't perform as bad as you think against the competition.  The Nikon 80-400 scores about the same as it does.  Same goes for Canon's closest competing lens, the 100-400.
Paul
 VirtualMirage's gear list:VirtualMirage's gear list
Sony RX100 Sony a77 II Tokina AT-X Pro 11-16mm f/2.8 DX Tamron SP AF 90mm F/2.8 Di Macro Tamron SP 70-200mm F/2.8 Di VC USD +18 more
nandbytes Senior Member • Posts: 5,575
If you are selling the sony 70-200 let me know for how much.
 nandbytes's gear list:nandbytes's gear list
Sony Alpha NEX-7 Sony a6000 Samyang 8mm F2.8 UMC Fisheye Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +2 more
Hi Paul
I certainly understand and appreciate what you have written, and also share this view. The only reason I raise this is we see a lot of longer zoom lenses that have been tested on the a77 rating low. If it was a case of one or two bad lens design, i can appreciate that, but when we see across the board low scores specific to the a77, it makes me wonder why, and if there is something specific to the a77 that may lead to this trend. Hence my original post.
Will do mate, I really need to use it more to know if its something I want to keep. With some lenses I personally feel i hit my capability as a photographer, and time i can invest into it. I could probably get away with just owning the 16 - 50, 50 1.4 SSM, and 18 - 250, 85 1.4, 11-16 and be covered for all occasions based on what I currently do with my cameras. The rest I could potentially sell and put my toe into E mount for a try.
VirtualMirage
Hi Paul
But it isn't the A77. Look at the same lenses on other camera models, Sony including. You don't see any of the other models scoring higher than the A77, do you? See here:
http://www.dxomark.com/Lenses/Compare/Side-by-side/Sony-70-200mm-F2-8-G-on-Sony-SLT-Alpha-77-versus-Sony-70-200mm-F2-8-G-on-Sony-Alpha-550-versus-Sony-70-200mm-F2-8-G-on-Sony-Alpha-700___246_734_246_624_246_562
The A77 is 24MP, the A550 is 14.2MP, and the A700 is 12MP.
Now let's compare the same lens with the A77, A900, and A99:
http://www.dxomark.com/Lenses/Compare/Side-by-side/Sony-70-200mm-F2-8-G-on-Sony-SLT-Alpha-77-versus-Sony-70-200mm-F2-8-G-on-Sony-Alpha-900-versus-Sony-70-200mm-F2-8-G-on-Sony-SLT-Alpha-99___246_734_246_371_246_831
The conclusion to come to that is it is the lens is more of a limiting factor than the sensor.
Here's the Sigma 35mm F/1.4 A HSM on the A77, D7100 (no OLPF), and D5200 (with OLPF) (all 24MP):
http://www.dxomark.com/Lenses/Compare/Side-by-side/Sigma-35mm-F14-DG-HSM-A-Sony-on-Sony-SLT-Alpha-77-versus-Sigma-35mm-F14-DG-HSM-A-Nikon-on-Nikon-D7100-versus-Sigma-35mm-F14-DG-HSM-A-Nikon-on-Nikon-D5200___1060_734_1057_865_1057_850
Remember that the strength of the aliasing filter can affect perceived sharpness.
The only thing that I keep noticing on DxO's site is the tests tend to consistently show the Sony's as being weak in the corners. And that isn't with just the A77, it is with all the Sony APS-C sensors. I can see that being more problematic with the E-mount cameras and having such a short flange distance, requiring some optimized micro lenses on the sensor, but not so much the A-mount. It makes me question how and what DxO is testing and if they do sample variation. Until I can see other sites or testers verify this, I cannot conclude that DxO's results are 100% correct. They do give us a good start and give us an idea of some expectation, but that is about it. Error tolerances, testing methods, equipment used, etc. are all factors that can sway their results where the same lens on the multiple cameras could score close to each other.
So again, you are looking at it from the wrong perspective and assume the problem is the A77. What you really need to be asking are the following:
  • Why do the DxO tests consistently show the Sony APS-C sensors testing worse in the corners when comparing results of the same lens across multiple 1.5x APS-C sensors?
  • Why do the DxO tests consistently show the Sony APS-C sensors testing better in light transmission when comparing results of the same lens across multiple 1.5x APS-C sensors?
  • Why do the DxO tests consistently show the Sony APS-C sensors testing better in vignetting when comparing results of the same lens across multiple 1.5x APS-C sensors?
  • If the above holds true, does Sony do something different with their sensor microlenses that hurts corner sharpness in exchange for improved vignetting and light transmission?
Paul
Hi Paul
For some reason this link does not work for me.
This link is OK.
I know this is the primary principle, and this is the underlying principle that DXO is trying to prove with their numbers.
So basically what it all means to me is that we have 24 meg APS-C sensors, but will never realise their full potential. We may as well be shooting with zoom lenses and 10 Megapixel sensors that work better together. Or alternatively shoot primes to get the closest match as possible.
This link does not work either.
I am not assuming something is wrong with the a77. I am testing whether the 24 Megapixel sensor and camera implementation is contributing to the lack of resolution a lens can achieve with this sensor, particularly what was implemented in the a77. When we place a lens on a camera, the sensor is not the only hard variable. There is other hardware, firmware that come into play.
As mentioned, I understand the reason for the numbers, what DXO is trying to achieve by comparing lenses and their resolvability on certain sensors. What this process does not factor in is the variability on the camera side. Then again as you have mentioned it does not account for variation in lens quality control either.
Paul
EvilOne
EvilOne Forum Pro • Posts: 13,970
so much is wrong.... so much is wrong
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
I am actually thinking of going down Fuji route. Don't really like lenses on nex or their price. But the price of A6000 is tempting.
