D610, does it have bulb mode?
Started Feb 14, 2014 | Discussions
Mark_A Veteran Member • Posts: 9,925
Checking out the quick review here, I like the D610, can't afford it at the moment but the spec sheet says slowest shutterspeed 30 seconds.. does that mean it does not have bulb mode?
Mark
Nikon D610
SeymourButts Regular Member • Posts: 113
Re: D610, does it have bulb mode?
Mark
Yes it does. It also has video,2 card slots ,pop-up flash.... Unlike other cameras in the Nikon line-up.
Mark_A OP Veteran Member • Posts: 9,925
SeymourButts wrote:
Mark
Thanks SeymourButts
I like it, I couldn't go so far as the D800 which for me would be overkill but the 610 could be about right.
I suppose dpreview will put a full review up in time, or is it because the D610 is so similar to the D600 that they haven't done it?
Mark
ata3001
ata3001 Contributing Member • Posts: 599
Another YES that it has Bulb. I use it quite often. I have set up U2 to, by default, be in manual, Bulb mode & with back button focus.
 ata3001's gear list:ata3001's gear list
Nikon Coolpix P7700 Nikon Coolpix A Nikon D700 Nikon D610 Nikon AF Nikkor 24mm f/2.8D +33 more
Simon Garrett Veteran Member • Posts: 4,924
I doubt it.
Yes, that would be my guess. The only thing of significance to change is the shutter design, to remove the oil spray feature. From the dpreview quick-look review:
The new D610 is a very minor upgrade to the D600, with just three new features. They include faster continuous shooting, a 'quiet continuous' mode, and an improved auto white balance system. The first two features are courtesy of a newly designed shutter mechanism.
Simon
 Simon Garrett's gear list:Simon Garrett's gear list
Nikon D800
Simon Garrett wrote:
I doubt it.
Hi Simon,
I was considering looking at D600 because with the oil issue they might be quite a bit cheaper. I don't mind cleaning the chip regularly. But I see they are not discounted by much over the D610.
Mark
romfordbluenose Senior Member • Posts: 2,055
Why don't you download the manual from the Nikon website. It'll  help you make up your mind, answer most of your questions and then let you ask additional questions on this forum.
 romfordbluenose's gear list:romfordbluenose's gear list
Nikon D800 Nikon D5300 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR Nikon AF-S Nikkor 50mm f/1.8G +8 more
mais51
mais51 Senior Member • Posts: 1,695
I doubt it.
Hi Simon,
Mark
They are not discounting the D600 because they have to factoring in the cost of the extra warranty services !   , seriously why would you want to go there - rumor has it that Nikon is replacing the D600 with the D610 as part of their warranty service.
 mais51's gear list:mais51's gear list
Canon PowerShot S120 Nikon D300S Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +8 more
mais51 wrote:
I doubt it.
Hi Simon,
Mark
Yes, I quite quickly discounted the idea, the 610 is the one for me.
My current dslr is 13 years old, a D610 will be a big step up in many ways.
Mark
Oh, OK, I didn't know you could do that. Thanks for the info.
I might well, then I can read it while I save my pennies
Mark
aus4ever
aus4ever Veteran Member • Posts: 8,832
Mark
I prefer electronic to paper for a quick search.  I downloaded it from here.
D610 user manual
Page 79.
Bamboo ~
Defiant of all the beats it takes, it bends ... but not to bow too low,
And it cares not which direction the wind may blow.
 aus4ever's gear list:aus4ever's gear list
Canon PowerShot S100 Nikon D700 Nikon D610 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +7 more
