Full Size Image Champaign Splash! D800E + 58mm. What do you think?
Started Feb 14, 2014 | Discussions
bmcdad
bmcdad Regular Member • Posts: 313
10
Nikon D800E
lickity split
lickity split Senior Member • Posts: 2,591
Looks great (full size) nt.
 lickity split's gear list:lickity split's gear list
Nikon D810 Nikon D500 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Micro-Nikkor 200mm f/4D ED-IF +10 more
low3llSD Regular Member • Posts: 263
Re: Full Size Image Champaign Splash! D800E + 58mm. What do you think?
i thought the 58G wasnt capable of making great images?!
 low3llSD's gear list:low3llSD's gear list
Nikon Df Nikon AF-S Nikkor 58mm f/1.4G Nikon AF-S Nikkor 24mm f/1.4G ED Nikon AF-S Nikkor 85mm f/1.4G Nikon AF-S Nikkor 14-24mm f/2.8G ED +4 more
JJ168 Contributing Member • Posts: 522
Or sharp image...
 JJ168's gear list:JJ168's gear list
Nikon D810 Nikon AF-S Nikkor 18-35mm f/3.5-4.5G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28mm f/1.8G
(unknown member) Senior Member • Posts: 4,624
Very nice.
Amateur photographer. Enjoy.....believe in yourself..
 Bajerunner's gear list:Bajerunner's gear list
Nikon D300 Nikon AF-Nikkor 80-200mm f/2.8D ED +8 more
Araucaria Forum Member • Posts: 85
It's full of oilspots and I can see you used left AF on the bottom of the glass hence the soft image. You can also see the amp glow destroying tonality.
Great image btw!
Wahrsager Regular Member • Posts: 152
I think it's a nice start.
I wish the berry-color was more rich, prominently lit.  (The beautiful red color gets lost in shadow).
I wish there wasn't what appears to be evidence of a previous splash.
I think compositionally, it'd be better if the splash where higher.  (Drop the berry from a greater height perhaps).  It's more of a "kerplunk" not an energetic "splash!"
I wish the seam between the horizontal and vertical surface was perfect.  It's slightly uneven, almost looks like a welding bead.
I wish the hotspot on the back surface had a more gradual transition.
I think it'd be nice to have some level of rim-lighting to make the glass pop more from the muddy backdrop.
I wish overall, it was higher-key and slightly more vibrant.
I hope you find my observations valuable.
 Wahrsager's gear list:Wahrsager's gear list
Nikon D7000 Nikon D800 Nikon D800E Nikon D4S Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED +15 more
bmcdad
bmcdad OP Regular Member • Posts: 313
Thank you so much for your valuable feed back... I'll reshoot while taking some of your point into inconsideration.
Thanks again!
jaypike Regular Member • Posts: 163
Awesome! And inspiring!  I'd love to know more specifics of how you set this up.  It looks simple enough.
Personally, I like the low-key nature of this specific image, but, I can see the previous posters points but only if you would want to offer a range of different versions of the same concept.
Commercially, this has value, but, most clients want a whole spread of the same concept so they can make their choice.
For instance, this would would make a perfect split page spread for something with a title like "make a splash"... and yes, shooting dead center in the image is most desirable so the client can choose which orientation they want to use the image in based on ad purchases.
Nicely done... a great stock photo shot here!
 jaypike's gear list:jaypike's gear list
Nikon D4S
bmcdad
Hi there and thank you of the feedback. I hope the image here can help demonstrate a little bit from the setup. This was a two light setup one light (Einstein) for the backdrop with a 7" reflector and another light with a reflector as well straight overhead to highlight drops and glass rim.
I will repeat this effort tomorrow and add another light with a snoot to light the front of the glass to light the front + berry like suggested. Can't add braod lighting in the front to not lose the splash but I will try to light the center of the glass only.
Sergey_Green
Sergey_Green Veteran Member • Posts: 8,894
I think it looks very good ..
.. exceptionally good!
- sergey
 Sergey_Green's gear list:Sergey_Green's gear list
Samsung Galaxy Note 10.1
WIMorrison Senior Member • Posts: 1,463
Sometimes it is better to leave what you think as thoughts than actually writing them down.
personally, I think it is an excellent shot and it inspires me to try and emulate it.
Iain Morrison LRPS CPAGB
wimorrison.co.uk
 WIMorrison's gear list:WIMorrison's gear list
Nikon D7000 Nikon D800E Sigma 50-500mm F4.5-6.3 DG OS HSM Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Micro-Nikkor 60mm f/2.8G ED +13 more
wimorrison.co.uk
Thank you for your observation.  In my profession, I must deal daily with what may seem as harsh criticism.  I believe my honest and unedited observations will benefit the original poster optimally rather than coddling him/ her.  I apologize for any offense I have caused you.
frenchy01 Regular Member • Posts: 282
Bill, it looks very nice. I like the setup, the lighting and the sharpness...but two things bother me:
1) the colour of the "champaign": it is too orange, more cognac than champaign...
2) where are the bubbles?
...which makes me think you did not use real champaign but coloured water? (or the bubbles disappeared after 20 trials?) I would also make my trials with another liquid and only use champaign on the final shot...;-)
Frenchie
bmcdad
Frenchie
Frenchy! this was not Champaign you are right... Canada dry
bmcdad
Another try with brighter front.
wimorrison.co.uk
axcentphoto
axcentphoto Senior Member • Posts: 1,392
Very nice. I did a similar shot in a Martini glass and drolled a Key Lime into Bombay Gin. It me over 120 shots to get it right! Have a look   http://axcentphoto.com/commercial   Brent
 axcentphoto's gear list:axcentphoto's gear list
Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +2 more
bmcdad
Very Nice!
AlephNull Senior Member • Posts: 1,308
I'm surprised no one has mentioned that the correct spelling is "champagne"
Unless it's meant as a joke for "champagne campaign"?
 AlephNull's gear list:AlephNull's gear list
Sony RX100 II Nikon D810 Canon EOS 5DS
