Exif viewer
Started Feb 14, 2014 | Discussions
djddpr Veteran Member • Posts: 5,381
Exif viewer
A new exif data viewer from Nir Sofer, v. 1.1. There are several exif data viewers available, but a product from Nir Sofer always catches my interest.  As with all Nir Sofer utilities, it is effective, small (98 KB), portable (no installation -- just unzip to a folder of choice), and free. It is now my exif viewer of choice.  It can be obtained from:
Nir Sofer website, http://www.nirsoft.net/utils/exif_data_view.html
or
Portable Freeware, http://www.portablefreeware.com/index.php?id=2280
David Dollevoet
kkardster
kkardster Senior Member • Posts: 6,859
Re: Exif viewer
Looks rather limited.  I prefer using EXIFTool and EXIFToolGUI along with a custom file so what I see matches what my camera's menus present.
Bruce
You learn something new every time you press the shutter
 kkardster's gear list:kkardster's gear list
Panasonic Lumix DMC-LZ7 Panasonic Lumix DMC-FZ200 +5 more
Jerry045
Jerry045 Senior Member • Posts: 6,464
Re: Exif viewer
David:
Check out PhotoMe.    http://www.photome.de/
It shows a lot more info on the camera settings.  It is free also.
www.flickr.com/photos/av8tor045
Jerry
 Jerry045's gear list:Jerry045's gear list
Panasonic Lumix DMC-FZ150 Panasonic Lumix DMC-ZS20 Sony a6000 +7 more
Erik Ohlson
Erik Ohlson Forum Pro • Posts: 16,728
Re: Exif viewer
Bruce
I downloaded and installed this on my iMac, but cannot find it anywhere in my computer to use it.
There was something about typing in a "Terminal Window" - whatever THAT is.
Sounds quite final, er, terminal
"Measure wealth not by things you have but by things for which you would not take money"
www.flickr.com/ohlsonmh/ ohlsonmh@yahoo.com
kkardster
Re: Exif viewer
Jerry045 wrote:
David:
I use PhotoMe as well, but it is not customizable as is EXIFTool.
Bruce
Jerry045
Re: Exif viewer
Bruce:
I just found PhotoMe two days ago, and I have not had time to do any playing with it yet. Thanks for the tip on the EXIF Tool. I think I downloaded it also.
Jerry
kkardster
Re: Exif viewer
Jerry045 wrote:
Bruce:
Hi Jerry,
Here's a mid-thread link that will help you with EXIFTool - check it and a few subsequent posts.
EXIFTool and FZ customization
Bruce
kkardster
Re: Exif viewer
Erik Ohlson wrote:
Bruce
Sorry Erik,
EXIFTool is a command-line utility, so it typically requires a terminal (text) window to run it.  It supports Windows, Mac, and Unix.
For Windows, there's a front-end EXIFToolGUI which provides a windows-based interface but EXIFToolGUI appears to support Windows only.
Bruce
djddpr OP Veteran Member • Posts: 5,381
Re: Exif viewer
My thanks to all who commented.  I tried the suggestions offered and have settled on Jerry045's recommendation of PhotoME.  It is much larger than Nir Sofer's program but it communicates better and has a histogram.
David Dollevoet
Erik Ohlson
Re: Exif viewer
kkardster wrote:
Erik Ohlson wrote:
Bruce
Sorry Erik,
Bruce
OK, I can accept that, even if I don't understand it.
I downloaded the "Mac" version, so, one would think it might be supposed to work on a "Mac".
Does anyone know how this might be done?
kkardster
Re: Exif viewer
Hi Erik,
Sorry, I'm not a Mac user but the might help - if you really want to bother.  EXIFTool should work but the EXIFToolGUI graphical front-end will not, meaning you'll be entering a textual world that you may not be familiar with. and may not be useful to you.
Note that by default, the terminal window will open on your home folder, so you'd have to navigate to the folder where your images reside. Instead, I suggest enabling the service that allows launching the terminal against the current folder:
  • Under System Preferences, select Keyboard > Shortcuts > Services. Find "New Terminal at Folder" in the settings and click the box.
You should now be able to right-click in the Finder and select Services > New Terminal at Folder to launch a terminal on the selected folder. You can turn this off by simply unchecking the "New Terminal at Folder" checkbox under System Preferences.
Once the terminal is launched, you should be able to execute the EXIFTool against one or more images. Here's example output for a single file using default settings (no optional arguments) - it's not real user-friendly...
ExifTool Version Number : 9.24
File Name : P1050864.jpg
Directory : .
File Size : 4.8 MB
File Modification Date/Time : 2013:04:04 13:40:40-05:00
File Access Date/Time : 2013:04:06 14:03:47-05:00
File Creation Date/Time : 2013:04:06 14:03:47-05:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : Panasonic
Camera Model Name : DMC-FZ200
Orientation : Horizontal (normal)
X Resolution : 180
Y Resolution : 180
Resolution Unit : inches
Software : Ver.1.0
Modify Date : 2013:04:04 14:40:41
Y Cb Cr Positioning : Co-sited
Exposure Time : 1/500
Aperture : f/4
Exposure Program : Program AE
ISO : 100
Sensitivity Type : Standard Output Sensitivity
Exif Version : 0230
Date/Time Original : 2013:04:04 14:40:41
Create Date : 2013:04:04 14:40:41
Components Configuration : Y, Cb, Cr, -
Compressed Bits Per Pixel : 4
Exposure Compensation : -0.33
Max Aperture Value : 2.8
Metering Mode : Center-weighted average
Light Source : Unknown
Flash : Off, Did not fire
Focal Length : 108.0 mm
Image Quality : High
Firmware Version : 0.1.0.0
White Balance : Auto
Focus Mode : Auto
AF Area Mode : 1-area
Image Stabilization : On, Mode 1
Macro Mode : Off
Shooting Mode : Program
Audio : No
Data Dump : (Binary data 8200 bytes, use -b option to extr
act)
Panasonic 0x0022 : 0
Flash Bias : 0 EV
Internal Serial Number : (O08) 2012:08:24 no. 0014
Panasonic Exif Version : 0401
Panasonic 0x0027 : 0
Color Effect : Off
Time Since Power On : 00:02:23.62
Burst Mode : On
Sequence Number : 4
Contrast Mode : Normal
Noise Reduction : -1
Self Timer : Off
Panasonic 0x002f : 1
Rotation : Horizontal (normal)
AF Assist Lamp : Enabled but Not Used
Color Mode : Normal
Optical Zoom Mode : Standard
Conversion Lens : Off
Travel Day : n/a
Panasonic 0x0037 : 257
Panasonic 0x0038 : 2
World Time Location : Home
Program ISO : 100
Advanced Scene Type : 1
Faces Detected : 0
Panasonic 0x0043 : 2
Color Temp Kelvin : 0
WB Shift AB : 1
WB Shift GM : 0
Flash Curtain : None
Panasonic Image Width : 0
Panasonic Image Height : 0
AF Point Position : 0.5 0.5
Num Face Positions : 0
Panasonic 0x004f : 0
Panasonic 0x0050 : 0
Panasonic 0x0055 : 1
Panasonic 0x0057 : 0
Panasonic 0x005e : .
Faces Recognized : 0
Flash Warning : No
Recognized Face Flags : 0 0 0 0
Title :
Baby Name :
Intelligent Resolution : Off
Panasonic 0x0072 : 0
Panasonic 0x0073 : 0
Panasonic 0x0074 : 0
Panasonic 0x0075 : 0
Panasonic 0x0076 : 0
Panasonic 0x0077 : 5
Intelligent D-Range : Off
Panasonic 0x007a : 0
Panasonic 0x007c : 0
Panasonic 0x007d : 0
Panasonic 0x007e : 0
Photo Style : Vivid
Panasonic 0x008b : 0
Panasonic 0x0092 : 0
Panasonic 0x0093 : 0
Panasonic 0x0094 : 0
Panasonic 0x0097 : 0
Panasonic 0x0098 : 0
Panasonic 0x009d : 0
Panasonic 0x2003 : ....@A .
Maker Note Version : 0141
Scene Mode : Off
Panasonic 0x8002 : 1
Panasonic 0x8003 : 1
WB Red Level : 2156
WB Green Level : 1060
WB Blue Level : 1911
Flash Fired : No
Text Stamp : Off
Baby Age : (not set)
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 4000
Exif Image Height : 3000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Custom
Exposure Mode : Auto
Digital Zoom Ratio : 0
Focal Length In 35mm Format : 600 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Hard
PrintIM Version : 0250
Print IM 0x0001 : 0x00160016
Print IM 0x0002 : 0x00000000
Print IM 0x0003 : 0x00000064
Print IM 0x0007 : 0x00000000
Print IM 0x0008 : 0x00000000
Print IM 0x0009 : 0x00000000
Print IM 0x000a : 0x00000000
Print IM 0x000b : 0x000000ac
Print IM 0x000c : 0x00000000
Print IM 0x000d : 0x00000000
Print IM 0x000e : 0x000000c4
Print IM 0x0100 : 0x00000005
Print IM 0x0101 : 0x00000001
Print IM 0x0110 : 0x00000080
Compression : JPEG (old-style)
Thumbnail Offset : 11776
Thumbnail Length : 7710
MPF Version : 0100
Number Of Images : 2
MP Image Flags : Dependent child image
MP Image Format : JPEG
MP Image Type : Large Thumbnail (full HD equivalent)
MP Image Length : 595402
MP Image Start : 4476416
Dependent Image 1 Entry Number : 0
Dependent Image 2 Entry Number : 0
Image Width : 4000
Image Height : 3000
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Advanced Scene Mode : Off
Blue Balance : 1.80283
Image Size : 4000x3000
Preview Image : (Binary data 595402 bytes, use -b option to ex
tract)
Red Balance : 2.033962
Scale Factor To 35 mm Equivalent: 5.6
Shutter Speed : 1/500
Thumbnail Image : (Binary data 7710 bytes, use -b option to extr
act)
Circle Of Confusion : 0.005 mm
Field Of View : 3.4 deg
Focal Length : 108.0 mm (35 mm equivalent: 600.0 mm)
Hyperfocal Distance : 539.17 m
Light Value : 13.0
Bruce
Erik Ohlson
Re: Exif viewer
Wow -- that's a lot !!
kkardster
Re: Exif viewer
PhotoMe is pretty good, just be aware that it is now 5 years old and all development ceased long ago. Note that you can use the arrow keys to move from image to image.  It does automatically integrate with other imaging software, so you can launch other image viewers and editors from PhotoME.
You can also enter filters to limit what you see - for example, to display the JPEG settings, enter the following into the Filter field (you may need to type ctrl-F to open the filter panel if it isn't already at the bottom of the program display):
  • 0089;NoiseReduction;Sharpness;Saturation;Contrast
The "0089" is the tag number for the PhotoStyle setting, which PhotoME doesn't decode. The Panasonic FZ values for PhotoStyle/Tag 0089 are:
  • 0 => 'Auto',
  • 1 => 'Standard or Custom',
  • 2 => 'Vivid',
  • 3 => 'Natural',
  • 4 => 'Monochrome',
  • 5 => 'Scenery',
  • 6 => 'Portrait',
It's the ability to customize EXIFTool to display camera-specific values using the same designations are why I prefer it.  EXICTool also has the ability edit EXIF data, making corrections to timestamps or the addition of GPS data, etc., possible.
One feature of PhotoME I wish worked better is the ability to display the focal point used for the images on its thumbnail image - I've learned through trial and error that this feature does not work very well for my FZ-series images.
Bruce
