D600/D610 users with kids: what AF mode do you use?
Started Feb 14, 2014 | Discussions
jintoku Contributing Member • Posts: 621
I am finding the 39-point area too restrictive so recently switched to center point AF. I also seem to get more consistent results with AF-S than AF-C.
This is just an informal survey to see what other folks are doing to get their little ones in focus?
 jintoku's gear list:jintoku's gear list
Sony Cyber-shot DSC-RX100 III Fujifilm X-T1 Olympus E-M5 II Sony Alpha 7R II Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED +6 more
Nikon D600
Dave Courtenay Contributing Member • Posts: 724
Re: D600/D610 users with kids: what AF mode do you use?
Although i do not have a D600/610 i do have 2 D800/E, I would use AF-C with back button focusing, If it moves then AF-C is the only way to go
www.wildlifeinfocus.com
www.davidcourtenayphotography.com
Sponsor me for Cancer Research www.walkingforacure.org
 Dave Courtenay's gear list:Dave Courtenay's gear list
Nikon D800 Nikon D800E Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 600mm f/4G ED VR +9 more
AndyW17 Contributing Member • Posts: 617
I set up the AE/AF lock button to force C-AF ON (buried in the menus) and then use CAF on demand.  Single/center focus seems to work best for me, but I've seen people comment that using d9 can also work well.  I shoot manual, Auto-ISO, and depending on the lighting will set up the minimum ISO to ensure I get the right exposure range, and I pretty much leave aperture set to a reasonable DOF.  Trigger button must be set on release, not Focus, with the assumption being that you'll have the C-AF running before you fire the shot so you can just fire when you like the shot.
With a fast lens, the camera does extremely well in most settings.
The settings are saved on U1.
I've used this at social events and triathlons with high success rates.
The main downside is that if you hand the camera to someone else, then they won't remember to hit that AE/AF lock button, so change it before you take a volunteer to do your portrait…..
Andy
 AndyW17's gear list:AndyW17's gear list
Sony RX100 II Olympus E-M1 Nikon D750 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
jintoku OP Contributing Member • Posts: 621
Thank you, that sounds very much worth trying!!
Andy
See this thread also. Note the comment about turning tracking focus OFF in A3.
http://www.dpreview.com/forums/thread/3623764
Good luck!
Andy
