Tokina 11-16mm f/2.8
Started Feb 14, 2014 | Discussions
DaveOl
DaveOl Veteran Member • Posts: 3,073
Anyone have any experience with this lens?  Is it better than the Tokina 12-24mm f/4 lens which is about half the price.
I may be going to Mammoth Cave next month and have been looking for a fast wide angle lens for my Nikon D 300s.  No flash is allowed in the cave.
The only wide angle lens with VR is a Nikon for a lot more money and not as wide.
I may be able to use a monopod, but I will call and ask about it.  Someone has suggested a solution from Kirk that screws into your tripod socket and you step on the strap to keep it steady.  It is around $ 30 though.
 DaveOl's gear list:DaveOl's gear list
Nikon D300S Epson Stylus Photo PX720WD
Abu Mahendra Senior Member • Posts: 4,011
Re: Tokina 11-16mm f/2.8
Wide angle Tokinas tend to be hamstrung by poor chromatic aberration and flare resistance performance. Caveat emptor.
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm f/2.8L Macro IS USM Canon EF 70-200mm f/2.8L IS II USM Canon EF 70-200mm f/4L IS USM Canon EF 24-70mm f/2.8L II USM Canon EF 40mm f/2.8 STM +4 more
DaveOl
DaveOl OP Veteran Member • Posts: 3,073
I've heard about the flare problem before, but not about the other.  Thanks for the answer.
Lenstip described the Purple Fringing of that lens as "monstrous".
>>A huge level of chromatic aberration is a nightmare of wide angle Tokinas. The predecessor of the tested lens had big problems in this category as well, so did many other instruments (it’s enough to mention here the 12-24 mm, the 16-50 mm or the 16.5-135 mm lenses). It’s high time the producer did something with that aberration because the rivals deal with it much better.<<
Read it yourself here:
http://www.lenstip.com/379.5-Lens_review-Tokina_AT-X_116_PRO_DX_II_AF_11-16_mm_f_2.8_Chromatic_and_spherical_aberration.html
DaveOl
Thanks, Abu
It looks like the problem doesn't get much better by stopping down either.  I might just pass on the lens.
SeaScout851 Veteran Member • Posts: 6,199
Re: Tokina 11-16mm f/2.8 - An Example
Here are two shots taken first with the canon 15-85 at 15mm.  The second with the tokina 11-16 at 11mm.  Both were shot under similar conditions.  The first being Oct. 4, 2014 the second Oct. 10, 2014.  The CA problems can be seen around the tree limbs and leaves.  I did not try to remove it.
Andy
DaveOl
You must be talking about the purplish fringe around the tree branches.
Yes.  Note that this can be removed with software.  I've just not done it.
Andy
DaveOl
Thanks, I thought it could be removed.  Doesn't the Nikon D 300s remove some of this if you use JPEG?
evan47
evan47 Senior Member • Posts: 1,029
Andy
dont forget the tokina will also give white fringing on high contrast edges, ie architecture too. this cannot be removed. most ultrawides do this on dx format. dont know why.
 evan47's gear list:evan47's gear list
Nikon D7000 Nikon D7100 Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Teleconverter TC-14E II +6 more
Jim Funston Senior Member • Posts: 1,690
Though many seem to love this lens I am far less enthuesiastic about my copy. Night time or sunrise/sunset flare is horrible and my copy would not focus at infinity. I found a web article on this infinity focus thing and opened mine up and adjusted this for myself.
I personally do not recommend this lens due to the results I have gotten from my copy.
Pi lover
Pi lover Regular Member • Posts: 422
Re: Tokina 12-24 F4
I've got the Tokina 12-24 and it isn't what I'd consider a low light lens like you would want for caves.
Another choice for a steadier monopod:  I attached a cane foot to the bottom of mine.  It took about a half inch of cutting with the hacksaw to let it split wide enough to fit since the canes tend to be wider.  Push the tripod end in and tighten the bolt on the bottom of the cane foot and it's not coming off.  You can stand on it similar to with the strap but I suspect it's got a steadier base on all sides.
Tokina 12-24 moonlight.  25 seconds on a monopod - D90 ISO 100
Cane foot on the bottom of the monopod.
ABA DABA Veteran Member • Posts: 3,069
Re: Tokina 12-24 F4
Nice looking set up, I did the same thing on my monopod, works great.
ABA DABA
 ABA DABA's gear list:ABA DABA's gear list
Nikon D500
alex41 Regular Member • Posts: 306
Re: Tokina 12-24 F4
Hi,
I have the Tokina 11-26/2.8 version II on my D7100. This is a very sharp lens but have purple fringing that can be fixed in Lightroom. Frequently I have flare shooting in strong light but this can be avoided by changing the shooting angle. Also the lens needs -0.7 EV exposure compensation at 16mm.
I have some full-size (6000X4000) pictures from 11-16 in my Flicker set.
http://www.flickr.com/photos/yazici/sets/72157637574140473/
Pi lover
Re: Tokina 12-24 F4
alex41 wrote:
Hi,
Great results on the 11-16 on your Flcker set.  When they have enough light and you go to the higher f stops they shine !!!  I love the way clouds/ scenes become almost 3d with these lenses.
Grant
nkistrup
nkistrup Senior Member • Posts: 1,700
GORGEOUS sunset pictures! (n/t)
No text.
 nkistrup's gear list:nkistrup's gear list
Canon PowerShot G12 Olympus XZ-1 Nikon D7100 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S Nikkor 14-24mm f/2.8G ED +4 more
DaveOl
Re: Tokina 11-16 mm lens
After thinking about this a few days, I might be better off buying a used Nikon 16-85 mm VR lens for about the same price.
I looked at some cave shots I took a year or two ago and I mainly used my zoom between 24mm to 50 mm for all the pictures.  They were shot at ISO 320, f/5.6, at 1/60th of a second with the Nikon SB 22s Flash.  However, no flash is allowed in Mammoth Cave, hence the VR may be the best answer. Plus the 16-85 is a much more versatile lens than the 11-16.
Formation in Cumberland Caverns , Tn
Besides the VR might eliminate the need to carry or use a monopod.
