Show your 300mm pics(while we wait for 2015)
Started Feb 13, 2014 | Discussions
herebefore
herebefore Veteran Member • Posts: 3,296
ZD 70-300 with adapter @ 300 mm in poor light.
I was practicing Hand Holding technique with an un-stabilized lens & camera combo.
Very cold and breezy day.  This stream froze over in about 3 hours..
Larry Lynch
Mystic, Connecticut
Be Careful, sleep can be a symptom of caffeine deprivation
I figured out why I cant lose weight! The only exercise Im good at is CHEWING
Don't take yourself so seriously. No one else does
In all matters of opinion, our adversaries are insane.
Oscar Wilde
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 12,530
Two Birds
Black-tailed Godwit G6 100-300 cropped
Greenshank G6 100-300 + Ex Tele Conv + cropped
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S
daddyo Forum Pro • Posts: 11,169
A couple 'Tree Rat' shots, and a 'Busy Bee'...
These were alll shot with my Oly m75-300mm all at 300mm, and all using the DTC Function (1200mm FF equivalent)
The squirrel shots were from yesterday morning.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8
Martin.au
Martin.au Forum Pro • Posts: 10,317
Re: Two Birds
A blingtastic godwit.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +6 more
pede59 Senior Member • Posts: 1,270
Re: Panny 100-300: A fine, sharp lens at 300 mm
Looks really sharp. I was considering getting a 300mm manual lens such as Canon FD 300 f4L but this is substantially bigger. Makes me think.
BillSprague Contributing Member • Posts: 865
How about a 5 second video clip of a squirrel's whiskers at 300mm?
https://vimeo.com/86797961
Bill Sprague
 BillSprague's gear list:BillSprague's gear list
Sony RX100 Panasonic Lumix DMC-LX100 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 ASPH. / Power O.I.S Panasonic Leica 100-400mm F4.0-6.3 ASPH +2 more
John Russell NZ Regular Member • Posts: 226
Re: A couple 'Tree Rat' shots, and a 'Busy Bee'...
Great shots and sharp too. Just curious, what is the dtc function?.  Thanks, John
 John Russell NZ's gear list:John Russell NZ's gear list
Nikon 1 V1 Nikon 1 Nikkor VR 10-30mm f/3.5-5.6 Nikon 1 Nikkor VR 30-110mm f/3.8-5.6
Erick L Contributing Member • Posts: 889
E-M5 & Panny 100-300
Turkey - Pointe Pelée
Gray Whale while sitting at Chez Monique's
Erick - www.borealphoto.com
varanus Regular Member • Posts: 205
Re: Zuiko 300mm f2.8 + E-M1
Shot wide open.
Ruddy-Breasted Crake, a small and normally shy waterbird.
www.flickr.com/photos/wokoti/
stevedigiphoto
stevedigiphoto Regular Member • Posts: 301
Re: Show your 300mm pics(while we wait for 2015)
Superb images well done, here are some from me with the Panny 100-300.
 stevedigiphoto's gear list:stevedigiphoto's gear list
Panasonic Lumix DMC-LX100 Fujifilm X-E1 Nikon D810 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED +9 more
John,
The DTC is short for 'Digital Teleconverter' Function. Several Oly m4/3's cameras, including the E-M5 and E-M1, have this function.
Essentially, with this function engaged the camera crops the original file dimensions by 1/2 to the center of the frame, then resamples that resulting 4 MP file back to a full 16 MP Jpeg file.
The results are very good from my experience and result in very good detail. The benefit is that you can view and compose the final image in the viewfinder while shooting, and what you are getting is a 2X FOV from any given focal length. So the 75-300mm (150-600mm FF equivalent) gives you a 150-600mm FOV (300-1200mm FF equivalent) when using the DTC.
Of course you can do the same thing in post processing -- the DTC simply saves you all the extra work.
I have my DTC Function assigned to my 'Record' Button, so I can easily toggle it on and off.
God Bless,
Greg
Lawrence W Contributing Member • Posts: 570
G5 + 100-300
G5 + 100-300
 Lawrence W's gear list:Lawrence W's gear list
Panasonic Lumix DMC-LX5 Olympus OM-D E-M5 Panasonic Lumix DMC-G5 Olympus PEN E-PM2 Nikon D7100 +13 more
My previous submissions were taken by G5+100-300 in a bird sanctuary. This is shot with at HK Bird Park with EM-5 + 75-300
SterlingBjorndahl Senior Member • Posts: 1,862
GH2 with Panny 100-300. I backed off a bit from full zoom for framing, then changed my mind in PP and cropped a bit, so I think this image is within the spirit of this thread.
What I like about this photo technically is how the boardwalk shows the limited depth of field when this lens is wide open, and how it has pretty good resolving power wide open even at (almost) full zoom as long as you keep the shutter speed high enough (1/1000 in this case) - zoom in on the skates and you can see quite a bit of detail.
Shot in Raw and PP in Photoshop.
Inline
Sterling
Lens Grit
 SterlingBjorndahl's gear list:SterlingBjorndahl's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot ELPH 330 HS Olympus E-1 Panasonic Lumix DMC-L1 Olympus PEN E-PL1 +11 more
Brian Wadie
Brian Wadie Veteran Member • Posts: 6,906
Robin Through the Conservatory Window
its amazing how good light helps, the first for a long while in the UK, cropped to about 50% of original frame the Robin is at about 15ft from the window.
A hand-held shot with the 75-300 mk2 on my EM-1
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 Canon EOS 7D Mark II Canon EF 70-300mm f/4-5.6L IS USM Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 +1 more
LTZ470
LTZ470 Forum Pro • Posts: 11,926
Re: A few from the 100-300...
Really there is a God...and He loves you..
FlickR Photostream:
www.flickr.com/photos/46756347@N08/
Mr Ichiro Kitao, I support the call to upgrade the FZ50.
I will not only buy one but two no questions asked...
