dp2 Quattro ergonomic study using a mockup
Started Feb 13, 2014 | Discussions
(unknown member) Contributing Member • Posts: 741
How do you know that?
Erik Magnuson wrote:
mrkr wrote:
the effects of the close proximity between battery and sensor by implementing RAWs as '11 + 7-bit lossy compression scheme: 11-bit range with 7-bit delta values from 14-bit pipeline (8 bits per pixel in effect)'.
Huh? Since this compression impacts sharp tonal transitions, it's not something that would matter for electrical noise which is typically low level banding or something like thermal noise.
jennyrae Senior Member • Posts: 2,690
Re: External signal interference
very good point and possibility.  also I think it is useless to even out dimension of camera at back for no reason than hollow space. was thinking of making screen articulate but I think it will add more complexity and electronic component to camera given location of screen directly at back of sensor.  it is nice option but we will see.
mmr Contributing Member • Posts: 758
Re: dp2 Quattro ergonomic study using a mockup
I hold my dp2m by using the strap to wrap around my wrist, and then hold the camera when I take a shot and let it dangle otherwise.  What happens if you use a strap?
Here's an example:
and:
It seemed to me, when I saw the design, that the use of the strap in this way would make the camera design feasible.  Is that something you could try?
 mmr's gear list:mmr's gear list
Sigma DP2s Sigma DP2 Merrill Sigma dp2 Quattro Nikon D300 Olympus E-M1
Erik Magnuson Forum Pro • Posts: 12,237
Re: How do you know that?
Logic.  What does that noise look like?  What types of artifacts result from that compression?  How would the two combine?  Think about it for a little.
Erik
 Erik Magnuson's gear list:Erik Magnuson's gear list
Canon EOS 5D Mark II Canon EOS 450D Sigma SD10 Sony Alpha NEX-5 Nikon D3200 +28 more
Prime85 Senior Member • Posts: 1,007
That is dedication!  Well done!
HBowman
HBowman Senior Member • Posts: 1,211
HBowman wrote:
It is wide because the battery is bigger and to minimize electromagnetic interferences with the sensor, which is very sensible to electromagnetism.
Why is this sensor more sensitive than any other active-pixel CMOS sensor?
Shielding very efficiently DP sensors, this one or the old ones, require some big amount of material.
So how does Sony do it in the RX1 with a much larger sensor but still compact body?
Erik
With the foveon chip, who need more power than bayer to work because there is 3 layers to read, even a high photon flux can be a problem. Electrons and magnetic flux are a problem. The DPM series do not have more powerful batteries because it would have impacted the IQ in a large margin. Low power >> low emission.
Shielding a camera is an additional in the process. If you want to keep price as cool as possible you need compromises. A camera is an equilibrium. design >> internal.
On the Merrill series, most of the banding can be interpreted as a frequency. This frequency can have 3 sources, the screen, the processor and the batteries.
My wild guess is that the battery AND the True III proc are far away from the sensor.
Kendall Helmstetter Gelner MOD Forum Pro • Posts: 19,351
That's a pretty impressive job of a mockup.  To me it doesn't look hard to hold from your photo... but I await holding one in person to see.  I think for instance using the rear D-Pad is something you'd be doing with two hands anyway, and it seems like the design is swept back to make the wheels easier to access.
The camera is wide I think for a few reasons:
1) A battery that large would have made the current DP-M body thicker.
2) Keeps electronics farther from sensor.
3) Better dissipation of heat.
4) Overall design can be much thinner.
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
Mike Gerstner Veteran Member • Posts: 3,851
Another possibility
hold it like you would a dslr....
the right hand still looks awkward at best, but holding it with your left hand under the lens might make it a little more comfortable. (might take a while for the image to load).
It does seem like it would have been better if the battery/shutter section would have projected forward instead of to the rear.
Perhaps they need a photon flux capacitor to modulate the noise. Surely these have shrunk enough since 1985 to fit
And here I thought they had lower capacity batteries to keep the size/weight down.  Batteries are rated in watt-amp-hours for a given voltage.  You can have larger batteries and just draw the same power for longer instead of drawing more power for the same amount of time.
This is the first I've heard of electronic noise from Lithium Ion batteries.  Now some chargers have noisy circuits ....
So these are all wild guesses?
Erik
Rudi Senior Member • Posts: 1,057
How can the battery produce noise ? It is pretty much a very large capacitor. What could produce a lot of noise is the power supply which is fed by the battery and has to produce all the necessary voltages for the electronic circuits of the camera and for the display. Might be they needed the extra space to move the power supply electronics further away from the sensor and the image processor to avoid crosstalk and interference from some coils or transformers the need in the power supply.
From this video it looks easier to hold than described...
Here's a video someone posted from CP+ (the post since mysteriously deleted, swear I did not do it!):
http://m.youtube.com/watch?v=wOLfIJgSjRk
In the video, it doesn't look too hard to hold - and the person holding it is able to access all of the controls fairly well.  The swept-back handle seems to match the shape of the hand holding it pretty well also.
Halldor Eiriksson wrote:
Shouldn't there be a left handed version of this camera?
That was my first thought also...
But then looking at every other camera design, they all are pretty one sided affairs.  The Quattro shape just doesn't make any efforts to hide how right-centric it is.
Including lens and grip the dp2 Quattro is 22mm thicker than the DP2M.
Relocating the processing electronics (noise or heat) from between LCD and sensor is about the only reason that makes much sense for the thin but wide body.
Erik
What a load of tosh
8
all these discussions about ergonomics. With the DP Merrills there were complaints that the body doesn't have a proper grip and was too slippery to hold. Now we have a proper grip and the gripes continue - and now it's too much of a grip or the wrong form and so on and so on.
Everybody has to decide for themselves - and mock-ups don't help, in my opinion.
Just wait till you can hold the darn thing in your own hands und use it and play around with it and then decide.
From the video it looks very good to me, personally.
PS:
Just a reminder: hands come in all shapes and some people can't even handle a screwdriver properly.
Re: Another possibility
Without a OVF I think it is better to hold like shown in Your Picture, for You need to watch what´s going on on the display.
Re: What a load of tosh
mrkr wrote:
PS:
... and with all kinds of brains to control them
Very good point
Rudi wrote:
mrkr wrote:
PS:
Cheers
That doesn't mean anything though.  Look at the current DP-M design, no way that new battery is going in that same body without the body getting thicker and the thing being quite a chunk.  Yes the overall design of the new body is in theory thicker, but that's only because of all the angles and the longer lens housing.  In reality the actual body of the new camera is thinner.
Personally I think the new body is much nicer than if they had just blown out the back of the current DP camera, which would have been the lazy design choice.
I do think that's the main reason, but they also needed somewhere to put a fairly large battery and there's no room in the old body.
Your turn it sideways (or diagonal) and add a grip bulge in the front like every other camera.  Or keep the small battery as default but add support for a larger or dual-battery grip.
If it does not fit in smaller bags or pockets, it's not practically thinner.
Perhaps.  Would you like to bet that the next generation DP Cinco-de-Mayo totally abandons this design?
Erik
Fair enough, although personally I've always thought that bulge was pretty ugly.  There's a reason why more compact cameras got rid of it.
True for carrying, it's more of a style thing.  Thin is in.  Visually the body looks very thin, though you're right that for actual use the overall width is larger.
Not much, this design has a lot of benefits.  I'm also pretty sure Sigma is not going to put a fifth sensor in the top layer.
